Old 07-24-2007, 06:22 PM   #1
mad_about_losi's Avatar
Trader Rating: 31 (100%+)
Send a message via Yahoo to mad_about_losi
Default Cleaning Nitro motors?????
I just picked up a motor from someone for nothing, (O.S. Max). It has after run oil in it but the outside of motor has red clay dirt all over it and I'm curious to find out the best way to clean the entire motor. Can I soak the motor in something to help loosen the dirt off it?
mad_about_losi is offline   Reply With Quote
Old 07-24-2007, 06:34 PM   #2
I put those rubber caps on the carb intake and exhaust port. Then you can spray it down with engine degreaser, if it's really bad, and then blast/scrub it off with hot water. If not too bad, hot soapy water and a good brushing. Make sure to dry it thoroughly afterwards and you should be just fine. Maybe relube the bearing.
satoch is offline   Reply With Quote
Old 07-24-2007, 06:40 PM   #3
thanks
Old 07-24-2007, 07:56 PM   #4
I have good luck with denatured alcohol. I use a stiff brissled brush and dip it in the alcohol and go to cleaning, then I spray it down with simple green and clean it again. Seems to do good for me.
tubehead is offline   Reply With Quote
Old 07-24-2007, 08:27 PM   #5
RevMaxx's Avatar
Send a message via MSN to RevMaxx
denatured alcohol cleans fine... but point them away from bearings...
RevMaxx is offline   Reply With Quote
Old 07-24-2007, 08:35 PM   #6
Thanks for all the help
Old 07-27-2007, 08:06 PM   #7
paint ball matt's Avatar
also what works good is nitro blast they probibly have it at a hobbie store i use it a lot the only it takes everything off just wipe the spot after you sprayed it
paint ball matt is offline   Reply With Quote
Old 07-28-2007, 05:23 AM   #8
joe of loath's Avatar
i use tis stuff on my bike called 'muc-off' and you spray it on, leave it 10mins and wash off, and it takes the dirt with it. its bright pink, and looks a bit weird. i don't know if you have it in the us but it shoudl work well.
joe of loath is offline   Reply With Quote
Old 07-28-2007, 07:08 PM   #9
pablo101's Avatar
Trader Rating: 50 (100%+)
I usually pull the engine leaving the manifold and pipe on, pull off the clutch and flywheel, air filter assembly and cap the carburetor. Then shoot it with WD40 and let it soften the clay, use an old toothbrush to break down the heaviest build up. Then rinse it off with WD40 until itís shiny as new. The WD40 will not damage the plastic or composite components nor will it damage the bearings. Wipe down the engine using paper towels or blue shop towels. Reinstall the carburetor filter assembly. If you have excess build up of dirt junk around the exhaust port or carburetor you have a leak and will need new exhaust manifold gasket or carburetor O-rings or fuel banjo fitting needs replacement.
pablo101 is offline   Reply With Quote
Old 07-29-2007, 03:52 PM   #10
Well I've got it clean and put all back together and now I can't get it to start, it has an OS Max CVR motor. It turns over but that seems to be about it. I'm not sure if I have the carb set right or not. Does anyone know what the basic start point is for this motor?
Cleaning Brushless Motors Drift_Buggy Electric On-Road 20 01-28-2007 06:14 AM
Cleaning up a little, Power Supply, Motors, dischargers Fred Perkins R/C Items: For Sale/Trade 6 02-26-2006 05:07 PM
Cleaning House Motors and Batts JJ187RC R/C Items: For Sale/Trade 4 08-31-2005 03:17 PM
Pre Spring cleaning motors dodgeguy R/C Items: For Sale/Trade 4 03-05-2005 07:05 PM
.: Cleaning Out :. xxx-s, batts, esc, motors, bodies, + more Altrodesigns R/C Items: For Sale/Trade 10 07-07-2004 07:25 PM
