Old 07-14-2007, 01:19 AM   #1
mbunker's Avatar
Trader Rating: 29 (100%+)
Send a message via MSN to mbunker Send a message via Yahoo to mbunker
Default Replacing Thermo Insulator on a V-Spec .21 carb
Does any one know how to remove the thermo insulator from the bottom neck of the v-spec .21 carb? It seems to be epoxied on or something and I need to replace mine.
Thanks,
Michael Bunker
~Michael Bunker~
_______________________________________
Special thanks to my beautiful wife Brittany whom I love very much!
AE FT SC10/ AE FT SC10 4x4/ Team Durango DNX408T
mbunker is offline   Reply With Quote
Old 07-14-2007, 02:14 AM   #2
when i put mine in the oven to replace the bearings it melted the insulator so i had to replace it anyway
www.pinehillsdirtracing.com...MUGEN MBX7R with TEKNO V4 conversion.....TEKIN RX8 GEN2 esc HOBBYWING motor 2200kv.....
pitdog is offline   Reply With Quote
Old 07-14-2007, 06:24 AM   #3
smyka's Avatar
Send a message via AIM to smyka
i usually just take a pair of plyers and crush it a little it will break apart then i use a scotch bright pad to get rid of all the left over epoxy
Trinity, Proline ,EA motorsports, T.O.P Racing ,Futaba ,Bsr Racing tires ,Advantage racing products,Hot Bodies racing,Tq Wire ,REDS Racing, Orca ,Protoform racing
smyka is offline   Reply With Quote
Old 07-14-2007, 07:36 AM   #4
mbunker's Avatar
Why didn't you remove the carb before putting it in the oven? Did baking the carb too damage anything else like the orings? When I replaced the rear bearing, I remove all the componets except the rear bearing and then baked it. But thanks for letting me know. I'll try a heat gun on the insulator first and it that doesn't work I'll bake the carb body and insulator to get it off.
~michael bunker
~Michael Bunker~
Old 07-14-2007, 07:38 AM   #5
Trader Rating: 14 (100%+)
When i replaced my thermo insulator on my .12 TZ (had a crack in it) i took an exacto knife and scored the insuatora. Then i took pliers and gently took it off. You dont want to be too rough with the pliers because it can deform the aluminum. As for putting it back on, I used NORMAL JB weld, do not use JB quik because normal JB weld can hold up to alot higher temps.
thunderbt3 is offline   Reply With Quote
Old 07-14-2007, 05:36 PM   #6
mbunker's Avatar
That was going to be my next question. I used a heat gun to get it off because I didn't want to damage the carb like you said. Now I have the new insulator ready to install but the OS instruction paper just says epoxy. but doesn't mention what kind so I'm thinking anything that is high heat. Using the JB weld, what if you needed to replace the insulator again, would you be able to get it off?
Thanks,
~Michael
~Michael Bunker~
Old 07-14-2007, 07:17 PM   #7
~michael bunker
my mistake i ashumed i didnt have to mention the obviouse and once again ashuming we where on the same level,ashuming has made an idiot out of the both of us
WTB: OS V SPEC carb CRFXXXT R/C Items: Wanted to Buy 0 07-23-2008 10:53 AM
V-Spec Carb BRETTMASTERJ Nitro Off-Road 3 03-14-2008 06:04 PM
Novarossi MT-12 carb insulator? Old Skool Onroad Nitro Engine Zone 1 12-16-2007 08:21 PM
OS V Spec Carb El Pedro Australia Wanted to Buy 3 05-25-2007 09:43 PM
OS V-Spec 21C carb dylanj R/C Items: For Sale/Trade 1 04-10-2007 05:41 PM
