HB Lightning Stadium 10... Please Help !
I need some help and below are my issues. This is a brand new HB Lightning Stadium 10 with stock motor, stock glow plug, O'Donnell 20% Fuel. The glow plug isn't fouled and ignites just fine. I also threw in a new MC-59 and had similar issues:
I'm extremely frustrated so I just put it on the shelf. Took out my 8ight and enjoyed 2 hours of non-stop action. I've been into Nitro for the last 3 months, but never had any major issues tweaking the motor on my 8ight so I'm very confused. I've been in the hobby for the last 10+ years, so I'm pretty familiar with gear and such. Are the smaller motors that picky or is there something else wrong? Anything I'm overlooking? Any help is appreciated as my son and I are extremely bummed.... |
I have the same car, with exacltly the same issues.
What I did was to get the idle screw to push the slide in about 1-2mm, set the low speed flush then half a turn out(rich) and the HSN 2-3 full turns out from bottom. It seems to me you can turn the moto extremly rich and it wil still run. What happens if you do a pinch test on the engine? The factory motor seem to be a difficult one to tune been struggeling for about 2.5 months with mine, and still is, buts its alot better now. PLEASE LET ME KNOW!! :) |
Sounds very much like an issue I had recently with my CEN Matrix. Engine would want to fire, but die right away, or when I got it going it would die with fuel still left. Also, wheels and drivetrain would spin.
I was told to look at either a bad clutch bearing, or something that would basically locking up the flywheel to the clutchbell. When I took mine apart, some of the clutch shoe springs were damaged, and it appears some threadlock got onto the bearings binding them up. Did a full dissassembly of the clutch and put it back together, and everything feels much better now, just need to fire it up here when I get the chance. I would say start there. |
