Old 07-18-2007, 07:27 PM   #1
Swaybarz's Avatar
Default What motor
I'm looking for a .21 for an 1/8 scale buggy, I'm looking to keep the price under $300.
The main thing I want is fuel milage around 7 1/2 min. I'm not new so power dosn't scare me but gas milage is more important.
I've been looking around on a-main hobbies and found a couple of motors that I would like some opinions about.
(all standard plug)
go tech 5 port
Hot moded Novarossi N21B 2001 BF 3 port
Novarossi RX21P5XS 5 port
open to any suggestions
p.s. is there a difference bwt standard & turbo plugs?
Byron Fuels***Proline Racing***Castle Creations***Rcamerica***Xray***Hudy
Lutz R/C***247 Designworks
Swaybarz is offline   Reply With Quote
Old 07-18-2007, 07:39 PM   #2
Well I will comment on my two current motors. I have a P5XS and a Ninja, The p5 has to be tuned perfectly to compete with the ninja when the Ninja is very easy to tune and you will hardly notice it when it is a bad tune, even when the tune is maybe half a turn off it still runs fine, and the P5XS has the be tuned perfectly or it wont run well. So I would recomend the Ninja over the P5 any day. Do you not know what a turbo plug is at all or do you want to know the difference? anyways the difference is that the Turbo seals from a taper and creates a better seal than from the brass washers standard plugs use.
Nitro syco is offline   Reply With Quote
Old 07-18-2007, 07:45 PM   #3
Here is a turbo plug, it seals better and at the bottom and makes a more agressive engine.
and here is a standard plug for you to compare it to.
Old 07-18-2007, 07:49 PM   #4
prphze's Avatar
I like my v-spec. I run on a indoor track and I can go from top of tank to completely empty in 10 min's and about 20 secs. I also have a Novarossi Plus 7bt which will go about 9 min's but is very picky about the tune. Hope this helps.
prphze is offline   Reply With Quote
Old 07-18-2007, 08:05 PM   #5
Scottmisfits's Avatar
I am currently running a Jammin 21 and I am loving it. I also Have a V-Spec that I have yet to run but I bought it to try it out because of what I have read about them.
Scottmisfits is offline   Reply With Quote
Old 07-18-2007, 10:04 PM   #6
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
ive been running two .21 race engines, a novarossi P5X for short tracks and a werks B7PRO for long....i love them both...the P5X is very smooth and liner with great fuel run times, and the werks is a mega top end rocket with massive bottom end punch...i got each for under $300 usd....
Jason Halvorson is offline   Reply With Quote
Old 07-18-2007, 11:40 PM   #7
I forgot to add that my P5XS with ofna 086 pipe gets not nearly as much run time as I would expect from a high end motor, I dont have any times but comparing it to my Ninja with a Dynamite 053 pipe the P5 dosnt come close. I think my Ninja gets like around 9-10 min run time and the P5 probably gets like 7 minutes and not as much run time. By the way I am comparing a 3 gallon old P5XS to a 8 gallon old Ninja B01A. I am way happier with my ninja.
Old 07-19-2007, 10:45 AM   #8
Swaybarz's Avatar
like i said i am not new i know what a turbo and standard plugs are.(just wondering if there was a perforance difference)
Also any opinions on gotech or the novarossi 3 port or are there any good RB motor close to my price range.
Old 07-19-2007, 11:27 AM   #9
CRASH's Avatar
Trader Rating: 26 (100%+)
OS V-Spec and OS 2060 pipe combo, is around 10 minutes in race condition. Hard to beat the fuel economy. Just gives up a little on the low end.
Later,
CRASH is offline   Reply With Quote
Old 07-19-2007, 03:31 PM   #10
xlgraphicspro's Avatar
O.S. V-Spec. this is the most efficient motor ever made. Why? because it produces alot more power than most engines out there, and it's only a 3 port engine. I've had 5 port and 7 port engines that don't even come close to PRODUCING what the V-spec can. plus O.S makes one of the best carbs out there. this thing holds a tune better than any I've seen. It'LL RUN EVEN WITH A CRAPPY TUNE ON IT!
Plus, alot of sponsored drivers use it for the same reasons I stated above! Best part is that It's only $260, and you could even get it cheaper than that on ebay if you watch for it.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 07-19-2007, 03:35 PM   #11
Oh yeah, the 5 port engine I owned was a Ninja. Also a great engine, but not as efficient as the O.S. Plus Run time was shorter and had about the same power.
Old 07-19-2007, 03:54 PM   #12
RBMike's Avatar
Run time is HUGELY impacted by your pipe choice, keep that in mind when making your decision.
RBMike is offline   Reply With Quote
Old 07-19-2007, 04:19 PM   #13
MADMAN23's Avatar
Trader Rating: 27 (97%+)
Send a message via AIM to MADMAN23
i say the hyper 21
MADMAN23 is offline   Reply With Quote
Old 07-19-2007, 05:16 PM   #14
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
What about werks b3 or b7
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-19-2007, 05:31 PM   #15
Black's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to Black
You know I would check www.bmainhobbies.com for motor specials. I am running a RBWS7II with a JP-3 pipe and I get about 10:15 a tank. Check out RB, crazy good fuel mileage.
Black is offline   Reply With Quote
FS: MTRONIKS GENESIS TRUCK B/L ESC, FEIGAO 380C-6L MOTOR & REEDY NEO-ONE 4 STAR MOTOR davidrrr R/C Items: For Sale/Trade 5 08-16-2008 02:32 PM
FS/FT NIB LRP 5.5T Brushless motor/ Castle CM-2080 motor Trade for Newer FUTABA S9451 ffpm46 R/C Items: For Sale/Trade 13 03-31-2008 01:17 PM
Modify your stock motor, mod motor, any motor! TRF-Powered Electric On-Road 10 03-15-2007 04:52 PM
Trinity Motor Checker “Monster Horsepower Machine” Motor Performance Monitor CRiXman R/C Items: For Sale/Trade 5 01-25-2007 02:36 PM
Stock motor blowout!!! NEW Hurricane bushing reamer / 767 brushes / motor case LOW$ evostyle R/C Items: For Sale/Trade 0 11-27-2006 10:22 PM
