Old 08-13-2007, 05:02 PM   #16
Send a message via MSN to rhymster
still no good i think my flywheel got wore out some i guess ima buy a new one if no one else has any ideas thanks
rhymster is offline   Reply With Quote
Old 08-13-2007, 06:15 PM   #17
tex1's Avatar
Send a message via Yahoo to tex1
You need the end spacer that is a Losi step type countersunk screw.
It will space the engine shaft properly even though it is not sticking through the front bearing completely.
Check your manual. That is how it is designed.
TEX
tex1 is offline   Reply With Quote
Old 08-13-2007, 06:50 PM   #18
im not a 5th grader bud i know how to follow a manual and see which parts are designed for what. it has worked for this engine and my rb until i spun my original collet since then nothin works not even the designed way
Old 08-14-2007, 04:13 AM   #19
tex1's Avatar
Red face Relax....
Don't get defensive. We are just trying to help. I have seen a lot of guys loose their outer washers and not pay attention and have the same problem. When you described the shaft not going all the way through the bearing I thought you may have over looked your washer. That's all.
TEX
Old 08-14-2007, 04:22 AM   #20
no i havent i ave tried everything thats what is frustrating
Old 08-15-2007, 07:01 AM   #21
Default same problem
Hello
I have a Losi 8 and an OS Vspec engine. I know the pilot shaft is 1mm shorter than other engines but i have tried almost everything but still i cant get the cluth bell spin free. It looks like it stucks on the flywheel. I need your help please.
mettuchi is offline   Reply With Quote
Old 08-15-2007, 01:02 PM   #22
K_B
K_B's Avatar
Trader Rating: 69 (100%+)
Originally Posted by mettuchi View Post
Hello
Two things I had wrong when my clutchbell hung up on the flywheel:
1)The clutch nut was loose.
2)I forgot the shim that goes in between the clutch nut and the 5x13 bearing.
If those two are OK, I would try adding an extra shim or using a thicker shim. I think this has all been covered here though.
K_B is offline   Reply With Quote
Old 08-16-2007, 05:52 AM   #23
tex1's Avatar
Red face Maybe this will help...
There are a series of very small washers I used to use for electric motor tuning. I have always kept my stuff around so I have long forgotten where I got them. Anyways, these washers are 3mm ID and smaller than the inner race of your bearings. They are used to shim out the countersunk washer to give you more play.
Look in the electric section for shim solutions. Motor shims. May be Trinity Kinwald chassis shims????
They work great!
TEX
Old 08-17-2007, 03:04 PM   #24
hey guys finally got my clutch working again i just got my new flywheel in and bell and it works fine. how much play do u guys give your clutchbell
Old 08-17-2007, 03:26 PM   #25
K_B
K_B's Avatar
It should tell you in the manual. It's about .5mm or something like that...
Losi 8ight buggy and Truggy Clutch problems layedbackguy Nitro Off-Road 17 01-17-2008 02:36 PM
Losi 8ight/8ight-t clutch parts dido41 R/C Items: For Sale/Trade 5 08-06-2007 04:51 PM
Problems with clutch! Hampe Electric Off-Road 2 01-18-2006 09:52 AM
Clutch problems?? chilionastick Monster Trucks 6 09-16-2005 03:56 PM
Clutch Problems Tazman6789 Electric Off-Road 3 08-28-2005 01:08 PM
