V-Spec questions... (how to tell if it is the newer motor)
Hey guy's,
Was wondering how to tell if a Vspec is the newer model? Anything change in the letters, or how can I tell. A Main has it listed as O.S. Max 21VZ-B V-Spec-T (P). Can I tell anything by this?
Dave
Dave
Im 99% sure the (P) means its the newer version, i just checked my vspec box i picked up at the start of this yr and its not labeled (P)
No, I was not referring to the speed engine either. I ordered one so I will see what I get when it gets here I guess .
Dave
Dave
Kind of hard to explain so I'll do my best. I think he means is it a 06 or 07 model. The only way I can tell is by looking at the bottom of the crank case. If the screw tunnels run all the way up to the other side of the case its a 07. If they stop half way its a 06 version. Only difference is I believe the the 07 has the updated bearings
Tony, that was exactly what I was looking for as far as the 06 and 07 models, however, is the (T) what indicates the 07 model?
Dave
Dave
OK thanks. Just cause I am curious, can anyone post a picture of the newer crank case? I have found alot of pictures of what I think is the 06 model crank case, but I can't find any pictures of V-Spec with the screw holes running all the way to the front of engine.
Dave
Dave
Huh huh aaaaaaaaaa hu huh, Dude just said screw holes.
You guys just made me run down to my basement this late at night just to grab my box.
Ha ha I know I just said "Grab my Box". and I don't see any "T" or "P" I know it does say 13890 above the bar code on the circular sticker that says Max 21VZB V-spec. I hope it's a revised one with the good bearings.
The "07" V-Specs have a 9 ball rear crank bearing vs. the 8 ball bearing in the "06" V-Specs. That and the updated crankcase are the only two differences in the engines as far as I know.
If you buy a new V-Spec from any shop that regularly sells engines (like A-Main Hobbies) then you'll get the "07" V-Spec since they've been available for a while now.
