Old 06-19-2007, 12:59 PM   #1
FlintstoneF1yer's Avatar
Trader Rating: 14 (100%+)
Default Is this possible
Can you turn an 8th buggy into an 8th truggy? Thanks
FlintstoneF1yer is offline   Reply With Quote
Old 06-19-2007, 01:23 PM   #2
RC Pro 1's Avatar
That's exactly how the truggies were born several years ago! In most situations though your better off with a truggy than a conversion. The factory truggies have the right gearing for the larger tires as well as longer arms to make a wider vehicle and longer wheelbase than the buggies. One option if you just have to go that way is the Panther LP tires since they are almost the same diameter as a buggy tire and just a little wider. That helps the gearing problem.
RC Pro 1 is offline   Reply With Quote
Old 06-19-2007, 01:56 PM   #3
Suspended
Send a message via AIM to Nay0k
also, one of the main differences is that a factory truggies chassis will be a bit longer.
Nay0k is offline   Reply With Quote
Old 01-04-2009, 12:24 PM   #4
Anything is possible with the right amount of money!
TeamRC09 is offline   Reply With Quote
Old 01-04-2009, 01:04 PM   #5
CaptCrunch's Avatar
Trader Rating: 17 (100%+)
I was interested in the differences between the buggies and truggies myself. Not because I wanted to convert, but because I wanted to limit the duplication of spare parts. I have Jammin' X1 CR's and X1 CRT's, so it's pretty easy to compare. Here's the differences that I have noticed:
- The chassis of the truggy is both longer and wider than the buggy, which means that you also need longer drive universals or dogbones
- The arms are longer, so therefore the CVD's & turnbuckles are also longer
- The shock towers are larger on the truggy and have a different body mounting setup
- The spur gear on the truggy is much larger than the buggy
- The truggy has a large front bumper that the buggy lacks
There may be other differences, but that's what I've been able to determine from a visual inspection of my cars. Personally, if I wanted to switch from one to another I'd just buy a used truggy of the same type as your buggy.
My 2 cents
Never met an RC I couldn't crunch! If it never breaks, you're not playing hard enough.
Current Toys: 1990 RC10 Gold Pan buggy, 1991 RC10 Team Buggy, AE TC3, Diggity Designs XLR8, Tamiya TRF 415, Losi Mini Late Model, Losi Mini Slider, AE RC18MT, 2 Jammin X1X CR's, 2 Jammin X1 CRT Pro's, HPI Savage XL, Revo Platinum, Jammin X2 CR Electric Conversion, 4X2 Slash, 4X4 Slash, Losi Comp Crawler, Arrow Shark 47" Boat, Blade 400 Heli, Blade CX3
CaptCrunch is offline   Reply With Quote
