Old 08-10-2007, 06:54 PM   #1
Default Throttle problem with losi 8ight
Here's my problem. After I run two or three tanks thru my buggy, the throttle servo stops working. This has happened about four times now. I used JRPSZ590 Z590M Torque Race Servo: Metal Gear the first two times, and then I switched to the 650's the last two times. I'm stuck in Iraq right now, and there aren't any hobby shops here(I looked). Any suggestions? Thanks
In_Iraq is offline   Reply With Quote
Old 08-10-2007, 07:16 PM   #2
your an idiot losi king
Resale_Warehous is offline   Reply With Quote
Old 08-10-2007, 07:26 PM   #3
Timmahh's Avatar
Send a message via Yahoo to Timmahh
set the epa on the brakes correctly. im willing to bet when braking, the servo is trying to plull farther than it mechanically can pull the brake assembly, thus overstraining and overheating the servo and shutting them down, or burning them out.
keep in mind the stock 270 servo is only 43 in/oz of torque. the 590 is better at 88, and the 650 better yet at 130ish. But none of them are good if your overstraining the servo.
Be sure to adjust the epa on the brake so its pulling just far enough to fully engauge them.
on my jammin with the Z650MG on Trt/Brake and my React, im thinking i have my brake epa set just over 40. like 46 or 47. but i also have the antilock brake feature setup on the React and Man that is the Cats Meow. i cna lock them up at full application but up to 80% its pulses the brakes and i have great control coming hot into the corners with it.
Check my F/S ads I am posting up, Liquidating my bajas and SCBs in part outs.
http://www.rctech.net/forum/r-c-items-sale-trade/562290-wreckluse-crawler-chassis-other-scaler-parts.html http://www.rctech.net/forum/r-c-items-sale-trade/562534-hpi-baja-items-f-s-motor-rtr-tranny-full-wheel-sets-servos-more.html
Timmahh is offline   Reply With Quote
need help with 8ight throttle linkage mike williams Nitro Off-Road 6 02-12-2008 09:14 PM
Need help with M8 throttle problem Jerrit1 Nitro On-Road 1 08-20-2007 03:00 AM
M8 throttle problem Jerrit1 Nitro Off-Road 1 08-20-2007 12:17 AM
Steering problem on my Losi 8ight RcOneNitro Nitro Off-Road 12 08-11-2007 08:22 AM
THrottle linkage problem... LiLRCLoUiE Nitro On-Road 5 05-18-2002 09:13 PM
