Old 07-13-2007, 08:44 PM   #1
blasterman456's Avatar
Send a message via AIM to blasterman456
Default reciever pack question!!! help!!!
how many mili-amps do i charge a 5cell, 1600 reciver pack? thanks dont wanna blow it up
*Xray 808*
*Nova Motors*
*FUTABA 3PK*
*ROCKET SCIENCE FUELS*
***www.propinch.com***
blasterman456 is offline   Reply With Quote
Old 07-13-2007, 08:55 PM   #2
V for Victory's Avatar
Send a message via AIM to V for Victory
On the safe side, I charge mine at 1.5, to 2 amps.
V for Victory is offline   Reply With Quote
Old 07-13-2007, 09:26 PM   #3
i charge mine at either 0.5 amps when at home prior to a race meet. if i am at the track & need to charge i will charge at no more than 1.2 amps.
reasons being, charging the receiver packs at anymore than 1.5 amps will reduce the batterys life & also you will find your milliamps will drop off as well. you will have a faster charge, but your run time out (life for a given charge) will be reduced.
so the higher (amps) you charge at the lower the milliamps (mah)
the lower (amps) you charge at the more milliamps you will put into your battery.
i also cycle my packs each month to keep them fresh as possible.
hope this helps
flysti is offline   Reply With Quote
Old 07-13-2007, 09:53 PM   #4
ya i know all that i just came from electric off-road and ment to ask about milli-volts...theres so many per cell...i know the amps...sorry i mean how many milli-volts
*Xray 808*
*Nova Motors*
*FUTABA 3PK*
Old 07-13-2007, 10:18 PM   #5
Scottmisfits's Avatar
I'm using the SMC 1400 packs, charrging at 0.5a with a mV drop of 4 per cell.
Scottmisfits is offline   Reply With Quote
Old 07-13-2007, 10:28 PM   #6
i charge at 1 amp with my ice and 16x8, but then i use a traxxas charger as well.
HTH
gatermaxx is offline   Reply With Quote
Old 07-13-2007, 10:39 PM   #7
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
for the best charge, charge at 0.5 the pack will last many tanks longer...
Jason Halvorson is offline   Reply With Quote
Old 07-14-2007, 07:48 AM   #8
GUYS, READ THE REST OF IT!!!
The stop drop should be set between 3 and 5mV/cell. Figure out where is best for your battery. Charging at 1 amp occasionally, with a 4mV/cell, my battery will get to about 90*. Any hotter than that in those smaller cells isn't really that great.
Old 07-14-2007, 12:14 PM   #9
Nickmind's Avatar
Send a message via AIM to Nickmind
what about dischange? how many amps are you guys dischange at?
Thanks,
Nickmind - 2 x savages, hyper 7, Revo 2.5, TC4, T4, 3 x 18T, CRT x1, Tmaxx, 8ight & 8ight-T 2.0 - all ran from a 3PK and spektrum.
Nickmind is offline   Reply With Quote
Old 07-15-2007, 03:11 AM   #10
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
You dont want to discharge receiver packs. Been told that by many fast racers.
Charge at 1 amp, 10mv for the pack, 1.5amps if your ina hurry.
Reason you want to charger at a slower amperage verse a higher is one is 2 reasons. Your trying to achieve runtime, not voltage, and receiver packs can get hot if you put anything more then 1.5-2 amps in them.
Receiver pack will also last longer if you dont charge as fast.
TLR ~ MaClan ~ Hobbywing ~ Futaba ~ Proline ~ Werks Racing ~ Genesis R/C Products ~ Mr. Scrubbles ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 07-15-2007, 09:36 AM   #11
air8's Avatar
Yep, I've blown up two before trying to get voltage in them. I was trying to make my servos perform better. I stay at 1 amp now and 8-10mv.
air8 is offline   Reply With Quote
Reciever pack NitroMaxx3.3 Nitro On-Road 11 05-31-2007 04:24 AM
lipo reciever pack shift Electric On-Road 1 11-08-2006 08:50 PM
Reciever Pack TeamPink91 Electric On-Road 10 07-16-2004 03:02 AM
Reciever pack cycling Darkseid Nitro On-Road 5 03-13-2003 09:13 AM
