Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 08-22-2009, 06:35 PM   #8371
bigmatt's Avatar
Originally Posted by malik View Post
I dont see where nobody cant get nothing here I can and ask 22racer where he gets his stuff from? Racefactorindustries is here and not gone it basically was to supply hobby shops. And Russell does have the GX line coming in he just likes to have all old stuf out before he brings in new. I can understand that myself as I have my own buisness and hate having 1 or 2 of the "old" thing on the shelf because its hard to get rid of. Thats all just be patient and all will be well. Trust me I want a GX5 too but I can wait.
God don't get rid of all the old stuff. I have 4 go-tecs. Will need parts for them. I am a go-tec NUT! I cannot say or think of 1 bad thing to say about any part of the product. Once these are broken in they haul ass,keep a tune I get great mileage, with just the stock restrictors. Once I found this thread and understood how to tune these,from gen 4 too gen 5 these are super easy to tune. The engines need the same maintenance as any other engine out there. One of my 7 ports is on gallon 12. What more could you ask for. Get the new stuff here in the states, thank you.
bigmatt is online now   Reply With Quote
Old 08-22-2009, 09:40 PM   #8372
ace921000's Avatar
Two questions.
What is the ideal size carb restricter to use?
Also
What should the needles be set to for break in on a go tech 5 port?
ace921000 is offline   Reply With Quote
Old 08-23-2009, 12:20 AM   #8373
grizz1's Avatar
Originally Posted by ace921000 View Post
Two questions.
Also
Start with the silver 7.0 mm restrictor. This is a good all round size. When you have some tanks on the motor and want to start tuning for economy and run time, switch to the gold 6.5 mm.
If it's a Gen 5.5 with the red logo on the front of the carb, factory settings are flush on both needles.
If it is an earlier model with the long needle (stays in spray bar at full throttle) - HSN .5 turns in from flush and LSN 1.5 turns in from flush will be close. If it's a short needle (comes out of spray bar at 3/4 to full throttle - HSN 1.5 turns in from flush and LSN 2 - 2.5 turns in from flush should be close.
These won't be precise due to differing fuel, pipes, clutch set up etc, but will be close enough to get you started and not too far off a good tune hopefully.
Shane "Grizzly" Adams.
GO RACING NZ www.go-racing.co.nz
X-Ray XB 808 (09 Spec) Buggy
Massive Mods MG66 & 2072 Pipe
ACE - AVID - VP PRO - ANSWER - A-MAIN FUELS
grizz1 is offline   Reply With Quote
Old 08-23-2009, 04:12 AM   #8374
zonda's Avatar
I've just bought a gen 5.5 carb for my gen 4 5 port just to try out. I wil stick with the gen 4 carb, I might prefer it
zonda is offline   Reply With Quote
Old 08-23-2009, 08:35 AM   #8375
bigmatt's Avatar
no you won't. A gen 5.5 carb works and is easier to tune then the gen 4 carb. imo. The only thing with any of those carbs are the carb seals for the needles. You can by some from massive mods or make them out of fuel line(I use fuel line trick, after I have bought all the other engine seals including needle seals from massive mods or fx racing) At least this has been the case for me. And when you do go to massive mods to get your seals. order at least 3 sets of each and keep them on hand. trust me on this one!
Old 08-23-2009, 04:19 PM   #8376
So do the GX line of GO engines use totally different parts than the gen 5 engines? I tried to get a gen 4/5 conrod and was told that I also need a new crank as the big end is now a different size.
It would suck if the internals totaly change and there are different parts needed for the Gen 5 range, the GX range and now the MG66 range.
herb99 is offline   Reply With Quote
Old 08-23-2009, 04:57 PM   #8377
bigmatt's Avatar
I thought the new gx line was really a gen 5.5 with coated parts and pretty heads. As far as the con rods I thought that 4-5.5 were the same. Just porting was changed along with the cranks, carbs. But they all took the same crank rod. Mark from massive mods,22racer or grizz would be the ones who would really know. I wouldn't be surprised if you could take the crank from the gx line along with the new con rod and put it in your go 5.5. along with the carb. as soon as they appear on ebay I plan on trying it.
Old 08-23-2009, 05:08 PM   #8378
RCHavoc's Avatar
My man you are telling the truth! A whole U.S. market waiting for these engines. Our official GO_TECH distributor is a joke. He's coming up with some thing big! Maybe getting fired and getting some one in there that can handle the job. I have been bitching about the way we are supplied with go products for over a year. Need to go to Canada or massive mods for parts. Unless 22 racer has them. They Sure are not here! When I order from fx racing or massive mods I try to order 3-4 of everything. My have to wait a few extra days for parts but at least you get them. Be cause you sure won't get them from RACEFACTOR.
Hey Guys, thanks for your patients.
Racefactorindustries.com is still in the process of being revamped. The GX line of engines is on their way to us. I have been told that the Go Engine factory had had to shut down because of a typhoon in Taiwan. If you have any more questions, you can always email me
dcoleman360@hotmail.com
Otherwise, I will let you know as soon as we receive the new engines.
Thanks again for your patients
RCHavoc is offline   Reply With Quote
Old 08-23-2009, 05:22 PM   #8379
RCHavoc's Avatar
just in case you haven't seen this yet...
Old 08-23-2009, 05:41 PM   #8380
MassiveMods's Avatar
Originally Posted by Marcus Falconie View Post
Curious, it's the same carb that is on your motor the MG66
Hey All
The MG66 and the new GX engine all share the same carb. The only difference is the badge on the front.
The differences are from Gen 5 to Gen 5.5 and Gen 6 MG 66
New Nitrile Seals HSN LSN and Crank Body
New HSN with Double seal ( little bit more sensitive in tuning )
New Carb body material and manufacture process.
TiNi Coated Slide
My first impressions of the carb are good. its very steady and is the best carb Go have made yet ! The older carbs were fine too but suffered from a small problem of the seals being too soft. The New Nitrile Seals are much better ! and indeed have eliminated this problem. So dont panick the gen 5 carbs are still fine , just swap out the seals and youre under way !
Cheers MM
www.massivemods.com Performance Fuels , Engine Mods , Go Engines Australia / Go Engine development manager Australasia
MassiveMods is offline   Reply With Quote
Old 08-23-2009, 05:58 PM   #8381
bigmatt's Avatar
Originally Posted by MassiveMods View Post
Hey All
TiNi Coated Slide
Cheers MM
mark the nitrile seals I got from you were 2 different sizes. The smaller ones fit all the needles on the carb,what were the bigger ones for? It's like they are carb needle seals just the outside diameter is bigger. Inside is the same.
Old 08-23-2009, 06:06 PM   #8382
Gizmatron's Avatar
Send a message via Skype™ to Gizmatron
I asked mark this question..just a standard set of 2 different sizes to fit most nitro engines..the seals aren't specifically made for GO engines..mark told me that the thicker one will fit the GO lsn if you remove the bit on the end with the ball joint for attaching your servo first..but I found even then it shaved a bit of the seal so I too used 2x the smaller size....
Oh and I put 3 liters through the MG66 today..WOW it is just beginning to liven up properly..totally insane..perfect days racing..only breakages was finally blew the bearings in my rear gearbox where the centre driveshaft attaches to the small drive pinion ..but I did this on the lap of honor after the last race and I lost the stinger I JB welded on my 2072 pipe so I'll have to make something proper or buy a new pipe again..bit pissed about that but shit happens in the melee!!
Kyosho mp777 sp2 WC
MM5 GO 7port with HN2047 pipe
MG66 from maaaaaaasive with 2072 pipe
Futaba 3PKS with spektrum pro module and RX
hitec HS5955tg and HS5998tg servos
Gizmatron is offline   Reply With Quote
Old 08-23-2009, 09:36 PM   #8383
22Racer's Avatar
I'll have to catch up on the thread tomorrow, we had a busy weekend of racing. It was round 5 of our Minnesota Nitro series (www.mnnitroseries.com) We had an awesome weekend. Kendall Tqed every round of buggy and Truggy running a 5 port in His Kyosho Mp9 and a 5 port in his St-rr and won both mains. He even had to come in for a tire change after one was coming loose. I Tqed all my rounds and won my Intermediate A with a 7 port. I had been running a 2047 with a 0801 header but went to a 0801 pipe for a little mileage and have to say I like the 0801 better. Can't wait to get the 2072.
Rex
Rw modding and engine repair
Sleeve resizing
Go engine dealer/ Tko bearings
e-mail 22welch@frontiernet.net
Rex Welch
22Racer is offline   Reply With Quote
Old 08-23-2009, 11:50 PM   #8384
hi there
my dealer could get an go mg66 engine, i am thinking about to try it but i not sure
i have a go r21 5pt and a 7pt
i like the 7 port more in my truggy, its an awesome engine.
with which other engine of other brands i can compare a MM Mg66 engine?
with a C6, ninja? would this mg66 have this bottom and low end?
mihael
mihaelbencek is offline   Reply With Quote
Old 08-24-2009, 12:58 AM   #8385
grizz1's Avatar
Originally Posted by mihaelbencek View Post
hi there
mihael
Hi Mihael,
The MG66 has only just been released, with most of the new owners still in the break in process.
There might only be a couple of guys who have seriusly raced the motor at this stage. I know the prototypes where scaring the pants off a lot of other motors out there.
Mark may have done some side by side testing, and may be able to give you more of a comparison.
I would say in a couple of weeks there will be some reports from the track that you could refer to.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
firebird78 , jmackani
Forum Jump
Official Go Engines Thread MassiveMods Australian Racing 1185 Today 06:39 PM
Official O.S Engines thread TTR:EB4 Nitro Off-Road 440 11-18-2009 03:24 PM
Maxy's Fuel and Maxy's Mod Engines (Official Thread) Tabushi Nitro Off-Road 93 10-26-2009 01:08 PM
**The official GO Tech Engine thread** TomB Electric Off-Road 2 03-20-2007 05:10 AM
R/C Tech v2.0: Official Thread futureal R/C Tech Site Forum 26 12-17-2003 12:03 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
