Old 07-15-2007, 08:09 AM   #1
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Default Idling problem
Hey everyone.
Had a pretty good day of driving my CEN Matrix and OS .21VG combo. The only issue I am having now is this:
When getting it going it would fire up fine with just alittle throttle given, but seemed to not want to hold its idle. when adjusting the idle screw so it would keep an idle, it would at times right after coming off of some high speed passes would drop down immediately. This however was not consistent.
Could it be I have an air leak somewhere? What are some of the methods you guys go about diagnosing the problem.
Other than that, the vehicle ran great, engine did quite well too.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 07-15-2007, 12:00 PM   #2
Tech Legend
Cain's Avatar
Anyone?
Old 07-15-2007, 07:30 PM   #3
David Wall's Avatar
With your throttle in the brake position, your carb should be open 1mm. Once you get your idle screw set for this opening, than you will set youe low speed needle to adjust your idle, not the actual idle screw. If the the idle is too low, lean the low speed, if it is too fast, richenthe low speed needle.
Hope that helps!
David Wall is offline   Reply With Quote
Old 07-15-2007, 07:38 PM   #4
Davidka's Avatar
Trader Rating: 75 (100%+)
I do it the other way around. I start with a roughly .5mm gap and begining to run and tune the engine. It doesn't need to idle for very long while I am running. Once I am confident that the balance from the HSN and LSN are good, I will adjust the idle screw to get the idle I want.
Old 07-17-2007, 10:35 AM   #5
Tech Legend
Cain's Avatar
Thanks for the info guys!
I noticed it somewhat that as I would lean the low end needle, it appeared as if the idle got better but I wasn't sure how those two worked together.
I will reset my idle screw to 1mm (its not far off from it anyway) and work with the low end.
These vehicles are pretty fun once you get the hang of tuning. Was having a blast just filling and go.
Old 09-25-2007, 08:31 PM   #6
rltanner's Avatar
Originally Posted by Cain View Post
Hey everyone.
I had a hard time getting my tune down for the first month on my buggy but had some help from some guys down at my local track help me out now its not a prob.Just seal around the carb, hsn base and your golden
Mugen MBX6
Mugen MBX6 Truggy
rltanner is offline   Reply With Quote
Old 09-25-2007, 08:33 PM   #7
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
cain sold the engine and car about a month and a half ago...
Jason Halvorson is offline   Reply With Quote
Idling problem Shaunnyg723 Rookie Zone 4 05-27-2008 03:53 PM
MR Ninja MR21 B01 engine Idling high after throttle input? spinall4 Electric Off-Road 9 01-22-2007 02:07 AM
Engine Idling/Tuning Help Needed dirtracer1 Electric Off-Road 7 09-17-2006 06:35 PM
Clutch biting points in conjunction with engine idling speeds Carbonfi_dragon Onroad Nitro Engine Zone 4 07-23-2006 06:30 PM
What does it mean wher my engine makes a high pitched sound while idling??? asd Nitro On-Road 6 07-03-2003 02:52 PM
