Old 08-15-2007, 01:47 PM   #1
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Default Cheap Temp Guns
Hello All,
What do you guys think about cheap temp guns? Is it necessary to go for those high price temp guns? Also, if cheap temp guns are ok, which brand/model do you guys suggest?
Thanks in advance!!!
teeforb is offline   Reply With Quote
Old 08-15-2007, 02:04 PM   #2
I use the $39 Odonnell temp/stopwatch. It's always been accurate to within 1 degree of the $300 Exergen and I've tested it many many times.
satoch is offline   Reply With Quote
Old 08-15-2007, 02:17 PM   #3
teeforb's Avatar
Yes, I was looking at that one. I just didn't know how reliable they are.
Old 08-15-2007, 04:02 PM   #4
I've been using mine nearly every weekend for about 9 months with no problems. That's more than good enough for my $40.
Old 08-16-2007, 06:23 AM   #5
rdeppen's Avatar
That's funny because I checked my odonnell agianst 3 different Exergens both the flat DX series and the new DX501 and it was 20 to 30 degrees off.
You get what you pay for. I will say I very rarely use a temp gun anyway other than to check final temp after a qualifier or main. Tune to power and smoke. Guys that are scared becaue there motor runs over 240 aren't taking advantage of fuel mileage and power. My v-specs normally come off the track 260-280.
rdeppen is offline   Reply With Quote
Old 08-16-2007, 06:31 AM   #6
Timmahh's Avatar
Send a message via Yahoo to Timmahh
i use the duratrax temp gauge. small blue one. works great and can be adjusted to read the different metals. an anodized head will give a different reading than a non anod head will. thus you can change how the meter is "weighted" to get the proper readings. im sure the Odonnal also can me adjusted accordingly, which may explain the 20* difference seen by rdeppen
Check my F/S ads I am posting up, Liquidating my bajas and SCBs in part outs.
http://www.rctech.net/forum/r-c-items-sale-trade/562290-wreckluse-crawler-chassis-other-scaler-parts.html http://www.rctech.net/forum/r-c-items-sale-trade/562534-hpi-baja-items-f-s-motor-rtr-tranny-full-wheel-sets-servos-more.html
Timmahh is offline   Reply With Quote
Old 08-16-2007, 08:13 AM   #7
gubbs3's Avatar
I use a cheapy, can't remember exactly what it is. However here's the point: Temp guns aren't used for tuning to temperature. You find a good tune, then temp it. That is about were your engine will normally run well. If you happen to temp it and it has jumped 50* then there is a problem and you need to start checking for air leaks in the exhaust, fuel lines, tank, etc. So the precision is not important, it is simply a tool to check for problems.
gubbs3 is offline   Reply With Quote
Temp guns... again D_o_S Nitro Off-Road 26 07-25-2007 12:15 PM
2 Raytec temp guns cheap! RCJUNKIE R/C Items: For Sale/Trade 29 02-14-2004 12:42 PM
Temp Guns... Fisher890 Nitro On-Road 5 10-15-2003 09:20 PM
Temp Guns for sale. $32.50 iflybyu R/C Items: For Sale/Trade 6 08-18-2003 05:13 PM
Temp Guns for sale swimman R/C Items: For Sale/Trade 0 07-18-2003 05:46 AM
