Old 06-26-2007, 10:42 AM   #1
Default Sand Tires
What r the best sand tires for a stadium truck?
jmdv is offline   Reply With Quote
Old 06-27-2007, 12:26 PM   #2
Trader Rating: 23 (100%+)
I have used proline sand paws and they seem to work just fine.
Remember, if you use them to loosen your slipper clutch or you may do damage to the diff.
pete8541 is offline   Reply With Quote
Old 06-27-2007, 12:55 PM   #3
thanx alot
Old 06-27-2007, 02:03 PM   #4
no, im just using them to get traction at this sand track, is it going to affect the dif.
Old 06-27-2007, 05:03 PM   #5
gubbs3's Avatar
If you are racing on a track I would reccommend step pins. Paddles are great for bashing around and just having fun sending huge roosts of sand but on a track they are not quite the best choice. Step pins still have great forward traction but not so much the front wheels are always off the ground. Making sure the slipper is loose enough to protect the diff is just the same as any other tire choice. It is just a little bit more sensitive since paddles can grab hard!
gubbs3 is offline   Reply With Quote
Old 06-27-2007, 07:02 PM   #6
thanks
Old 06-28-2007, 04:17 AM   #7
if you are on a track you may want to look at a differnt tire, they tear things up pretty good.
I live near The Wisconsin river and used them on a gt for bashing on the sand bars. They grab great but I ended up installing a steel diff gear and loosening the slipper.
Old 06-28-2007, 06:47 AM   #8
ok, how do i losen the slipper?
Old 06-29-2007, 06:41 AM   #9
a lil help...?
Old 06-29-2007, 12:44 PM   #10
what truck are you running?
Old 06-30-2007, 02:38 PM   #11
loosen the nut 1/8th turn at a time on the shaft the spur is on
acexxxoasis is offline   Reply With Quote
Old 06-30-2007, 03:14 PM   #12
im running a nitro rustler, whats the spur?
Old 07-01-2007, 05:21 AM   #13
did you get my pm?
Old 07-02-2007, 11:02 AM   #14
ya, i got it, thanks
Looking for Sand Tires mikedealer Electric Off-Road 9 10-29-2009 10:20 AM
Wheels/Tires for Sand Viper DT02? swannco Electric Off-Road 1 08-16-2007 09:55 AM
sand damage? customride Rookie Zone 4 06-04-2007 08:08 PM
Sand Tires scottyoer R/C Items: Wanted to Buy 1 05-04-2005 06:19 PM
Sand, is it bad ?? TS_Mick Monster Trucks 8 03-15-2003 11:15 AM
