Old 08-08-2007, 07:09 AM   #1
Default Where is the slipper on a 1/8th buggy?
Like the title says i need to find the slipper on my buggy so i can tighten it.. Where is it?
Thanks Andrew
andrewtexas123 is offline   Reply With Quote
Old 08-08-2007, 07:24 AM   #2
Sorry
Zazuk is offline   Reply With Quote
Old 08-08-2007, 07:25 AM   #3
Old 08-08-2007, 07:26 AM   #4
How do you know that you need to tighten the slipper?
I have a pair of slippers but they go on my feet.
What kind of Buggy do you have and what is the problem you are having, this will help others help you if you give more info.
EDIT:
Sorry for the multi post, was getting a database error when I press the post button
Old 08-08-2007, 09:39 AM   #5
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
There is no slipper on an 1/8 nitro buggy.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 08-08-2007, 10:30 AM   #6
gacjr0's Avatar
Trader Rating: 15 (100%+)
One of many things that can slip is your clutch. Attached to the engine. Most are not so adjustable that you can just tighten it. If it has been slipping you likely need new shoes/springs, also a good time to replace clutch bell bearings since they go bad fast.
gacjr0 is offline   Reply With Quote
Old 08-08-2007, 12:32 PM   #7
MADMAN23's Avatar
Trader Rating: 27 (97%+)
Send a message via AIM to MADMAN23
there no slipper on a 1/8th buggy.. and i had almost every brand out there a time lol..
catch me if you can....
WWW.RCFANATICS.NET
http://rcraracing.com/sitebuilder/images/FORUM/index.php
C&D R/C RACEWAY
Team Wicked Racing
MADMAN23 is offline   Reply With Quote
Old 08-08-2007, 12:52 PM   #8
-R2-'s Avatar
ditto on that answer, I have'nt seen a slipper on any 1/8th buggy.
-R2- is offline   Reply With Quote
Old 08-08-2007, 03:51 PM   #9
Be easy on me this is my first buggy.. I have a Ofna lx.. The top speed is like 15 mph so i think something is sliping..
Andrew
Old 08-08-2007, 04:01 PM   #10
Your flywheel may be loose or the collet could be worn, your clutch shoes may be in need of maintenance/ replacing, or maybe some teeth are missing on some gears somewhere.
Old 08-08-2007, 04:12 PM   #11
How do i tighten my fly wheel?
Thanks!
Old 08-08-2007, 05:55 PM   #12
KForce's Avatar
Trader Rating: 2 (75%+)
remove motor from car
remove screw holding clutch bell
remove clutch bell / bearings / shims (remember the shims order)
remove clutch shoes
hold flywheel with some channel locks and tighten the nut on the flywheel.
re-assemble in reverse order. make sure you have you clutch shoes going the proper way. looking at the flywheel the tails should be on the right of the pin.
Team TQ Fuel
OS Speed Engines
Futaba
Panther Tires
CRCRC Raceway Webmaster
FullThrottle Raceway Webmaster
KForce is offline   Reply With Quote
Old 08-12-2007, 10:00 AM   #13
Send a message via AIM to trashedmaxx
I wouldn't mind seeing some kind of slipper for these brushless 8th scales.
trashedmaxx is offline   Reply With Quote
Kyosho ZX5 Slipper Shaft & Slipper Plates (CHEAP!) thecrow2k R/C Items: For Sale/Trade 0 06-02-2008 08:10 AM
Slipper in a tc? why not? streetracer745 Electric On-Road 8 03-12-2008 07:46 PM
Where is the slipper on a 1/8th buggy? andrewtexas123 Nitro Off-Road 11 08-09-2007 07:36 AM
slipper clutch new2this Electric Off-Road 3 05-30-2007 05:00 PM
Please help dont know how to set my slipper... Jhyten Electric Off-Road 4 02-15-2006 09:57 PM
