Old 06-27-2007, 11:27 AM   #1
Default Steering Problem
My steering is fine at slow speeds with the steering trim but at high speeds it tends to swerve one way. Any, help?
jmdv is offline   Reply With Quote
Old 06-27-2007, 12:18 PM   #2
Trader Rating: 23 (100%+)
what are you driving?
where are you running it?
pete8541 is offline   Reply With Quote
Old 06-27-2007, 01:01 PM   #3
im runing a nitro rustler on like hard packed tracks with some sand
Old 06-27-2007, 02:00 PM   #4
R40Victim's Avatar
Check to make sure your linkage and servo are ok, and your servo saver is tight enough. It may just be inherent to that truck.
R40Victim is offline   Reply With Quote
Old 06-27-2007, 02:06 PM   #5
k, ill check that, thanks
Old 06-27-2007, 04:09 PM   #6
would the cars balance have any affect on this? under hard acceleration, my car would tend to swerve to 1 side as well until i balanced it out.
WayzOfTheCore is offline   Reply With Quote
Old 06-27-2007, 07:00 PM   #7
and how do i balance it?
Old 06-28-2007, 03:46 AM   #8
find out which side is lighter and then even it up by adding weight. ive only balanced my onroads up but to do it i balanced the car on 4 springs under the chassis and added weight to 1 side until the springs on the left and right were compressed evenly. not sure if that method will work for you as your rustler is probably alot heavier than a 1.10 onroad
Old 06-28-2007, 07:23 AM   #9
k i will give that a try, thanks
TC4 steering problem mnapp69 Electric On-Road 4 12-25-2007 04:20 AM
how to fix the problem in steering? Potter Micro and Mini Scales 2 10-18-2007 05:19 PM
Steering problem... joe of loath Micro and Mini Scales 5 03-21-2007 12:24 PM
MI2 Steering problem brakkie Electric On-Road 6 02-13-2006 06:01 PM
