Old 08-13-2007, 10:22 AM   #1
Default Buggy Help: Pull starter
Hi, I recently bought this buggy: http://cgi.ebay.com/NEW-2-SPEED-RC-R...QQcmdZViewItem
I used it for about 5 minutes on a baseball field and all of a sudden it wouldn't go. The engine ran, but it not go anywhere. When I try starting it. the..the pull starter would not budge. It did not move an inch. Can someone please help me..Thanks.
jjlim129 is offline   Reply With Quote
Old 08-13-2007, 10:36 AM   #2
Timmahh's Avatar
Send a message via Yahoo to Timmahh
ok, could be a few things causing the buggy not to move.
clutch shoes could be bad, but im more inclined to believe the motor shifted and isnt meshing with the tranny. if you look at the pics from your auction, you see the pics in the middle of the 4 gears, 2 are black(Spur Gears on the transmision) and two are metal ( Pinion Gears on the Clutch Bell). these gears will need to Mesh together to make your buggy move. if your motor mount bolts loosened up, this would allow the motor of move, thus opening a gap between them. therego the motor will run/rev up ect, but the buggy stays still.
it could also be any of the drive shafts, either the center driveshafts, or the wheel driveshafts could have lost, loose or broken pins or even loose setscrews.
you ll have to check each part along the drive train to find out where the issue lies.
for the Pull starter, it could be a bad oneway bearing, or a knot in the ps rope. can you roll the motor over by spinning the flywheel with your hand?
for a starter buggy, it may not be to bad, but to be honest with you, it will probably be somewhat of a PITA to get parts for. especially if it brakes alot without a good reason why. i would suggest use it the best you can, and save a few hundred dollars and buy a nice quality and in decent condition used buggy.
if you can save 400.00 to 600.00 you can get a very nice, High Quality, used buggy in Very Very good shape.
jm2c.
Timmahh
Check my F/S ads I am posting up, Liquidating my bajas and SCBs in part outs.
http://www.rctech.net/forum/r-c-items-sale-trade/562290-wreckluse-crawler-chassis-other-scaler-parts.html http://www.rctech.net/forum/r-c-items-sale-trade/562534-hpi-baja-items-f-s-motor-rtr-tranny-full-wheel-sets-servos-more.html
Timmahh is offline   Reply With Quote
Old 08-15-2007, 01:54 AM   #3
khoo's Avatar
hi,
1) you could have stripped your gears if the engine is running (throttle squeezed) and the car is not moving.
2) you need to remove the pull starter. it's probably stucked.
khoo is offline   Reply With Quote
Pull starter steven_tiger Monster Trucks 5 03-03-2008 05:21 PM
.15 pull starter? MRC15 Electric Off-Road 2 11-25-2006 06:09 AM
where can i get this pull starter? sho .21 Electric Off-Road 0 04-09-2005 07:06 PM
WTB: AE Pull Starter raj824 R/C Items: Wanted to Buy 3 02-02-2005 07:59 PM
Help: When I pull the pull starter, wheels of car move racer rich Nitro On-Road 3 01-04-2004 06:29 PM
