Old 07-18-2007, 09:42 AM   #16
Black's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to Black
www.nitrohouse.com has them in stock
Black is offline   Reply With Quote
Old 07-18-2007, 10:15 AM   #17
xlgraphicspro's Avatar
Originally Posted by rhymster View Post
well i cant find the ofna truggy box anywhere that isnt on backorder. how did u get the assoiciated one to work?
You see the AE starter box has 2 slots one going from front to back for gas truck, and touring car. and another slot going from left to right. you have to unscrew the screws holding the motor mounts and flywheel mount. turn the whole assembly mount sideways and screw it back in. your gonna have to take the flywheel mount, and unscrew the cover over the bearing and pop the bearing out, switch sides pop the bearing back in and screw the bearing cover on the opposite side that it was on.
You have to take the flywheel off before you screw the motor mount down. Then you slide the center shaft in the fly wheel out a bit, wrap the belt around the pulley, slide the flywheel into place, push the center shaft into the appropriate hole on the motor mount. put the flywheel mount on the other side of the shaft and screw it down to the box.
There are instructions with the box when you buy it. it should tell you the same thing.
I use it on my 8ight and I haven't had a problem yet. Use a Gel cell battery also, much more reliable and lasts 10 times longer.
I hope that wasn't too confusing! So don't get rid of it because it works just fine!!!
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 07-18-2007, 10:18 AM   #18
also, after I assembled my associated box properly, I took an exacto knife and beveled the edges of the rubber flywheel wheel while it was running. That's so it doesn't rub on the chassis. looks professional like a lathe trimmed it down!
Old 07-18-2007, 12:10 PM   #19
Send a message via MSN to rhymster
i think i just take it back and wait for the losi starter box it comes out today so i can prolly get it by next week. thbaKS
rhymster is offline   Reply With Quote
Old 07-18-2007, 01:09 PM   #20
OK. The problem with a dedicated box is that it will only work well with one (or two in this case) vehicles.
My 1/10 OFNA box has been used on five different chassis, my 1/8 OFNA box has been used on four. All I had to do was position the pegs, not a very difficult task to do.
I did get another box for my truggy because I race buggy and truggy, however, I got a Himoto box for $30 which is very similar to the AE box and is very light (even with a 12V).
AreCee is offline   Reply With Quote
Old 07-18-2007, 04:44 PM   #21
g26er is offline   Reply With Quote
Old 07-18-2007, 05:09 PM   #22
TGA78's Avatar
http://www.ofna.com/start-box.html
The one I use is part# 10244 (bottom of the page). I assume that is the blue 1/8 box everyone is talking about.
Originally Posted by g26er View Post
Can anyone here point me to the thread that has pictures of the blue ofna dual motor setup fot the 8T? I can't find it.
TGA78 is offline   Reply With Quote
Old 07-18-2007, 05:15 PM   #23
Team Losi 8ight or 8ight-T Starter Box--2 weeks old! pncstod R/C Items: For Sale/Trade 3 05-10-2008 09:10 PM
***** TEAM LOSI STARTER BOX FOR BUGGY AND TRUGGY 8ight 8T 8ight-T ***** mach51 R/C Items: For Sale/Trade 2 11-27-2007 11:43 AM
**FS: LOSI 8ight/8ight-T Starter box - Brand new and cheap! jarel R/C Items: For Sale/Trade 6 11-01-2007 11:32 PM
New Products from losi! (Mini Lst2/8ighT-8ighT-T starter box) losi09 Electric Off-Road 0 03-15-2007 03:27 PM
How do starter boxes work? Do they work with Shaft Start engines? Ofna_Driver_777 Electric Off-Road 7 02-25-2007 06:51 PM
