Old 08-06-2007, 06:08 AM   #1
Send a message via AIM to GroffBall
Default Ever Snap a Crank? Pics inside
I won't release what manufacturer made this yet as I don't want to tarnish a good company provided they take care of this, but has anybody ever experienced this or seen this before with any motor. The internals of the motor are fine otherwise this motor has just around a gallon on it.
GroffBall is offline   Reply With Quote
Old 08-06-2007, 06:15 AM   #2
Trader Rating: 38 (100%+)
Is that an RB crank? Looks like it, the red putty, weighted crank flywheel....
Was that the only thing that broke? Con-Rod? Anything else?
If not, then my first thought is probably a structural weakness in that particular piece, cause I've not seen a "modern" crank break like that...
JQ Products "Le Car" - 3 of them. Primary, back-up, and spares car
Bunch of "classic" Schumachers
Tamiya - Leopard 2A6, Tiger 1
HPI - Blitz
bushyar15 is offline   Reply With Quote
Old 08-06-2007, 06:27 AM   #3
I'm not going to say what kind of motor it is yet I want to give the company a chance to explain what happened and take care of it, but no there was not a thing wrong with it otherwise. I'm sure I could clean it up and throw a new crank in it and go to town, but honestly if I have to BUY a new crank I'll just throw it in the box and write it off.
Old 08-06-2007, 07:00 AM   #4
Timmahh's Avatar
Send a message via Yahoo to Timmahh
yes, 3rd or 4th tank in on a Hot Bodies Lightning 26. ran great for the first few tanks. i let it cool off, while i had some lunch. and 1/2 way thru the next tank it just stalled. no compression when i tired to start, so figured i blew a conrod or got it too lean ( wasnt sure how that could be ) and burnt the pistion up. but i was shocked when i opened the motor to find a 2 piece crank shaft.
Hot Bodies was EXCellent and warrenty replaced the whole motor!!!
T
Check my F/S ads I am posting up, Liquidating my bajas and SCBs in part outs.
http://www.rctech.net/forum/r-c-items-sale-trade/562290-wreckluse-crawler-chassis-other-scaler-parts.html http://www.rctech.net/forum/r-c-items-sale-trade/562534-hpi-baja-items-f-s-motor-rtr-tranny-full-wheel-sets-servos-more.html
Timmahh is offline   Reply With Quote
Old 08-06-2007, 07:34 AM   #5
associatedguy's Avatar
I saw some guy at the track do that to a Picco P7R
associatedguy is offline   Reply With Quote
Old 08-06-2007, 07:42 AM   #6
V for Victory's Avatar
Send a message via AIM to V for Victory
all i can say is
V for Victory is offline   Reply With Quote
Old 08-06-2007, 07:45 AM   #7
Originally Posted by V for Victory View Post
all i can say is
Glad you find it funny... I sure don't thats a $325 paper weight now
Old 08-06-2007, 08:18 AM   #8
RBMike's Avatar
I have seen this once but there was a rock stuck in the intake port. The guy had lost his air filter & a rock the size of a pincil eraser had jammed between the crank intake port & the bottom of the hole the carb fits in. On yours I would guess the metal they machined the crank out of had a flaw that went undetected. Very unussual no matter what the cause.
RBMike is offline   Reply With Quote
Old 08-06-2007, 11:21 AM   #9
MADMAN23's Avatar
Trader Rating: 27 (97%+)
Send a message via AIM to MADMAN23
do you know what temp it was runing at?
catch me if you can....
WWW.RCFANATICS.NET
http://rcraracing.com/sitebuilder/images/FORUM/index.php
C&D R/C RACEWAY
Team Wicked Racing
MADMAN23 is offline   Reply With Quote
Old 08-06-2007, 12:01 PM   #10
i can tell you exaclty what motor that is out of byt the 1 counter balancing wieght and the red putty and should i be correct i know that they will take very good care of you and do the right thing its the reason why i run their equipment
leon mcintosh
punkracer24 is offline   Reply With Quote
Old 08-06-2007, 04:35 PM   #11
wrightcs77's Avatar
Trader Rating: 517 (100%+)
Just curious, any other marks in the case? Was the crank rubbing at all on the backplate or ???? Just wondering if the flywheel and collet where not all the way snug, allowing the crank to move fore and aft in the case. Just a thought.
Thanks,
Casey
wrightcs77 is offline   Reply With Quote
Old 08-06-2007, 05:49 PM   #12
schmelme's Avatar
I did the same thing to a modded p5 i have seen this on a few others mostly on drilled crank motors sometimes the casting just cant take the reduction of material.
schmelme is offline   Reply With Quote
Old 08-06-2007, 05:54 PM   #13
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
My money's on a Plus series NR
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 08-06-2007, 06:02 PM   #14
KK-racing's Avatar
Seen 2 O.S. V01 had that happended, as well as to mine too previously. And they all break at exactly the same area as yours, at the rear end of the intake opening of the crankshaft.
Ours were written-off as they have been through many gallons & the main bearing was also well worn(O.S. has a bad reputation for that with it's standard bearing).
KK-racing is offline   Reply With Quote
Old 08-06-2007, 06:29 PM   #15
matts6887's Avatar
Send a message via AIM to matts6887 Send a message via MSN to matts6887
All I can say to this one is OUCH!!! That had to hurt to see that happen to a otherwise perfectly good engine. Well whatever company this is from, I would certainly hope that they would take care of it; and im Sure they will, especially if the company is along the lines of the RB and/or Novarossi calibur.
matts6887 is offline   Reply With Quote
O.S 28xz Snapped crank (with pics) herb99 Nitro Off-Road 22 07-12-2008 04:03 AM
TC5 PARTS LOT, LOOK INSIDE! PICS knoxvillerocco R/C Items: For Sale/Trade 0 01-03-2008 06:06 AM
STS 30 modded crank pics Maximo Onroad Nitro Engine Zone 20 01-18-2007 06:26 AM
DTX .21 $50! Pics inside! shadmaster4 R/C Items: For Sale/Trade 1 02-28-2005 01:27 PM
All of this for $75.00 Shipped. Must go! *PICS INSIDE* ceb27 Other Items: For Sale/Trade or Wanted to Buy 4 02-14-2005 06:20 PM
