Old 06-25-2007, 05:22 PM   #1
patrick21x's Avatar
Trader Rating: 58 (100%+)
Send a message via Yahoo to patrick21x
Default Will I need head shims on OS V-SPEC if running 30% Nitro
I have been running Odonnel 20% Nitro for a while. I now got three new OS V Spec 21's. I am thinking of going to 30% Nitro. will i need head shims or should the motors be fine?
patrick21x is offline   Reply With Quote
Old 06-25-2007, 05:31 PM   #2
FrankBlack's Avatar
Its advisable, the manual says to use the extra shim for 30%.
FrankBlack is offline   Reply With Quote
Old 06-25-2007, 06:13 PM   #3
Yes, that is why OS packages the shim with the engine. You will need it for 30%.
AreCee is offline   Reply With Quote
Old 06-25-2007, 06:53 PM   #4
shimmyz's Avatar
I just bought a CEO Powermods Vspec from Chris O'Donnell. He told me as long as it stays around 250 degrees or lower don't worry about the shim. before the CEO I had a stock Vspec with no shim. On a hot day(high 80's), running 30% Losi Nitrotane, my Vspec would come off the track anywhere from 210-220.
shimmyz is offline   Reply With Quote
Old 06-25-2007, 07:04 PM   #5
racersnow's Avatar
Trader Rating: 37 (100%+)
Send a message via AIM to racersnow
All my motors needed the shims, would fry the plugs not long after starting if I didnt
racersnow is offline   Reply With Quote
Old 06-25-2007, 07:31 PM   #6
No shims and 30% runs sweet.
Dave.H is offline   Reply With Quote
Old 06-25-2007, 07:32 PM   #7
schmelme's Avatar
If its around 75+ degrees outside switch to a P6 plug and you'll be fine. I've had good luck with .1mm added and running a cooler plug.
schmelme is offline   Reply With Quote
Old 06-28-2007, 09:06 AM   #8
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
Use the extra shim for break-in to make life a little easier for the conn rod, then take the shim out after you're done. No shim needed for 30% after break-in.
SkarTisu is offline   Reply With Quote
Old 06-28-2007, 09:57 AM   #9
Without using the extra shim on 30% nitro the engine will run fine, very aggresive powerband from bottom to mid. Using the extra shim will give you a better top end, smoothen the bottom and mid and give you better fuel mileage. The V-spec is one my favourite engine. Currently still have 4 of these excellent engine. Will try out the OS speed version soon.
RunarounD is offline   Reply With Quote
Old 06-28-2007, 01:25 PM   #10
xlgraphicspro's Avatar
I run 30% byrons, and haven't added a shim. it runs fine at 210-220. I'm also still using the original glow plug after 2 gallons. the motor comes stock with one shim already installed, That's enough!
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 06-28-2007, 02:09 PM   #11
Matt Howard's Avatar
man, you are just the oddball around here. First you're not using the smallest carb insert and now you're not running the extra shim. I betcha your car would be easier to drive and have better fuel economy if you ran the extra shim and the smallest insert See ya sunday
Matt Howard is offline   Reply With Quote
Old 06-28-2007, 02:49 PM   #12
patrick21x's Avatar
Default Went from 20% to Werks 30 %
Well I switched it up this weekend. After talking to multiple people I decided not to add the shim. I was using ODonnell 20% and I ended up getting Werks 30%. Holy Shizznit. I could tell a big Diffrence. On the 20% my motor was running 230-240. After filling the tank w/ 30% and no needle adjusment my motor was running rich and slower and came in at 180-190. I leaned it out a bit and it started to wake up. After a few tanks i was able to lean it probably 3-5 hours and it is running freaking awsome. Hauls Balls with awsome power band. Coolest thing is that it comes in around 200-210. My V-Spec is great now. I have two other V-Specs one is a JP modified and I cant wait to see what they baby runs like on 30%.
Thanks to every ones comments on the topic of Head shim needed.
After Doing the switch myself I have learned that you do not need a shim when switching to 30% Nito and your motor will run awsome.
I also learned that the Werks fuel lives up to what people are saying. It does run cooler w/ more power.
I also exsprianced that going from a JP3 pipe to an OS 2060. The temp dropped 15-25 Deg in the motor, Dont know why but it does.
Later guys, Patrick
Old 07-01-2007, 12:42 AM   #13
nhodd's Avatar
Send a message via Yahoo to nhodd
Default shim
i do run the shim but only because initially was told to.i am fairly new to gas.
I don't run that amount of nitro though.Cant be good for the life of your engine
nhodd is offline   Reply With Quote
o.s vpec running 20% need to remove shims? losiracer22 Nitro Off-Road 2 06-25-2008 07:04 PM
Head shims for a VZB jrwoodchuck Nitro Off-Road 12 02-16-2008 03:30 AM
OS VZ-B head shims porter Onroad Nitro Engine Zone 0 08-01-2006 07:17 PM
head shims harddrive Electric Off-Road 5 12-30-2005 08:43 PM
Do I need extra Shims for a Mr-12 when running 30%? Dust Nitro On-Road 8 11-18-2003 10:05 AM
