Old 08-08-2007, 11:01 PM   #1
Send a message via AIM to Os_powerd_jato Send a message via MSN to Os_powerd_jato Send a message via Yahoo to Os_powerd_jato
Default CRT.5 Build thread
Here is my CRT.5 so far. Next up is my Engine. Its a Jammin .12
Before you ask.. I was Surprized about how smooth the Diffs are
...........SELLING OUT!!!!!!!!!!!!!!!!!!!!
Os_powerd_jato is offline   Reply With Quote
Old 08-09-2007, 06:52 AM   #2
beta bob's Avatar
Trader Rating: 2 (75%+)
nice pics but why are you missing a shock and the jammin .12 you mentioned did it come with the kit or did you buy it???
Team Terribles---------2009 post of the year
"Cant you read Mopar???He said that he drives a T-max 2.5!!!!"
Spec classes are for communist
beta bob is offline   Reply With Quote
Old 08-09-2007, 08:43 AM   #3
GHETTOTEACHER's Avatar
Did you clear or refill you diffs??? If you are gonna do it, now is the time!
Move your steering linkage to the inside of you servo arm.
BTW, good job on documenting you your build. I document all my builds.
Herolin <---Traded my Airtronics for an Ipad and Laptop...
Soon to be GHETTOPRINCIPAL..
GHETTOTEACHER is offline   Reply With Quote
Old 08-09-2007, 10:24 AM   #4
Originally Posted by GHETTOTEACHER View Post
Did you clear are refill you diffs??? If you are gonna do it, now is the time!
Thanks! Yeah i cleaned them out and Put 2k in the front 7k in the center and 5k in the back.
Well Those were "In build" picture. That shock is now on it, the Jammin.12 i bought. If you buy the other kit (Which i thought i had got) comes with a Picco .12.
Old 08-09-2007, 11:41 AM   #5
-R2-'s Avatar
i think your diffd are tooo thick. I'm using 1k front 2k middle 500 shock oil rear. Your gonna have a handfull when you drive it with that set up. on shocks I use 60wt losi front 40wt losi rear,I also set the shock positions on rear upper row middle,rear lower arm outside, front lower row middle, front lower arm inside. cut your front brake lever so that it does not dig into the fuel tank and put fuel tubing on your brake linkage so your do'nt blow a gear in your servo on throttle.
-R2- is offline   Reply With Quote
Old 08-09-2007, 02:47 PM   #6
lockmouth's Avatar
Trader Rating: 33 (100%+)
3k/ 3k/ 1k is a tested set-up that works awesome. I run it with a BCE chassis an the little fella is hooked
600 Mugen with piston #2
Blue Springs
( 0 Rebound )
2' Toe Out
20' Caster
No Sway Bar
3k Mugen Diff Oil
3k Mugen Diff Oil
500 Mugen with piston #3
Blue Springs
( 0 Rebound )
3' Toe
2' Anti-Squat
Stock Sway Bar
1k Mugen Diff Oil
STS EX .12 Turbo
JP-5 Pipe
Byrons 30%
Odonnell 77T
M2C Four Shoe Clutch ( Med. Regular Shoes + .90 Springs)
BCE PJR 5 Chassis
MARIO KNOX
HOTBODIES RACING / FULL THROTTLE RACEWAY (OWNER / OPERATOR)
lockmouth is offline   Reply With Quote
Old 08-09-2007, 10:20 PM   #7
nitroexpress's Avatar
Just for the record. I was running on a small track. So I changed the pinion to a 12T and tried running 2/2/1. Little bugger wanted to wheelie from low speed.
nitroexpress is offline   Reply With Quote
Old 08-10-2007, 02:22 PM   #8
Update:
Engine will be here FOR SURE tomorrow. This was my first paint job i have ever done so dont make to much fun of it..
Old 08-12-2007, 01:46 PM   #9
Here is the engine..
Old 08-12-2007, 06:27 PM   #10
luisv's Avatar
Looks great... do yourself a favor and try to clean up the hole in the body for the heatsink. You might also want to invest in some aluminum tape or nomex type tape. Place it around the opening and where the body meets the heatsink to preserve the paint job. I've been using this tape on all of my electric and nitro cars and it works great.
LOSA9343 Heat Shield Nomex Tape
http://www.losipartshouse.com/servle...d-Nomex/Detail
8ight TE 1.0 | MM2 2200kV | Spektrum
8ight TE 3.0 | MM2 2200kV | Savox | Spektrum
Ten-SCTE 2.0 | HW Pro SCT | Spektrum
luisv is offline   Reply With Quote
Old 08-13-2007, 09:23 AM   #11
beta bob's Avatar
if you take off about a quarter of an inch around the heatsink you should be ok and also if you take out the left door window and the left side of the windshield (were the fuel tank is so your not confused) so you can fuel up faster and so the engine and air filter gets a lot of cool air.
Old 08-14-2007, 03:25 PM   #12
You have a nice build and a very nice motor. Now, like beta bob said cut more air holes on your body to give that motor some more air! I cut out a square out of the front window, the left side window out entirely and cut a hole on the side where the head rests next too.
My big Jammin has the same cuts. It's the same as Beta bob's suggestions. Your almost there!!!
Old 08-14-2007, 04:00 PM   #13
beta bob's Avatar
I never thought about there thanks.
O yeah were the heatsink sticks out smooth out that hole with a dremel or one flip and you will have a big crack in the body.
Offroad Track Build Thread racenut123 Electric Off-Road 41 01-24-2015 02:38 AM
RADICAL-Z8 Thread now has BUILD PICTURES> ericsp2 Nitro Off-Road 0 09-18-2007 12:06 PM
Build it yourself. TDyk Electric Off-Road 9 01-12-2007 09:18 PM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 08:37 PM
