Old 08-10-2007, 02:31 PM   #1
Send a message via AIM to Os_powerd_jato Send a message via MSN to Os_powerd_jato Send a message via Yahoo to Os_powerd_jato
Default Matrix Arena FRE Build
I will be building a Matrix Arena FRE soon. Heres what i orderd:
2 x Pro-Line White 23mm HD MAXX Standard Offset Monster Truck Rims (2) (PRO268404) = $23.98
1 x Kyosho Silicone Diff Oil 2,000wt (40 CC) (KYOSIL2000) = $8.49
2 x Pro-Line Crime Fighter MTR Monster Truck Tires (2) (PRO113500) = $47.98
1 x Pacer Zap-A-Gap CA+ Thick (1oz) (HOUPT02) = $6.49
1 x Kyosho Silicone Diff Oil 5,000wt (40 CC) (KYOSIL5000) = $8.49
1 x CEN Racing Matrix TR Arena Factory Race Edition Truggy (CEG9563) = $449.99
1 x Associated Silicone Shock Oil 40wt 2oz (ASC5423) = $2.99
1 x Associated Silicone Shock Oil 60wt 2oz (ASC5436) = $2.99
1 x CEN Racing Matrix TR Arena Body (Painted) (CEGMX103) = $40.99
I Am putting in a OS V-spec for a little wile and maybe get a Novarossi.
Pictures will be up when i get it monday.. I cant wait
...........SELLING OUT!!!!!!!!!!!!!!!!!!!!
Os_powerd_jato is offline   Reply With Quote
Old 08-10-2007, 02:42 PM   #2
rregl0612's Avatar
Trader Rating: 33 (100%+)
Default Rims
Truck is not nearly as twitchy with the offset rims.. just a thought.. and if you havent been cruising.. lots of good info here..!!!?
CEN Matrix TR
Hope this helps.. You should get the new kit with the regular diffs.. if you do not just contact CEN.. they will probly help you out..
THe only really needed part to upgrade on the truck is the Upper cnc servo saver bellcrank.....
Like I said about the Rims .. I was super afraid the truck would be too wide with offsets.. and it looks big when you put em on.. but on the track.. woo. what a difference.. I think I nocked atleast a second off my lap times..
rregl0612 is offline   Reply With Quote
Old 08-10-2007, 02:47 PM   #3
Regular diffs? Like as in not cross-pin? I think i would prefer the cross-pins..
Old 08-10-2007, 03:22 PM   #4
rregl0612's Avatar
no like as the original kits have LSD's... new kits.. within the last couple of months have standard cross pin diffs
Old 08-14-2007, 11:21 PM   #5
I got it
Old 08-15-2007, 10:42 PM   #6
I am almost done. I have to tare it down again because i put either the front and back diffs in back words or the center diff in backwards. (I spun the center diff the way the engine will turn it and went backwards!) Does it matter on were you put your spur gear or the gears on the diffs?
ALL of the camber has been fixed.. Just showing how bad it would have drove!
Old 08-16-2007, 09:36 AM   #7
Trader Rating: 26 (100%+)
there is an arrow moulded into the diff case to show which side the ring gear goes on, pretty sure the book tells you that if you read it closer,
bobf24 is offline   Reply With Quote
Old 08-18-2007, 05:51 AM   #8
sir miles's Avatar
Trader Rating: 23 (100%+)
I also want to build a FTE but the dogbone/ axle popping problem avoided me from doing so. Is there a chance that CEN would address this problem and upgrade the axle that comes with the kit?
gaining momentum!
sir miles is offline   Reply With Quote
Old 08-18-2007, 07:59 PM   #9
A.C
A.C's Avatar
Send a message via MSN to A.C
hi bro understand that u driving the Hobao hyper ST.
izit a good ride as i heard that i will suffer from Air leak from the Fuel Tank.
and that the radio tray where u put the Hump pack is lock by screw and not body clip. izit a hassle to change the hump pack during race?
and are there any CNC parts for the hyper ST..
pls advice..
A.C is offline   Reply With Quote
Old 08-21-2007, 08:09 AM   #10
http://www.rctech.net/forum/showthre...=1#post3601226
This explains how to keep the CVD from poping out. The problem has been fixed also with new arms. Team CEN ran them at the Nationals and they worked perfect.
VP-Pro USA - www.raceVPpro.com
Agama USA - www.AgamaUSA.com
Maxy's Fuel - www.Maxysfuel.com
Machine's R/C H is offline   Reply With Quote
fs/ft: cen matrix arena fre chrisw R/C Items: For Sale/Trade 15 12-09-2007 06:59 PM
CEN Matrix Arena TR kamlooper R/C Items: For Sale/Trade 12 11-30-2007 09:34 PM
Cen Matrix Arena Tr Fre 3nigma R/C Items: For Sale/Trade 20 11-29-2007 11:43 PM
Matrix Tr Arena NIdaho Mudder R/C Items: For Sale/Trade 6 05-19-2007 11:04 AM
Cen Matrix TR Arena Marz Australia For Sale/Trade 0 05-09-2007 02:35 AM
