Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 03-21-2009, 10:33 AM   #6091
Caster Fusion pro SA 2200 combo Hitec servo on 4S- Ve8 MMM 2200 system on 4S W/ACE products. Hitec servo, KO EX1-UR 2.4.
Sponsor
GO-ENGINE.COM, GO TECH ENGINES FACTORY TEAM DRIVER
Caster Racing team member, Team terribles
malik is offline   Reply With Quote
Old 03-21-2009, 10:55 AM   #6092
vyt666's Avatar
bought this cooling head from a friend,the only problem is he forgot what brand of cooling head it is..if i could remember it is an aftermarket head for the hyper 21 engine,but never had a chance to mount this head on my hyper21..good thing is that the hyper 21 and the go engines sleeve has the same size.
swabe!
vyt666 is offline   Reply With Quote
Old 03-21-2009, 12:28 PM   #6093
heeltoedrver's Avatar
hey all - as far as the gotech .25 6port race goes, what pipe? is there a carb restrictor which gives the best of both worlds too?
Team Terribles
heeltoedrver is offline   Reply With Quote
Old 03-21-2009, 12:31 PM   #6094
endler's Avatar
I wanna know too!!!!
Action Hobbies Kingsville
Canwest RC/Xray Canada
FXR Hobby/GO engine Canada
Blitz Bodies/VP Pro
Rizzos Rides
endler is offline   Reply With Quote
Old 03-21-2009, 12:57 PM   #6095
Gizmatron's Avatar
Send a message via Skype™ to Gizmatron
Well - first run of the season today..circuit all finished apart from a bit of rakin over on the new banked corner..MM stage 5 - 7port with 7mm insert ...da da da daaaaaah 10m36s on a tank for the first run..was a whisker hot for my liking and not smoking much so richened the hsn about 1/8 turn..perfect and 10m23s on a tank..more than enough power to spin the tyres just about anywhere on the dry loose surface and killing everybody else on the now longer straight. Rockin..really really pleased with this motor now its run in..still a bitch to start on the box without a little preheat from cold after almost 2 gallons.
Kyosho mp777 sp2 WC
MM5 GO 7port with HN2047 pipe
MG66 from maaaaaaasive with 2072 pipe
Futaba 3PKS with spektrum pro module and RX
hitec HS5955tg and HS5998tg servos
Gizmatron is offline   Reply With Quote
Old 03-21-2009, 01:02 PM   #6096
For the .25 the Go 0801 or dynamite 086 and start with the 7mm restricter. Depending on track size and weight of the truggy you can go way smaller and you will definetly get the best of both worlds.
Sponsor
Old 03-21-2009, 04:31 PM   #6097
hi! there i need you guys help broke da go3r crankcase (cracked)& amainhbbs have no parts on this ,if you got spare even used one ,i dont care i just need to run again da truck, pls. just pm me if youre interested to sell it,thks again
mbx5rcr34 is offline   Reply With Quote
Old 03-21-2009, 04:54 PM   #6098
If nobody responds call Russel at Racefactor Industries 1-928-274-4017 tell him I told you to call. He is the US importer so if no shop has it he might.
Sponsor
Old 03-21-2009, 08:28 PM   #6099
tagalong_74's Avatar
Trader Rating: 22 (100%+)
you could just look on ebay or look on racefactors website. Russel is a good guy and will deal with anyone. You don't need to mention anyones name for him to work with you. I'm sure he has what you are looking for
Factory Team RC8 .21 RB S7
tagalong_74 is offline   Reply With Quote
Old 03-21-2009, 09:27 PM   #6100
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
I use GO 0801 pipe with 7.5mm restrictor i get 08.50 minutes of runtime. Today i was helping a friend to end the break inn process and once leaned for race and 4 tanks in a row with stock carb no inserts was doing 08.00 minutes with JP2 pipe and Odonnel 97 plug. He will install 7.5mm restrictor so can manage to pit at 08.00
cya !
Patricio "PATO" Concha
CEN Racing USA / GO Engines / VP PRO Racing
Avid RC / Ultimate Racing / Maxy's Fuel / ARC Hobbies Chile
MSN & E-Mail : pato_concha@yahoo.com
Tabushi is online now   Reply With Quote
Old 03-22-2009, 05:21 AM   #6101
cya !
I'm running the stock .25 with OCM redline pipe (pretty much same as Novarossi 9853) with a shorter header from GO 2047. With standard 8mm restrictor and even the engine is not fully broken in yet I can do easily 8min in my OCM Truggy. Most probably I'll go to 7mm restrictor and 14t bell when it's settled and aim to 10min
Poinas2 is offline   Reply With Quote
Old 03-22-2009, 09:18 AM   #6102
bigmatt's Avatar
has any one tried the MassiveMods Run In Ring? on a new engine.
bigmatt is offline   Reply With Quote
Old 03-22-2009, 11:52 AM   #6103
bigmatt's Avatar
also can someone point me in the right direction on how to disassemble a engine? take piston sleeve out that sort of thing. thanks for your time.
Old 03-22-2009, 01:05 PM   #6104
this might be listed already but whats the pipe of choice for the go tech 5 port engine ? it seems I saw somewhere someone said the dynamite 085, may be wrong. thanks.
Retired from racing do to football season.
Go Foley Lions !! #27
roadracer43 is offline   Reply With Quote
Old 03-22-2009, 01:08 PM   #6105
grizz1's Avatar
Matt, you got PM
Shane "Grizzly" Adams.
GO RACING NZ www.go-racing.co.nz
X-Ray XB 808 (09 Spec) Buggy
Massive Mods MG66 & 2072 Pipe
ACE - AVID - VP PRO - ANSWER - A-MAIN FUELS
grizz1 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
crashman1 , defcon13
Forum Jump
Official Go Engines Thread MassiveMods Australian Racing 1185 Today 06:39 PM
Official O.S Engines thread TTR:EB4 Nitro Off-Road 440 11-18-2009 03:24 PM
Maxy's Fuel and Maxy's Mod Engines (Official Thread) Tabushi Nitro Off-Road 93 10-26-2009 01:08 PM
**The official GO Tech Engine thread** TomB Electric Off-Road 2 03-20-2007 05:10 AM
R/C Tech v2.0: Official Thread futureal R/C Tech Site Forum 26 12-17-2003 12:03 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
