Old 06-20-2007, 02:45 AM   #1
Rookie01's Avatar
Default XXX-NT motor question
Is there any way I can put an SG style shaft with a slide carb motor in my XXX-NT?
Thanks!
Rookie01 is offline   Reply With Quote
Old 06-20-2007, 02:37 PM   #2
El Pedro's Avatar
I have an AD2 and the kit comes with linkages for both slide and rotarty carbs. No sure about the SG shaft though. I would think it would be easier to just get a rotay/threaded enigne though.
El Pedro is offline   Reply With Quote
Old 06-20-2007, 02:41 PM   #3
Rookie01's Avatar
Thanks for the answer!
Im asking this because I already have a old motor from my Serpent 710.
I was hoping to put this one since its only for bashing.
Pascal
Old 06-20-2007, 07:05 PM   #4
Rookie01's Avatar
Anyone put an SG shaft on a XXX-NT?
Old 06-20-2007, 08:37 PM   #5
rushdude's Avatar
Send a message via AIM to rushdude
I dont think its possible without getting a custom nut for the flywheel.
rushdude is offline   Reply With Quote
Old 06-21-2007, 12:08 AM   #6
Aaron Waldron's Avatar
With enough machine work and ingenuity, you can do almost anything with an R/C car.
With that said, you cannot install an SG crank in a XXX-NT truck with off-the-shelf parts (that I know of).
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 06-21-2007, 05:26 AM   #7
since the gt2 uses a sg shaft you might be able to use the flywheel nut from it. not sure, just a guess.
T Green is offline   Reply With Quote
Old 06-21-2007, 06:49 AM   #8
The flywheel nut isn't the problem, it's finding the right clutch bell and flywheel to line up with the XXX-NT drivetrain without too much chassis mods.
AreCee is offline   Reply With Quote
Old 06-21-2007, 08:43 PM   #9
shady3031's Avatar
Trader Rating: 26 (100%+)
I showed up at the track the other day with xxx-nt, but needed a motor. One of the guys that runs a mst-1 had a novarossi with an sg shaft and a rotary carb, along with some kind of offset motor mounts and with a little shimming we awere able to line the motor up good enough to run 3 five minute qual. and finish second in the main. So it can be done.
shady3031 is offline   Reply With Quote
Old 06-21-2007, 08:52 PM   #10
what flywheel did you use?
Old 06-22-2007, 01:21 PM   #11
Rookie01's Avatar
Did you use the MST-1 flywheel and clutch?
Old 06-25-2007, 08:45 PM   #12
shady3031's Avatar
Yes we were using the mst-1 clutch setup and flywheel and if it matters the engine was a T-12. Hope this helps!!
Old 06-26-2007, 02:01 AM   #13
Rookie01's Avatar
Thank you very much! I will give this a try.
Pascal
Motor Question RoseTuned Electric On-Road 5 09-27-2007 11:50 AM
Motor+ESC question SPO Electric On-Road 2 08-29-2006 05:29 PM
Motor fan question ChadCapece Electric On-Road 7 04-07-2005 10:09 AM
Motor Question RaceFan3 Electric On-Road 7 11-18-2004 12:19 PM
question about motor for ipc esc mf2rcr Electric Off-Road 2 08-11-2004 03:22 AM
