Run Time for Werks motor
How long can I expect the Werks 21 B3-pro last on a fuel of tank?
Till the tank is empty
Joking, not sure on the pro, I ran the team line b3 and got atound 8 1/2 minutes, now I am running the b7 Pro Got to get a time run in this weekend to see how long it will last
Man, you guys must be running RICH! I get 10 minutes with a B7 and the B3 is supposed to be better on fuel. It all depends on pipe choice, track type and driver type (throttle control). IF you're getting less than 7 minutes then your tune is pretty far off.
With the b7 Pro this weekend and the JP3 pipe I was getting a little over 7 minutes, first weekend on the motor, so it should get a little better after it frees up some more. Temps around 235 with plenty of get up and go
