Old 06-30-2007, 09:41 PM   #1
Trader Rating: 27 (100%+)
Default Jato 3.3 steering/throttle cutting out.
Got my 3.3 Jato today and am pretty impressed with it. One problem Ive been having though is that sometimes the throttle/steering will just die out. I can lift up the back of the truck and it free revs and the tires start to spin up pretty fast. I hit the throttle/steering and after about 15 seconds or so it begins to work again. Sometimes I have to mess with the switch on the truck that turns it on/off which doesnt really work that well eithers. Sometimes when I turn that too the off position it still stays on and I have to move the switch inbetween off/on to get it to shut down. Anyone else had anything like this happen or know whats could be the cause?
Like I said I just got it today, brand new out of a sealed box.
Team Losi LST
Warehouse Hobbies M5 Manta Ray
Stryker F-27C
J-3 Brushless Cub
platinumjason is offline   Reply With Quote
Old 07-01-2007, 05:08 PM   #2
backyarder721's Avatar
I have a jato 2.5 and the switch on the car won't work some times. Try to pull it back just slightly from the on position. That works on mine if I have it all of the way on it doesn't work. If this is a problem for you the swithc is not expensive and you can just replace it.
Try to learn from mistakes. Preferably other's.
backyarder721 is offline   Reply With Quote
Old 07-01-2007, 09:16 PM   #3
Seems to be for some reason mine came with one of the plugs in the reciever that was suppose to be left empty. Unplugged it and seems to be working right so far. Thanks
Team Losi LST
Stryker F-27C
J-3 Brushless Cub
Old 07-09-2007, 07:01 AM   #4
jatoman1992's Avatar
Trader Rating: 4 (75%+)
Send a message via Yahoo to jatoman1992
check ur batteries, dont drive in water
jatoman1992 is offline   Reply With Quote
Best steering/throttle servo for 18th scale? wstuart Nitro Off-Road 0 05-16-2008 06:28 PM
Adequate Servo Specs for Steering/Throttle TxCZShooter Electric Off-Road 7 01-22-2007 09:43 AM
Steering and Throttle servo choice hitman Electric Off-Road 3 01-06-2006 09:04 PM
1/8th scale steering and throttle servo recomendations Rick Draper Electric Off-Road 1 08-18-2004 09:19 AM
Radio throttle/steering return springs ChrisP Electric On-Road 7 04-12-2004 07:30 AM
