Old 08-09-2007, 08:59 PM   #1
RcOneNitro's Avatar
Trader Rating: 60 (98%+)
Default Steering problem on my Losi 8ight
When I turn on the radio on and then the switch on my Losi 8ight the steering servo turns the tires all the way top the right and stuck. I can not move the tires at all. I tried changing the steering on the radio but the tires didn't move.
Is there anything I can do to fix this or is the steering servo shot? I am using a JR650.
Thanks...
RcOneNitro is offline   Reply With Quote
Old 08-09-2007, 09:06 PM   #2
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Yup, it sounds like the gears in your servo are stripped.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 08-09-2007, 10:40 PM   #3
did you put the steering horn on wrong? pull it off, turn everything on so it straightens the servo out, then place the horn on. Not sure if you did that or not.
jarel is offline   Reply With Quote
Old 08-10-2007, 12:12 AM   #4
ya that happened to me once.. then i did what jarel said and i never had any problems after that
venomystic96 is offline   Reply With Quote
Old 08-10-2007, 12:21 AM   #5
RcOneNitro's Avatar
Thanks jarel -- fixed the problem. Long day at work and just was not thinking.
Old 08-10-2007, 07:37 AM   #6
Timmahh's Avatar
Send a message via Yahoo to Timmahh
lol, yea not turing on and centering the servo BEFOR installing the servo horn has got us all atleast once b4.
Check my F/S ads I am posting up, Liquidating my bajas and SCBs in part outs.
http://www.rctech.net/forum/r-c-items-sale-trade/562290-wreckluse-crawler-chassis-other-scaler-parts.html http://www.rctech.net/forum/r-c-items-sale-trade/562534-hpi-baja-items-f-s-motor-rtr-tranny-full-wheel-sets-servos-more.html
Timmahh is offline   Reply With Quote
Old 08-10-2007, 10:27 AM   #7
Hey guys I also have a problem with my Losi 8t steering. It seems likes there's alot of binding to the point that my servo cannot get back to its neutral position. When I remove the top brace and loosen the screw to the main servo saver it seems fine but after I tighten the screw the binding is back. I have a hitec 5955 servo that has a claimed torque of 333 oz and it can't turn the darn wheels. Please help! Suggestions on what maybe the culprit to the problem are appreciated.
r6ryder is offline   Reply With Quote
Old 08-10-2007, 10:39 AM   #8
Send a message via MSN to Adim_X
r6ryder,
It sounds like you already know what the problem is. Try putting a small washer in between the bearing and the upper plate, then retightening your screw. Use some loctite, then you can run it a little looser, but not have the screw come out.
Adim_X is offline   Reply With Quote
Old 08-10-2007, 07:20 PM   #9
No problem, i've done it plenty of times not thinking before. it happens
Old 08-10-2007, 08:14 PM   #10
RcOneNitro's Avatar
I was told for Losi 8ight pro you should put the higher torque servo on the throttle than for steering. I have a JR 650 and JR 550 on the buggy now - 650 is setup as steering. I also have a JR Z9000T on my Revo and Muggy that I was thinking of taking one of them and putting it on the buggy.
Which servo should I use for steering and throttle?
Old 08-10-2007, 10:26 PM   #11
houston's Avatar
Trader Rating: 91 (100%+)
Talking
steering issues on 8 : check your servo saver , it probably backed off and is rubbing the chassis
later , monty
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 08-10-2007, 11:11 PM   #12
air8's Avatar
A servo with 125 oz/in and a speed of at least .15 will work really well for almost any application. These are usually well built with few problems. You get what you pay for with servos. With Ace, JR, Air, Hitec, Futaba servos you can't go wrong. Blue Bird servos are great as well as long as you get the correct servo for the application. I'm using a BB 621MG in my 8 for now. It's 100oz/in at .10. Plenty powerful plus I have lipo/regulator so the servo gets more juice for a bit better performance. Steering has an Ace 1015--200oz/in at .108. It's awesome
air8 is offline   Reply With Quote
Old 08-11-2007, 08:22 AM   #13
R40Victim's Avatar
Put the higher torque servo on the steering, and the quicker one on the throttle. You want to blip your throttle and be smooth with your steering.
R40Victim is offline   Reply With Quote
-@--Losi 8ight-T and MBX5t Prospec- Trade for - Losi 8ight-B and MBX5R--@- Mbx5t-DC R/C Items: For Sale/Trade 45 07-20-2008 03:59 PM
New Painted Never Used Losi 8 Body/Fioroni Team Losi 8ight/8ight-T Adjustable*LOOK** layedbackguy R/C Items: For Sale/Trade 0 05-06-2008 06:57 AM
Losi 8ight Buggy Steering Servo Chuck67 Nitro Off-Road 8 08-21-2007 10:15 PM
Throttle problem with losi 8ight In_Iraq Nitro Off-Road 2 08-10-2007 07:26 PM
