Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 12-08-2007, 09:27 AM   #751
Originally Posted by GRudinger View Post
arrg i dont know what to get 5 port or 7 port i am afraid the 5 might be to much bottom for me. what spring are you guys using i have a cheap little thunder tiger clucth
I wouldn't worry about that. These are not "light switch" motors. They are very controllable while still being strong. Fine tuning with header/pipe and clutch settings is easy enough.
The TT clutch is no different from any 3 shoe clutch. Depending on the track you pick your shoes, springs and bell size.
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: CowboyRa@sbcglobal.net
satoch is offline   Reply With Quote
Old 12-08-2007, 09:58 AM   #752
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
http://www.amainhobbies.com/product_...oducts_id/3158
the 5ports bottom end can be tamed down with clutching, gearing, carb restricting and pipe...
the 7port has a nasty top end that can also be tamed down by clutching, gearing, carb restricting and pipe...
i run both, but i myself prefer the 7port, cause of the massive top end speed, and the bottom isnt to shabby either...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 12-08-2007, 12:34 PM   #753
grizz1's Avatar
Hi guys. The 5 Port I purchased for my XUT Truggy has ended up staying in my GS Storm Buggy. I had it in the buggy for the break in process, but it is so much fun in the Buggy it looks like it going to stay there. I am running Dynamite 086 pipe, 14 tooth bell, and carbon shoes with 1.0mm springs. It is a weapon !!.
So it looks like I will need to get a .28 6 Port for the Truggy now (thatīs a shame ). I donīt want to spend any more on pipes etc if I donīt have to, so what would be the best pipe for the .28 out of a Dynamite 053, or a JP-3 ?
I run what you guys would call reasonably tight/technical tracks, with moderatly short straights. Any feedback greatly appreciated
Shane "Grizzly" Adams.
GO RACING NZ www.go-racing.co.nz
X-Ray XB 808 (09 Spec) Buggy
Massive Mods MG66 & 2072 Pipe
ACE - AVID - VP PRO - ANSWER - A-MAIN FUELS
grizz1 is offline   Reply With Quote
Old 12-08-2007, 12:47 PM   #754
well the 053 i feel will be to much bottom, and will make the truggy hard to drive, but will give ok run times...
the JP-3 will be easier to drive, but will make the 28 thirsty and be a bit of a fuel hog...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 12-08-2007, 09:15 PM   #755
grizz1's Avatar
Thanks Jason, looks like a new pipe might be required if I go that way. What do you run on your .28 / Truggy combo ?
My other option is to buy a 7 Port for my buggy, and put the 5 Port back into the truggy as originally planned. I have the 086 pipe for 5 port / truggy combo and an 053 which I believe is the right pipe for the 7 port /buggy combo.
Decisions - decisions
Old 12-08-2007, 09:21 PM   #756
go with the 28 for the trug...ive been running the 086 and 2047 pipes on the 28 with great results...i would go for the dynamite 086 if you doent want to spend to much money, and the performance is great, run times to...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 12-08-2007, 09:32 PM   #757
whats this the assies got the 3port race before the US did???
http://www.massivemods.com.au/produc...products_id=72
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 12-08-2007, 10:20 PM   #758
Default go tech engines life span
how long do these engines last? Are they easy to tune? which will you recomend for a jammin x1 crt(truggy)?
rawdawgga is offline   Reply With Quote
Old 12-08-2007, 10:35 PM   #759
grizz1's Avatar
Cheers Jason, Will take your advice and go the .28 way. All that power with economy as well - sounds like me !!
Thanks for your advice on that run in shim too, it made my life a lot easier. Removed it last week as temps stabilized and engine is getting easier to turn over now. Up to 35 tanks and it's starting to really haul now.
Turbo head is next thing on the shopping list.
The 5 port is a nice combo in my buggy, as the strong bottom end suits the tracks I run. With the softer clutch set up and 14 tooth clutch bell it isn't too much of a handful when you gun it out of corners, and it winds up pretty good on the medium length straights with the 086 pipe too. Now I've just got to get used to the power as compared to my old RTR engine
Old 12-08-2007, 10:49 PM   #760
rossoh10's Avatar
I gotta get the new 3 port
rossoh10 is offline   Reply With Quote
Old 12-09-2007, 02:57 AM   #761
Default Go tech .28 pullstart compatible???
Hey guys!! I'm planning to change my go tech .28 to a pullstart so that I can install it to my savage... I've seen this selling in a main hobbies:http://www.amainhobbies.com/product_...ducts_id/17037 and I was wondering If this pullstart is a direct fit to the engine or does it need other parts in order to install it??? Pls. help me... thanks!!!!
davelee_128 is offline   Reply With Quote
Old 12-09-2007, 08:00 AM   #762
mugenb46's Avatar
The 5 port turbo hands down unless you want to go with the .25 or .28, but i like the .21 for sure, add a 053,086,1005 and you got a great set up there. The 5 ports tune awesome, you can run them a little fat on the bottom to help tame it down and still move out.
Brian Carey
Pro Twister Mods
brian@protwistermods.com
615-838-5373
mugenb46 is offline   Reply With Quote
Old 12-09-2007, 08:35 AM   #763
Rocket42's Avatar
davelee, that pullstart will work with the .28 sport engine but you will also need this part http://www.amainhobbies.com/product_...ducts_id/16321 it is what the pullstart attaches too. These parts also will work with the race .25 and .28, but you will also have to replace the crankshaft with the crankshaft from the sport engines.
Rocket42 is offline   Reply With Quote
Old 12-09-2007, 08:51 AM   #764
i would say to go with the .28...all the top end of the .21, but with the bottom it takes to move a truggy...however if you want the best of both worlds check out the .25...anyway you choose you will be very happy with Go engines...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 12-09-2007, 09:21 AM   #765
CRASH's Avatar
Trader Rating: 26 (100%+)
I am considering trying the .28 in my truggy. What is the recommended pipe for this motor in a truggy?
Also how does this motor compare to the os motors?
Thanks,
CRASH is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
rageworks
Forum Jump
Official Go Engines Thread MassiveMods Australian Racing 1185 Today 06:39 PM
Official O.S Engines thread TTR:EB4 Nitro Off-Road 440 11-18-2009 03:24 PM
Maxy's Fuel and Maxy's Mod Engines (Official Thread) Tabushi Nitro Off-Road 93 10-26-2009 01:08 PM
**The official GO Tech Engine thread** TomB Electric Off-Road 2 03-20-2007 05:10 AM
R/C Tech v2.0: Official Thread futureal R/C Tech Site Forum 26 12-17-2003 12:03 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
