Old 07-05-2007, 10:32 PM   #1
Default Nitro Vets.. i need help on oldschool
any one know what type of breaking this is called..
http://s127.photobucket.com/albums/p...t=DSC00321.jpg
also does any one know if it can be converted into disc breaking. If it can, can you tell me how or direct me to a way.
thanks in advance
nfs23 is offline   Reply With Quote
Old 07-05-2007, 10:52 PM   #2
o ya... its an old nitro hawk that runs well, but i need more power and better breaks cause all i do now is slide for a while when i press my breaks and high speeds.
Old 07-06-2007, 09:29 AM   #3
Dave Nelson's Avatar
I belive its a "drum brake" type. as far as going with disk setup im not sure, someone here probaly knows of a conversion kit or parts to use. hope that helps a little.
HPI SAVAGE X: Ko Propro Mars R(Spektrum Pro)
Looking for upgrade parts pm me!
"Donnie, your out of your element"
Dave Nelson is offline   Reply With Quote
Old 07-06-2007, 02:04 PM   #4
RC Pro 1's Avatar
I had several of the Nitro Hawks and the brakes can be adjusted to not lock up but it takes a lot of playing with the servo adjustments. a spring or piece of fuel tubing on the linkage to absorb some of the pressure from the servo on initial application would work. The brake setup is similar to the old Brezinski setup for the GT if I remember right. I always burnt up the brake arm since it's just plastic against the steel clutch bell. I think some gasket material glued to the contact area of the arm would help make it last longer and may smooth out the braking as well. The brake arm applies pressure to the clutch bell. The problem with more power for that truck is the crank is a goofy length compared to most engines (longer). The flywheel and clutch bell are turned around backwards from the normal setup. If you try to install a regular crank engine the clutch bell teeth won't line up with the spur gear. You would have to move the engine back to make it line up which will require either re-drilling the chassis to move the existing mounts back or using different mounts.
RC Pro 1 is offline   Reply With Quote
Wanted..oldschool Twister disc sander Jay Boyd R/C Items: Wanted to Buy 3 11-19-2008 03:20 PM
Oldschool H Tamiya Hotshot for sale in sydney SP2333 Australia For Sale/Trade 7 04-17-2006 03:31 AM
Oldschool rare Tamiya Hotshot SP2333 R/C Items: For Sale/Trade 0 04-15-2006 05:11 PM
FS/FT Tmaxx, Nitro Rustler, Nitro RS4 Racer, Nitro RS4 RTR, Losi XXXNT RTR ChrisR40 R/C Items: For Sale/Trade 24 03-20-2006 02:47 PM
Oldschool RC10T,box of parts,MRC Jeep FS jsbodies R/C Items: For Sale/Trade 9 12-09-2005 04:52 PM
