Kyosho ST-RR
#4397
I'd just like for K to come out with an updated truggy that consisted of ditching the eclips, plastic hinge plates, the pop on front and rear chassis brases,the cast steering knuckles, plastic c-hubs, plastic rear hubs and making they're own weight forward chassis. I don't think these changes are too much to ask for or would be hard for them to do and you'd think it would keep it in the same ball park as the current price. Maybe not though. That new X-ray truggy does look nice though
#4398
All they would have to do would be to redesign the diff cases to accept tki4 mounting hardware, then modify the geomtry of the suspention plates to suit the truggy.
A weight forward chassis would require a new chassis, new front and rear centre driveshafts.
New knuckles would be just put the tki knuckles instead of the cast ones, maybe modify the arm a little to make it fit.
Im not an engineer or manufacturer, but nothing there sounds difficult in the slightest, or expensive.
#4401
Broke the stupid Front C Hub again at a club day. So I have decided to replace it with the MP9 recommendation in the Wiki above.
My question is: Can I used the stock Evo 2 spindle? Its the machined alloy one.
#4403
Strr
If anyone needs anything parts wise pm me I've got a ton of stuff for these truggys I just wasn't going to post a ton of lil parts In the for sale section so just pm me what you need and a number or email and I'll let you know if I have it or not if I do I'll send pics I've got tons of king headz and m2c pieces extra aluminum not the cast ones but I've got those to steering knuckles I'm going to try and make a lil post in forsale section but I figured in the mean time if someone needed some help if I can I will god knows I've had some help from some amazing guys on here
#4404
C hubs
I'm working on building a set of aluminum strr specific c hubs I got my prototype set that I made on a 3D printer I just need to buy the aluminum and get some spare time on a cnc machine I want to buy a small cnc but right now money just not good enough for that I'm lucky I have access to a milling machine and a few other cool tools so once I successfully make a set I'll let you guys know and if I get enough guys wanting them I'll make a few sets
#4405
I've just picked up an strr this is my 1st truggy and still kind of new to nitro rc cars
What's the story on getting replacement parts on this car?
Can you use parts from say a mugen if parts are in short supply
I'll have a good read over the whole thread when I get time but it's a good size thread
#4407
#4408
Absolutely loving this M2C EVO. What a difference.
#4409
Honestly the biggest issue i found with mine is the weight. Ready to run easily 500 gram heavier than say a tekno truck. I know because i ran them back to back. The weight takes its toll on accelaration, braking, cornering, engines, clutches and tires and in a competition where 0.5 of a second a lap can mean difference between podium or 11th, i found it too heavy. I never had a problem with its handling/turning.
#4410
Ive raced this truggy and several others over the past 15 years. If you compare it to a mugen or tekno its garbage....huge disappointment IMO. Kyosho should pull it off the market.
