Carb Inserts...how to tune when changing them
I am going to be trying out a few different size carb inserts in my C6 to make it a little more controllable in my 8ight. I will be going from the stock 8mm to 7mm or 6mm. When I am going to the smaller inserts, which way should I adjust my tune? I've never played around changing these things, but the C6 is a beast in the 8ight and I'm trying to limit the wheel spin.
I also race 1/10 elec buggy so I know about throttle control...lol! I think the C6 is overkill in the 8ight but perfectly matched in my truggy. I just wanted the same engine for both because I am familiar with the C6. Last summer I ran truggy only and for the new buggy I didn't want to have to learn the characteristics of a different engine.
Thanks for the tips guys!
Good, Im glad that you run a 2wd vehicle. Hmmm..I was thinking of buying a C6BB for my 8 when my WS7II dies...I also come from 2wd racing, but well see. I know that the WS7II/ III rocks in my 8, but its past the 3 gallon mark and quickly fading because of a mistake I made when I first got it.
I just couldnt resist the thottle control comment however You know, its funny, I havent driven my AD2 this season, and am finding my throttle control and steering to get sloppy because of the ease of driving a 4wd buggy. (also the 8) I will be breaking out the AD2 more often to compensate and gain my control back.
rezenclowd3, I too broke out my GT2 this past weekend and found that I was driving very sloppy Even though I am driving a 1/10 elec almost weekly, I just could not get in the rhythm of 1/10 gas truck like I used to be. I made the B-main but was so sloppy the 4th place I was in before I broke was below my standards and disappointing. I believe I have been running truggy and 1/8 buggy too much It is hard to break the point and shoot habits.
I totally agree man. Point and shoot. Although I have found my 8 to be so much less time consuming to upkeep...I have not been in the mood to rebuild my diff in my stadium truck. I hate ball diffs....when they blow anyway! I actually bought a whole new diff for my AD2 (~$50) and it is still not smooth, and my slipper (also new) doesnt slip like it did when the kit was new...Time for a new kit. I would like the GT2 but I have over $400-$500 in spares for the AD2 (my track eats up anything but buggies and truggies) I will land fine but a rock will be in the way and break the a arm or pivot block.
Though I gotta say, 2wd was so much more fun when the kit was built right. The look, the speed and handling just looked right.
Just a word of caution regarding exchanging carb inserts in 2 needle carburetor...
If you go down from a let's say 8mm insert to a 7mm insert, the low-end needle and spraybar remains on the same position and because the reduced diameter of the insert, is located nearer to the projected surface of the carb insert.
Having it them nearer could lead to carb adjustment and fuel atomization problems, just remember that fuel converts into a mist entering on the engine.
If you have a 3 needle engine (the ones with the 'brass screw' you can offset the spraybar and modify when you want your carb being driven from the LSN to the HSN. C6 Engines comes with a 2 needle, don't know why they switched from 3 to 2 needles on their high-end engines where you want the maximum flexibility and performance.
Be forewarned that smaller inserts mean slightly more runtime and better low-end, but some engines react very bad to them and start being a bitch to tune them.
The new version of the C6, the C6-BBT7, comes with the 7mm restrictor, turbo plug button, and lightened head. The rest of the motor remains unchanged. You won't have a problem going to the 7mm restrictor. I don't have experience with the 6mm insert, but have the 7mm and turbo button set ups in both my C6BB motors. They work fine, no tuning problems.
I don't recall much of an adjustment in the tuning after the change to the 7mm.
hey guys
do you always adjust the 3rd mixture screw according to the lsn?
I know how to tune the hsn and lsn,but is there also a method tuning the mixture screw? I´m running the os vspec btw.
The mid screw adjusts the point at which the engine switches drawing fuel from the LSN to the HSN as I understand it. Adjusting that seems to be an area that is rarely mentioned.
If you have the so incorrectly called 'Mid rpms needle' you can change that point and helps to tailor the carb fuel curve and their metering.
Ever has been said to better to not mess with that screw because if incorrectly adjusted you can cause lean conditions on partial throttle or very rich conditions and the performance could be sub-par.
Didn't knew why the manufacturers decided to drop that screw, left to many people without a tunning adjustment.
how do you adjust that screw?
if you insert a smaller venturi for example,what to do with that needle.
