Old 08-05-2007, 10:35 PM   #1
MadRacer's Avatar
Trader Rating: 33 (100%+)
Default After run oil
Does any one know what oil is this.
I herd automatic transmissiom oil is the same.
If that is the case the makers are making a huge profit
MadRacer is offline   Reply With Quote
Old 08-06-2007, 05:11 AM   #2
hey mark i got a JP RACING engine care kit from traxside $35 you 2 bottles of air filter oil,1 bottle of engine polish and 1 bottle of after run oil( not tranny fluid)you polish up your button head,piston,sleve,rod and crank with cotton cloth and cotton tips then rub your after run oil over the parts just the once to get the blackened stains off, then after run as nomal after meets as per usual(just 6 to 8 drops bump it on your box)then bobs your uncle one very healthy engine,the v-spec will luv ya for it
www.pinehillsdirtracing.com...MUGEN MBX7R with TEKNO V4 conversion.....TEKIN RX8 GEN2 esc HOBBYWING motor 2200kv.....
pitdog is offline   Reply With Quote
Old 08-06-2007, 05:23 AM   #3
sir miles's Avatar
Trader Rating: 23 (100%+)
For me I use a 2T oil (the one that they use on 2 stroke motorcycles) I use it as a after run oil and foam filter oil at the same time. Does the job and saves me a lot of money.
gaining momentum!
sir miles is offline   Reply With Quote
Old 08-06-2007, 05:49 AM   #4
air8's Avatar
Some of the after run oil is Marvel Mystery oil. That's what the hobbico stuff is anyway. Works really well, and since hobbico sells it by the little bottle, I can keep refilling it from the quart of Marvel I bought at the store. Plus, it has a distinct smell. LOL. That's what made me think it was Marvel Mystery oil.
air8 is offline   Reply With Quote
Old 08-06-2007, 07:50 AM   #5
MADMAN23's Avatar
Trader Rating: 27 (97%+)
Send a message via AIM to MADMAN23
for me i use wd-40
catch me if you can....
WWW.RCFANATICS.NET
http://rcraracing.com/sitebuilder/images/FORUM/index.php
C&D R/C RACEWAY
Team Wicked Racing
MADMAN23 is offline   Reply With Quote
Old 08-07-2007, 12:10 AM   #6
MadRacer's Avatar
I have herd that WD 40 is good . A read it in the Team losi manaul of my xxxnt rtr.
Thanks just curious thats all. I do after run all my engines on the bump box.
Old 08-07-2007, 03:33 AM   #7
I have heard that you should stay away from WD-40, as it contains petroleum which makes o-rings permeable or whatever (it makes o-rings not work anymore, causing air leaks etc.).
I use PowerSave racing after-run oil.
D_o_S is offline   Reply With Quote
Old 08-08-2007, 12:35 PM   #8
MADMAN23's Avatar
i never had any problem's with my motor...
WWW.RCFANATICS.NET
C&D R/C RACEWAY
Team Wicked Racing
Old 08-08-2007, 12:47 PM   #9
how often do u guys use it, after every ride, week...?
jmdv is offline   Reply With Quote
Old 08-08-2007, 09:41 PM   #10
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
i only use it when im gonna store for a month or more....if you use a good fuel like byrons you doent have much to worry about...
Jason Halvorson is offline   Reply With Quote
Old 08-09-2007, 06:32 AM   #11
air8's Avatar
Byrons 30% and MMO after sitting for two weeks and it looks like they won't be run for a few more weeks. Or when putting an engine back together after and inspection, I put a little MMO on the p/s, crank, bearing, carb barrel (All the moving parts).
Old 08-09-2007, 04:45 PM   #12
MADMAN23's Avatar
i use byron 20% and i put oil in the motor everytime i done for the day...
WWW.RCFANATICS.NET
C&D R/C RACEWAY
Team Wicked Racing
