Old 07-04-2007, 04:04 PM   #1
sir miles's Avatar
Trader Rating: 23 (100%+)
Default JP-3
Ofna JP-3 pipe, does anybody use this pipe? How was it? Im currently using a V Spec with T2050 pipe, Im happy with it but I want to try the JP-3. Is it worth trying?
gaining momentum!
sir miles is offline   Reply With Quote
Old 07-04-2007, 04:06 PM   #2
Scottmisfits's Avatar
If you like the 2050, you should like the JP3. Although If you're happy with the 2050 I don't see a need to switch.
Scottmisfits is offline   Reply With Quote
Old 07-04-2007, 04:07 PM   #3
Matt Howard's Avatar
I've run both on my V-spec and they're both great for that engine. In my testing the JP-3 seemed to have a bit more top end but a little less fuel economy.
Matt Howard is offline   Reply With Quote
Old 07-04-2007, 07:02 PM   #4
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
i have run both and i agree the jp3 has more top, but my fuel milage was about the same....running on a Novarosi P5X and a Werks B7PRO....
Jason Halvorson is offline   Reply With Quote
Old 07-05-2007, 05:52 AM   #5
sir miles's Avatar
Thanks for the inputs Sirs! Appreciate it!
gaining momentum!
