Old 07-28-2007, 08:16 PM   #1
Send a message via MSN to rhymster
Default servo problems with my 8ight-t
today i took my 8ight-t to the track went through 1 normal traxxas servo and a metal gear spektrum servo. i finally went to the hobby store and bought a ti gear hitec does anyone know why this keeps happining i have my endpoints set right. so what gives i also have the oring'[s under the back reciever battery tray
rhymster is offline   Reply With Quote
Old 07-28-2007, 08:26 PM   #2
pablo101's Avatar
Trader Rating: 50 (100%+)
What servo? steering or throttle brake?
pablo101 is offline   Reply With Quote
Old 07-28-2007, 08:28 PM   #3
Trader Rating: 96 (100%+)
Servo saver set too tight? I stripped out a Futaba gear last weekend so I just loosened it up a few turns. I know the manual says to tighten all the way then back off 1.5 turns , but I think that is still too tight. Grease the saver too as dirt will work it's way in there and jam everything up.
K.Copeland is offline   Reply With Quote
Old 07-28-2007, 08:45 PM   #4
xlgraphicspro's Avatar
I have my servo endpoints adjusted right. I also have my throw set to 80% instead of 100% Plenty to stear my car properly. I had problems with my car being overly responsive at 100%. 80% will work well, and that way your servo is never torquing from left to right at maximum throw.
Same for the Throttle, I assume that's the one you blew. adjust your end points so it's one tick below what you think it should be. I don't use O rings under my tray, and when I go from full throttle to full brake, my radio tray doesn't move at all.
I'm still using the same servo's I put in the car the day I built it. I think if properly done, you shouldn't never have a problem.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 07-28-2007, 08:46 PM   #5
the throttle servo i have the hitec thats puts out 333oz in torque so i better not have a problem with that one. i dont know what is up with the throttle tho
Old 07-28-2007, 08:47 PM   #6
take a look at this picture as far as throttle linkage setup goes!
Old 07-28-2007, 08:53 PM   #7
thats how my linkage looks i have my endpoints on the throttle servo so the radio tray doesnt move and the brakes are still strong and it just barely almost pull the carb slide all the way open about 1 mm so maybe this new hitec ti gear i put in the throttle will not blow out. and how do u tighten the servo saver for the steering mine is way to loose after a full day of practice.
Old 07-28-2007, 09:01 PM   #8
you can tighten your servo saver by using plyers, or do what I did and adjust it properly by taking the steering rack out and using a small dab of blue lock tight on the threads. Mine doesn't budge a bit.
and actually, the photo I posted was of some one elses set up for the throttle linkage. Mine is more angled to prevent the carb from kinking up a bit. that may be what's killing peoples servos. Binding slide carbs that aren't aligned straight.
He's mine!
Old 07-28-2007, 09:08 PM   #9
ok thanks but what am i spose to tighten on the servo saver to tighten it the wife thru my owners manual away???
Old 07-28-2007, 09:38 PM   #10
it's a blue circular nut on the steering bell crank on the right side of the car!
Old 07-28-2007, 09:57 PM   #11
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
thats not a very good throttle servo....its more like a truggy steering servo...a lil slow for throttle, but if that works for you go for it....
Jason Halvorson is offline   Reply With Quote
Old 07-28-2007, 10:04 PM   #12
no i have the hitec hs-5955tg on my steering and the hitec hsc5996tg on the throttle now. the steering is the one that has 333.oz on torque and im not sure what the throttle is but its plenty fast
Old 07-28-2007, 10:18 PM   #13
veejay323's Avatar
Send a message via AIM to veejay323
from what i hear, the servos sit on the chassis and when landing jumps or maybe just from vibration it can cause the circuit board inside to mess up.
solution would be something like the xtreme carbon servo support tray which raises the servos off the chassis.
http://www.xtremercracing.com/8IGHT.cfm
I just got an 8T but haven't run it yet
veejay323 is offline   Reply With Quote
Old 07-28-2007, 10:24 PM   #14
air8's Avatar
I just used 4 washers to raise my servo off the chassis.
air8 is offline   Reply With Quote
Old 07-29-2007, 02:49 AM   #15
Trader Rating: 38 (100%+)
Yeah, I had the same problem with my 8ight. Damn thing ate servos even when I followed the instructions an tips from others just like yourself.
I adjusted end-points, raised the servo, used the o-rings, used the rubber grommets that comes with the servos, checked and re-checked the servo saver....
Getting the Hitec seemed to work. But one day I just get fed up with it and switched to Mugen.....
JQ Products "Le Car" - 3 of them. Primary, back-up, and spares car
Bunch of "classic" Schumachers
Tamiya - Leopard 2A6, Tiger 1
HPI - Blitz
bushyar15 is offline   Reply With Quote
Losi 8ight buggy and Truggy Clutch problems layedbackguy Nitro Off-Road 17 01-17-2008 02:36 PM
Servo Problems! Renuco612 Electric On-Road 16 09-24-2007 08:21 PM
Having problems starting my O.S Vpec in my Losi 8ight Please help NJA82 Nitro Off-Road 12 09-20-2007 04:18 AM
8ight 8ight-T parts NIP including alum servo saver top Jwag R/C Items: For Sale/Trade 5 08-23-2007 10:58 PM
clutch problems with 8ight-t please help rhymster Nitro Off-Road 24 08-17-2007 03:26 PM
