Old 07-13-2007, 05:38 PM   #1
Default starter question
I just bought a factory team rc10gt2 kit and i also bought a .18 tz engine from os, and i was wondering what i need to do in order to convert the car into pull start.
I know i need the actual pull start, but i need to know if i need to convert the engine or something.
please list some parts that i would need
Thanks for your help
this is the back of the engine incase ur wondering
http://www.osengines.com/engines/osmg2110-inset3b.jpg
nfs23 is offline   Reply With Quote
Old 07-13-2007, 07:19 PM   #2
d4man's Avatar
It would be cheaper and less frustrating to just buy a starter box. But if you dont want to buy a box, you'll need the GT2 RTR Flywheel and RTR engine mounting blocks. The RTR Flywheel is bigger, and the RTR GT2 engine blocks are taller (to accommodate the starter mechanism). Part numbers 7993 and 2340 are what you need.
The greatest trick the devil pulled was convincing the world he didn't exist...
I always thought I had a pretty good imagination, but it turned out to be just my imagination.
NOT a member of Team Terribles!
d4man is offline   Reply With Quote
Old 07-13-2007, 08:56 PM   #3
V for Victory's Avatar
Send a message via AIM to V for Victory
Dont forget you'll need some time!
V for Victory is offline   Reply With Quote
Old 07-13-2007, 09:47 PM   #4
Trader Rating: 27 (100%+)
You can go easily and cheaply from a pullstart to a non-pull..
But to go from a non-pull engine to a pullstart engine you'll also need a new crankshaft. That itself will cost at least half as much if not 3/4's of the price of a bumpbox.
Here's a link to the crank: http://www2.towerhobbies.com/cgi-bin...?&I=LXJPY8&P=Z
Here's a link to a starterbox (I've used this box for four years): http://www2.towerhobbies.com/cgi-bin...&I=LXAXU2&P=SM
Cheaper box, basically the exact same one though: http://www2.towerhobbies.com/cgi-bin...&I=LXMPP5&P=SM
jbrow1 is offline   Reply With Quote
Old 07-14-2007, 04:16 PM   #5
ok so i need the mounts which i have the link, i also need a crankshaft, and a flywheel, what else do i need, other than the actual pull start?
thanks for those who answered.. but i think i need one more part but i cant think of it.
Old 07-14-2007, 05:31 PM   #6
That should be everything as long as the pullstart is a complete assembly. It needs the shaft and one way nut to make everything work. If that picture is the exhaust you have you'll have to jury rig the manifold on so it will clear the p.s. housing. Could try heating it up and bending it.
8T Starter box question jgtruggy Nitro Off-Road 3 02-26-2008 08:42 PM
starter box question mcc Radio and Electronics 0 11-05-2007 05:44 PM
Starter Box Question...Help??? jhigga15 Nitro On-Road 4 03-21-2005 07:56 AM
Starter Box Question SERPENTFREAK69 Electric Off-Road 8 10-27-2004 08:59 PM
Have A Engine Starter Question??? altmaster_1 Nitro On-Road 0 05-08-2002 07:03 PM
