Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 05-20-2009, 08:49 PM   #6886
vhb
Default Starter box input?
So, I will be breaking in a very tight motor. Need to buy a starter box and am looking at the OFNA Truggy/Buggy box 10244.
What are you guys using?
tks,
vhb
vhb is offline   Reply With Quote
Old 05-20-2009, 08:52 PM   #6887
22Racer's Avatar
Trader Rating: 15 (100%+)
tks,
vhb
Thats the one to get.
After breaking in motors on a break in bench I really like it, motors start up faster and don't flame out near as much.
Rex
Rw modding and engine repair
Sleeve resizing
Go engine dealer/ Tko bearings
e-mail 22welch@frontiernet.net
Rex Welch
22Racer is offline   Reply With Quote
Old 05-20-2009, 08:57 PM   #6888
bigmatt's Avatar
I use the OFN10245 compact starter box. when you first start your new engine heat it up. then loosen the glow plug to get it to turn over and fired up. then just tighten glow plug back down. I also use massive mods run in oil.
bigmatt is offline   Reply With Quote
Old 05-20-2009, 09:58 PM   #6889
looper's Avatar
Trader Rating: 17 (100%+)
Send a message via Yahoo to looper
So i did breakin on the go sport 3 port today, so far have about 9 tanks on it, it started up with little hassle. basically did a modified breakin, 2 tanks on the box just to set the bearings in and then (so far) 7 tanks on the ground not exceeding 1/2 throttle(many of those tanks were 2 minutes at a time). ran out of gas twice (thing is drinking like dudley moore did booze in arthur) and at flame out it temped at 245 regular temps were in the 210- 230 range. carb is set at flush lsn and 2 hours in on the hsn. yeah it is smoking more than tommy chong used to.
Not going past 1/2 throttle i was putting semi consistant 31-32 second laps. the fastest out there were doing 28-30 second laps.
I am really digging it! running fox med glowplug and 25%/12.5% fuel and a 086 pipe.. even with the 7mm restricter in there runtime isnt all that great but i am sure it will improve as it runs in.
Team Terribles
[URL="http://loopeddesigns.webs.com/"]looped designs paintworks[/URL]
looper is offline   Reply With Quote
Old 05-20-2009, 10:01 PM   #6890
looper's Avatar
i have been using the same ofna stainless box for the past 3 years.. same wheel, belt everything! when using it for the gas truck i put some slightly lighter springs in it though, not a needed thing just was bored and had them on the bench
this thing is the cats meow.
Team Terribles
Old 05-21-2009, 01:19 AM   #6891
pink_sleeve's Avatar
Trader Rating: 107 (100%+)
What pipe works the best on the 3 port race for decent power with good fuel economy? Also what plug are you guys running in the race motor? Also are there better orings out there for the carb?
ARCS HOBBIES - DIGGITY DESIGNS
HIGHVELOCITY RACING - WIFE OF AMERICA BANKING
pink_sleeve is offline   Reply With Quote
Old 05-21-2009, 05:10 AM   #6892
mattwoodcraft's Avatar
there are new o-rings out for the carbies i put some in my 5 port
this is the number on mm website
NEW MM Carb Seal Kit
[MMCO]
New MM Carb Seal Kit comes with 10 carb seals for HSN and LSN needles and some Midrange needles.. Will suit Most carbs including Go, OS , Nova , HPI,Thunder Tiger, Hyper.
Comes with 5 x 6.5 mm OD and 5 x 6.9 Mm OD seals. These are made from HDPE Nitrile Compound which is flake and fuel resistant.
RYPER HOBBIES ~ PURPLE RUSH FUEL ~AKA AUSTRALIA
GO TECH MG66 ~ BCE CHASSI
X-ray 808 09 spec
mattwoodcraft is offline   Reply With Quote
Old 05-21-2009, 05:14 AM   #6893
i have been through alot of starter boxes and the one i like and is dam good value for money is the q-world one the cheaper one out of the 2 similar to the mugan box ... this starter box Q-world one is good cheap and starts any engine i have put in my buggy without any problems at all
X-ray 808 09 spec
Old 05-21-2009, 06:46 AM   #6894
stu541's Avatar
Default 3 port pipe
Pink Sleeve,
I haven't tried the Go pipes yet, but the 086 is a great pipe on the 3 port race. I would also run a 7mm carb restrictor.
2010 gear:
odonnellracing.com
protwistermods.com
vp-pro-usa.com
stu541 is offline   Reply With Quote
Old 05-21-2009, 07:42 AM   #6895
markr04's Avatar
tks,
vhb
That's the best starter box I've personally used (out of mine and other people's). It will start new engines in your buggy, truggy, and Chevy.
Losi 8ight-B 2.0 - O.S. V-Spec Speed - Airtronics M11-DSSS
Losi 8ight-T 2.0 - RB Killer 9 - Airtronics M11-FHSS-2
Losi XXX-CR - Tekin RS / Novak Ballistic 13.5 - Airtronics M11-FHSS-2
Traxxas Slash - all stock - Spektrum DX 2.0
Team Terribles
markr04 is offline   Reply With Quote
Old 05-21-2009, 08:36 AM   #6896
i have heard good reports about the new go pipe 2072 have not tried one yet i like the losi pipes i find the re10 pipe awsome on the bottom end and still more than enough on the mid to top
X-ray 808 09 spec
Old 05-21-2009, 10:16 AM   #6897
DRRC's Avatar
Trader Rating: 9 (91%+)
I have had my go 7 port for a while now and lost the tune again
I have it at <.5 HSN and 1.5-2 LSN
I seems to be high reving especially at 1/2 throttle, it is not on pipe and have tried everything and dont know how to get the tune
I am using a dynamite MR pipe
thanks
D8T army - Extech .21, D8 - EB Extech .21, D8T-E
AE TC5 - LRP 4.5, T4 - LRP 6.5 sintered, B4 - LRP 7.5 sintered
Losi 8T-E, Losi 8-E, Losi 8T Go 7pt, XX-4 - LRP 5.5
Slash
Team Wife
DRRC is offline   Reply With Quote
Old 05-21-2009, 10:49 AM   #6898
Gizmatron's Avatar
Send a message via Skype™ to Gizmatron
Just fitted a GO 2072 in my mp777 buggy on a MM5 7 port with a 7mm restrictor..with 5000 oil in the center diff I can jam on the brakes and hit the throttle and it wheelies down our club straight...totally insane - everyone should have one
Kyosho mp777 WC - MM5 GO 7port with HN2047 pipe
Xray xb808 - MG66 from maaaaaaasive with 2072 pipe
Futaba 3PKS with spektrum pro module and RX
hitec HS5955tg and HS5998tg servos
Gizmatron is offline   Reply With Quote
Old 05-21-2009, 10:53 AM   #6899
bigmatt's Avatar
thanks
sounds like an air leak. mine leaked around carb,very slight. just enough to throw of tune.
Old 05-21-2009, 11:24 AM   #6900
Default go tech
well mark is right it will start a chevy i use marks starter box as well has a few other guys truggys and buggys and it starts us all. has to the pipes i need a new one which is best for the 7 port right i have the rtr pipe off the losi lol what should i go with
leapinglizard is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Forum Jump
Official O.S Engines thread TTR:EB4 Nitro Off-Road 714 Yesterday 08:44 PM
Official Go Engines Thread MassiveMods Australian Racing 1476 Yesterday 07:52 PM
Maxy's Fuel and Maxy's Mod Engines (Official Thread) Tabushi Nitro Off-Road 93 10-26-2009 01:08 PM
**The official GO Tech Engine thread** TomB Electric Off-Road 2 03-20-2007 05:10 AM
R/C Tech v2.0: Official Thread futureal R/C Tech Site Forum 26 12-17-2003 12:03 PM
Powered By: vBulletin v3.7.6
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
