Old 06-27-2007, 10:55 AM   #1
Default Upgrade Futaba from 3PM to 3PK?
My roomate recently got the 3PK with the FASST 2.4 module and I love it. Main improvements for me are the backlit screen and the timer/vibrate function. Is it worth it for me to upgrade from the 3PM FASST to the 3PK with FASST?
Losi 8ight-T 1.0 OS Speed JR 9000S/T
Losi 8ight 1.0 C6BB7T 2045 086 Hitec 5997TG/JR 9000S
Losi 22 Tekin RSpro 8.5/JR9000S
All controlled by 3PK/FASST
magbarn is offline   Reply With Quote
Old 06-27-2007, 01:20 PM   #2
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
It depends. Is the 3pk more comfortable? Does it have features that you need that your other radio doesnt have? Do you just want it? Its a hobby, buy what you want. Personally I would be fine with my old Spektrum radio as I dont like to use any advanced features, but I bought an M11, used it for a year, then tried out my friends 3pks and it felt a little more comfortable, so I bought a 3pks and sold the M11, but now I may move back to the M11 because some stuff on the 3pks makes me unhappy (failsafe blows as it loses the setup once the RX pack is turned off). I use the FASST module and RX. Mainly I like to try new toys.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 06-27-2007, 05:13 PM   #3
I could be wrong but I don't think this happens in HRS mode - only PPM.
Helios/KO 2.4
Mugen MTX-4 // Losi 8B // AE B44 // Mini-Z 2.4 // Axial AX10
jon123 is offline   Reply With Quote
Old 06-27-2007, 06:22 PM   #4
Failsafe is only operable in PCM and HRS modes from the 3PK.
My 3PK's failsafe works flawlessly every time (I always do a test before a race). However, since most of my vehicles now use Spektrum the failsafe is set up at the Rx during binding and the Tx is in PPM mode (no Tx failsafe).
AreCee is offline   Reply With Quote
Old 06-27-2007, 06:26 PM   #5
He said he was using FASST - which operates in either HRS or PPM. Failsafe with FASST works in both those modes, but in HRS doesn't need to be reset each time you turn on the radio.
Helios/KO 2.4
Old 06-27-2007, 06:32 PM   #6
TGA78's Avatar
I checked out the 3PK before I bought my 3PM and I didnít like the balance of the unit in my hand. So I bought the 3PM. The only problem I am having with the 3PM is the wheel doesnít seem to spring back to center. I assume there is a setting for that and I just need to adjust it. I just havenít had a chance to look.
TGA78 is offline   Reply With Quote
Old 06-27-2007, 07:01 PM   #7
Check that your steering wheel bearing is clean. If you run offroad, dust gets in there and it will not center as well over time.
Correct, with the FASST you can use failsafe in PPM or HRS mode, but I do not have digital servos yet (all Airtronics 358s). In PPM mode you have to set the failsafe every time that the receiver loses power which blows big time. Futaba dropped the ball on that one. If in fact HRS mode doesnt have to be reset every time, I will sell all my servos and go digital. Friggen lame if you tell me (failsafe, not the digital servos)
Also what bugs me is why have the 3 buttons for each trim?! Its like 2 engineers/ designers couldnt agree. One reason why I prefer my old M11..... I will try to adjust trim on the fly while racing and hit the button and slider trim....oh it ticks me off.
Old 07-22-2007, 02:04 PM   #8
Hi forum i am getting the 3pk soon and i am confused about the failsafe info
i Think i will have to run it in either pcm or ppm mode because i have a digital jr9000t steering and a traxxas stock 2055 throttle brake servo.
Will i have a problem with this servo configuration?
DonnieNitro is offline   Reply With Quote
Old 07-22-2007, 03:40 PM   #9
air8's Avatar
I'm confused also. I'm intrested in the 3PKS or whatever it's called. But all these different modes is mind blowing. HRS, PCM, PPM. What does all this stand for? Is it on the website? What is the diff between each one? I have nitro 8th scales with digital servos, but electric 10th scale with blue bird servos (pretty sure my BB are analog). What modes does the radio need to be in for the digital and analog?
air8 is offline   Reply With Quote
Old 07-22-2007, 08:56 PM   #10
wlfgnggtr's Avatar
With the 3PK you can run it in Pcm mode for any servo whether it be analog or digital. If you want to use the Hrs mode, the servo's do need to be digital. When changing models, the 3PK can be setup to use Hrs on model one. Pcm on model two... It's pretty cool really that it has all the options that it has. It can be confusing, but it is a nice radio...
I will agree that the fail safe is lame Why Futaba did that, I wish I new...
I did just switch from a M11/Spektrum pro system... There are things I miss about the M11, but I do like the feel of the 3PK... I am also impressed with the Fasst system, mine will bind in a second when powering up the radio and receiver... My M11/Spektrum would take a good 5 seconds... I am also impressed with the range, and the diversity antenna in the receiver. I have one corner on the track, that whenever I go off of it, I would lose signal with the Spektrum, today I went off the same corner with the Fasst, no signal loose
The way I see it, all of the top end radios are very good, it all comes down to user preference...
wlfgnggtr is offline   Reply With Quote
Old 07-23-2007, 12:44 AM   #11
air8's Avatar
Thanx a lot for the info. One more question. Can the 3PK use the FAAST modules? I believe the 3PKS can but how about the one that is a little bit older?
Old 07-23-2007, 01:01 AM   #12
Turbine_au's Avatar
There is a small screw under the wheel on an angle. Tighten it to increase the tension on the steering wheel spring, hence making it centre better.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 07-23-2007, 07:15 AM   #13
KForce's Avatar
Trader Rating: 2 (75%+)
yes the 3pk can use the fasst module. they (3pk and 3pks) are basically the same radio with a different button design and menu changes.
Team TQ Fuel
OS Speed Engines
Futaba
Panther Tires
CRCRC Raceway Webmaster
FullThrottle Raceway Webmaster
KForce is offline   Reply With Quote
Futaba EXHP tx/rx great upgrade for CP! jtrcing R/C Items: For Sale/Trade 6 09-29-2006 02:51 PM
want to upgrade MilanoFury Rookie Zone 3 12-28-2005 01:01 PM
Upgrade your Old Futaba AM to a 2PH AM JonBoy R/C Items: For Sale/Trade 0 01-07-2005 07:12 AM
anything to upgrade?? davioh Electric On-Road 10 03-30-2003 09:56 AM
Futaba 3PK $260, Futaba R203HF $80, R113IP $75, Futaba $9450 $80, OS 12TR $135 smash123 R/C Items: For Sale/Trade 2 02-13-2003 03:03 PM
