Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-05-2009, 09:48 AM   #7651
mattwoodcraft's Avatar
go a new motor always good fun getting new gear... you could just get the the other up and running as back up ......
i know whats its like a while back my front bearing collapsed and destoyed the block i didnt have a back up
RYPER HOBBIES ~ PURPLE RUSH FUEL ~AKA TYRES
GO TECH MG66 ~ BCE CHASSI
X-ray 808 09 spec
mattwoodcraft is offline   Reply With Quote
Old 07-05-2009, 10:01 AM   #7652
Originally Posted by zJatoRad View Post
the only one who seems to have it right now is MassiveMods in Australia.
hay mate that cooling head will be sent for you in the next couple days it will be sent by air mail i got my brother to send it for you
X-ray 808 09 spec
Old 07-05-2009, 02:26 PM   #7653
grizz1's Avatar
Originally Posted by Gizmatron View Post
Well racing went fabulous today.....until in the semi final I first cracked the weld at the front of the stinger on my new 2072 pipe and almost ripped it right off..Bugger..repairable though but 3 laps later the 7 port died and after a few attempts to restart I slammed the 3 port in and finished the race in 8th..BOO!..Post race inspection of the 7 port revealed a crack in the underside of the crankcase..Oh shit..strip down this evening shows it pushed the rear bearing through the case..ruined the case,crankpin,probably the rod etc and definitely the piston and sleeve (but they were on their last legs anyway)SO! big question is do I rebuild it with the new MM5 p/r/s I have which means new crankcase gen5.5 crank and might as well get MM to fit ceramics as well cause I bet the bearings are shot as the crank was presumably spinning at an angle for a while b4 it died!probably at least aus$160 or do I flog the unused p/r/s kit to someone on here and buy a new MG66..
.MM5 7 port p/r/s unused and ready to run in anyone
Hey Giz, that sucks big time bro. But as they say, every cloud has a silver lining. Now you get to run an MG66 (it's a no brainer - that is your only course of action ). Gee, I love spending other peoples money
Mate, from what I have seen of the prototype Gen 6 6 port which Retro RC tried here, plus the fact that the production MG66 is more advanced than that motor, and knowing what workmanship and high standards Mark at Massive Mods sets, I would not hesitate to go for the MG66 as a replacement.
It is going to be one hell of a motor. It's not only extremely powerful, but is designed to be very drivable as well.
Glad to hear the 2072 is repairable. Man, you did have a bad day at the track
Shane "Grizzly" Adams.
GO RACING NZ www.go-racing.co.nz
X-Ray XB 808 (09 Spec) Buggy
Massive Mods MG66 & 2072 Pipe
ACE - AVID - VP PRO - ANSWER - A-MAIN FUELS
grizz1 is offline   Reply With Quote
Old 07-05-2009, 03:22 PM   #7654
Gizmatron's Avatar
Send a message via Skype™ to Gizmatron
Yeh spoke to mom and the wife and both will cough half the difference between what I have in cash and the cost of the MG66 for my b'day on the 27th..so it's happening..YEH!
The track day was actually great..I was a little off form as I caught my left index finger (read throttle/brake finger) in the baling machine last sunday and ripped it half off.. 3 hours and 12 stitches later it's properly attached again..needless to say it's still bandaged and doesn't bend so I was driving with my second finger which is a little awkward but still was having probably my best drive all season so far...shit happens..I think my karma was sending me toward s an MG66 personally..tee hee
re the 7 port I think when I broke the rod last month it must have hit the bottom of the crankcase and weakened it so when I pinched the sleeve and increased the compression back to almost new again it slowly pushed the bearing through the case..bummer but that's the way it goes sometimes..I did manage to change the 3 port in and still finish 8th..not too bad..
Who cares I'm buying an MG66..FTW
Kyosho mp777 sp2 WC
MM5 GO 7port with HN2047 pipe
MG66 from maaaaaaasive with 2072 pipe
Futaba 3PKS with spektrum pro module and RX
hitec HS5955tg and HS5998tg servos
Gizmatron is offline   Reply With Quote
Old 07-05-2009, 03:52 PM   #7655
dam that sounds painful bro what happen to your finger .....
mmmmmmmmm the best part is your getting a MG66....
happy birthday when it arrives man
X-ray 808 09 spec
Old 07-05-2009, 04:39 PM   #7656
The MG66 well all of the MG's are brobably the best looking mills on the planet. I have been wanting MG but my Sponsorship doesnt cross the ocean. I wish it did. They are alot of loot,I should have thought about that before I had 4 kids LOL. I was trying to get the MG44 a while ago just couldnt make it happen. Awesome job on them Massive.
Caster Fusion pro SA 2200 combo Hitec servo on 4S- Ve8 MMM 2200 system on 4S W/ACE products. Hitec servo, KO EX1-UR 2.4.
Sponsor
GO-ENGINE.COM, GO TECH ENGINES FACTORY TEAM DRIVER
Caster Racing team member, Team terribles
malik is offline   Reply With Quote
Old 07-05-2009, 04:49 PM   #7657
Another thing I wanted to let you guys know the Caster Grenade pipe works awesome on the 3 and 5 ports, havent tried it on a 7. On my 5 it smoothes out the range and screams up top even better than the Dynamite 086 and gives me like an extra minute of runtime. I want to try the header off it on the Dynamite pipe. The pipes are the same length but the Caster pipe is much wider and has a taper at the end. the header on the Caster pipe is much longer and looks like it has 1 of them Novarossi extenders built in it. Its A good pipe. I haven got my 2072 yet still havent hit the states.
Sponsor
Old 07-05-2009, 05:04 PM   #7658
i cant really compare with the pipes you have run when i was waiting for my 2072 i ran the motor in on a 2053 .. that pipe seemed to very good heaps of run time but when i got my 2072 DAM it was a differant beast i run this on the moded 3 port
you will love your 2072 and look sideways at anyone who skates towards your pipe side of the car in fear if they catch that is
X-ray 808 09 spec
Old 07-05-2009, 05:07 PM   #7659
Got to actually race the .21 7p frankenmotor today (the rains have been terrible the last 6 weeks). Out of 13 entrants for 1/8 buggy, I qualified 12th. I was between 5 and 6 seconds off the 30s pace. I made it through two 5-minute heats with ok, but not great power. Just for grins I temped at 228, so I figured I could lean it out another .5 hour. The B-Main went horrible as I was lean bogging and came off the track at 278. Something wasn't right with my tuning philosophy. One positive is that I made the entire 10 minutes and still had some fuel left.
When I bought the motor I remember a number of people complaining about the long LSN and I assumed I had it, but the needle pulled out around half. I tried tuning it with the intermediate settings, but that was horribly wrong. So I stuck to the long recommendations. I got home tonight and measured ... and it's 1.44" (aka short LSN). Reading back over the notes I took, the long and short needles both are around 2.5 turns in from flush. The big difference is in the HSN, which is .5 on the long and 2.5 on the short. That explains why the long settings worked well during the first gallon and gradually got worse.
I certainly feel humbled tonight.
On the bright side, my 0801 pipe has a bent stinger which means I should have the perfect excuse to get the new pipe soon :-D
mthird is offline   Reply With Quote
Old 07-05-2009, 05:09 PM   #7660
The 2035 is basically an 053 which wouldnt work well on the 3 or 5 UNLESS modded. once the mill is modded you can try others and may find something better. I actually want 1 of them AE piipes you have because the guy who modded my 3 changed the timing and says it now need a longer pipe like yours or a 1005, 2060 ect, so if you have no use for it let me know I may take it off your hands.
Sponsor
Old 07-05-2009, 06:07 PM   #7661
megasaxon's Avatar
Send a message via AIM to megasaxon Send a message via Yahoo to megasaxon
he said 2053...
however i have an extra polished AE 2035, just picked up a non-stick one, you can try it out this week if you want, don't really want to sell it, but i'll def let you try it b4 you go out and buy one, lmk
MaxxGullo Motorsports
Team Associated FT RC8T
Reedy 121VR
AE FT EFRA 2035
megasaxon is offline   Reply With Quote
Old 07-05-2009, 06:30 PM   #7662
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Another great weekend for GO Engines in Chile - Southamerica, this time in GT Class :
cya !
Pato Concha
Southamerica
Tabushi is offline   Reply With Quote
Old 07-05-2009, 06:47 PM   #7663
Yeah i would like to try it out. I will be swamped this week at the trophy race though because I will be debuting my ED8 and have tons of work on that to do. Who knows i may get a chance definetly though i want to try it. Yes the black non stick 1 is awesome. Oh and DUH I really didnt see the 2053 LOL.
Sponsor
Old 07-05-2009, 07:35 PM   #7664
bigmatt's Avatar
http://rcspecial.com/news/?p=24197
heres some pic's I found of the new mg66
bigmatt is offline   Reply With Quote
Old 07-05-2009, 09:12 PM   #7665
grizz1's Avatar
Yahoo !! Nice one man. Happy Birthday for the 27th too.
We will need detailed reports about your new motor when it all happens.
Sorry to hear about the finger - OUCH.
Hey Pato, that Class looks like so much fun. I wish we had that class running here. I would be in boots and all
Hmm - nice. It won't be long now. I wasn't planning on buying any motors this year, BUT !!!!!! Looks like I will be hitting the overtime train at work to feed my nitro habit yet again
Forum Jump
Official Go Engines Thread MassiveMods Australian Racing 1184 Yesterday 02:46 PM
Official O.S Engines thread TTR:EB4 Nitro Off-Road 440 11-18-2009 03:24 PM
Maxy's Fuel and Maxy's Mod Engines (Official Thread) Tabushi Nitro Off-Road 93 10-26-2009 01:08 PM
**The official GO Tech Engine thread** TomB Electric Off-Road 2 03-20-2007 05:10 AM
R/C Tech v2.0: Official Thread futureal R/C Tech Site Forum 26 12-17-2003 12:03 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
