GAS & NITRO GAS
HET GUYS THIS IS MY FIRST GAS CAR AND I DON"T KNOW WHICK GAS I SHOULD GET REGAULR GAS OR NITRIO CAN I USE REGAUL GAS OR DO I HAVE TO USE NITRO GAS OR HOW DO U MAKE IT:tire:
Ok im just starting too. Im pretty sure u need the nitro gas, which idk how to make, Usually the cars that use reg gas is pretty expensive or old so u might wanna ask someone else before doing what i say
First off, what car do you have? ALL nitro cars use nitro hobby fuel available from hobby shops. Regular petrol is only used in large scale cars and is used with a mix of 2-stroke oil. DO NOT ever put regular petrol in a nitro vehicle.
RE:
ull kill ur engine if you do that
Only use Iraqi gas.
you will need to hit up your hobby shop to buy your nitro fuel. depending on the engine size in your car will determine what percentage of nitro mix you need. also dont buy fuel for airplanes or boats as they are slightly different and will work but its not the best for your motor. if you have a .12 to .18 motor you'll look to 20% nitro and engines from that size up usually use 30% but you can use 20%.
THANK I WOULD JUST TAKE MY SHIT TO THE HOBBIE STORE AND THE WILL TELL ME THE PERCENT AND A NOTHER ? I HAVE NOT OPEN the box to my GAS CAR CAN U GIVE SOME STUFF I SHOULD LIKE HOW TO BREAK IN MY ENGINE OR DO DO A HOLE BUNCH OF SHIT TO STRAT MY SHIT RUNING GREAT TH GAS CAR I HAVE IS A XtremeStormGreen 2-Speed 4-WD 1/10 Scale
Nitro Gas Radio Remote Controlled RC Off-Road Buggy Car,http://site.exceedrc.com/resource/product/51c06-11.jpg http://site.nitrorcx.com/xtremestormgreen1.jpg http://site.nitrorcx.com/xtremee2.jpg http://site.nitrorcx.com/xtremee3.jpg http://site.nitrorcx.com/xtremee12.jpg http://site.exceedrc.com/resource/product/51c06-18.jpg |
do you know how big the motor is? .12? .18? .21? if so, you can find out what fuel you need here on the web.
try finding a thread on the heat cycle method of break-in. that will probably get ya going. |
x
x
First thing you may want to do is go back and edit the language on your post. They try to keep the language, at least, kind of family friendly on here.
That car is a nitro car and I would first look in the manual since it looks like it came ready to run with that motor in it. I would bet that the manual has a recomended nitro fuel listed in it. If not check with your local hobby shop, but don't be too suprised if they are not very helpfull since you appear to have bought it on line instead of buying one from them. The manual problably also recomends a break in procedure that you should follow. |
YEA I THINK THE MOTOR IS LIKE 18 BUT Wat R some DO AND NOT DO FOR GAS CAR CAUSE I REALLY DON"T WON"T TO MESS MY GAS CAR THAT WHY I I LISTEN TO WAT PPL SAY BEFORE I OPEN THING UP:batman:
