Old 06-28-2007, 09:53 PM   #1
Default is tunning shreading my spur gear?
yesterday and today in the process of tunnin my tmaxx 3.3 the engine went from and idle to an out of control rpm rage and upon shut off both times i descover my spur gear is missing a section where it was touching the clutch bell during idle...im quite sure the gap is fine id did the paper test the teeth left grooves in the paper w/o tearing it also it runs fine for a few mins. then all the suden i pull it in for a pit stop to tune and it goes wild.also to doa when it happened i was manualuy messing w/ the brake control on the truck(w/o using the controller) wwhen it hapend so i wonder if it mat have did a sort of power braking action///but yester day i wasnt playin w/ the brakes...anyways does anyoe kno wut maybe causing this????
chav is offline   Reply With Quote
Old 06-29-2007, 01:06 AM   #2
sometimes using the paper to guide you in meshing still leaves too big of a gap in between. Try meshing the gears yourself but just leave the slightest amount of play and the gears should still free wheel when you spin them. Also sometimes the engine moves, use threadlock on the engine mount screws. My tmaxx went wild once when i forgot to pull up the antenna.
Genius is offline   Reply With Quote
Old 06-29-2007, 08:40 AM   #3
Dave Nelson's Avatar
Also if your tuning it while its running you can get interference when the screwdriver touchs the metal causing the servos to throttle up and down eratticly
HPI SAVAGE X: Ko Propro Mars R(Spektrum Pro)
Looking for upgrade parts pm me!
"Donnie, your out of your element"
Dave Nelson is offline   Reply With Quote
Old 06-29-2007, 06:43 PM   #4
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
like dave said with AM there is alot of interference when there is metal to metal contact....causes glitches...
Jason Halvorson is offline   Reply With Quote
Old 06-29-2007, 08:35 PM   #5
associatedguy's Avatar
Or if you get the antenna on the radio to close to the receiver wire, it'll glitch like crazy.
associatedguy is offline   Reply With Quote
Old 06-29-2007, 10:42 PM   #6
this is very true...
Gear Ratios/ Spur Gear Sparky7B Rookie Zone 2 02-26-2008 09:03 PM
Spur gear pinky2252s Nitro Off-Road 8 01-21-2008 04:43 PM
Jammin Diff, w/ Lightened Spur And Extra Spur Gear prphze R/C Items: For Sale/Trade 0 10-07-2007 02:40 PM
TC3 spur gear... AZNracerx1989 Rookie Zone 3 08-02-2005 06:58 PM
TC3 spur gear ajg Electric On-Road 3 03-08-2004 12:34 AM
