Old 06-08-2007, 07:00 AM   #1
Post Slipper Clutch Setup?
What is the correct or best way to set up the slipper clutch? I See some people grab the wheel and try to turn the gear to see if it tensioned enough?
Danie is offline   Reply With Quote
Old 06-09-2007, 08:57 PM   #2
tighten it all the way and back it out almost a turn and a half
what car are you doing it on?
Robert.Hull is offline   Reply With Quote
Old 06-09-2007, 09:22 PM   #3
customride's Avatar
Send a message via MSN to customride
on a firestorm the manual says to turn it out 6 turns or somthing like that I dont remember, seemed rather loose to me so I just slowly tighten it from there till I get the responce I want
HPI Firestorm 10T
G3.0 engine
customride is offline   Reply With Quote
Old 06-10-2007, 08:31 PM   #4
yea your suppose to do by feel but somepeople just cant but yea on a 1/10 give 4 a try i thought it was for a MT
Old 06-11-2007, 01:41 PM   #5
Exclamation t maxx with new picco .26
Guys, just installed a picco .26 in my t maxx, and this engine is crazy, the sounds and the pull of it is pretty amazing, the question is, My slipper cluth seems to be rotating a lot and very slowly engaging the gears, is this bad? Any comments?
pedigri is offline   Reply With Quote
Old 06-12-2007, 11:53 PM   #6
Danie, my electric racing days we set it the following way. set car on the track hold both rear tires and pull trigger. you want the front tires to almost come up off the ground, if it comes up ( pops wheelie) then loosen it. if it slips bad and dont try to come up with a decent amount of force then tighten it. also what your talking about is checking the diff. some people do like your saying hold both tires then try to turn the spur. but in my experience it is easier to do like I mention above. at least on a xxx buggy or truck.
Mike Elam is offline   Reply With Quote
Old 06-13-2007, 09:53 PM   #7
Thanx, will try that tonight.
Old 06-13-2007, 11:04 PM   #8
oops i was just reading my post I thought I deleted part of it but didnt. I posted that what you were talking about was checking the diff, I was wrong. here is what I meant ok if you hold your right rear and your spur gear and turn your left tire you can check how tight the diff is (on electric) if you hold both rear tires and try to turn the spur you are checking the slipper although I feel the way I said is much better way, Matt Francis is actually the one that showed me that and its a pretty good way in my opinion.
Old 06-14-2007, 11:05 PM   #9
I Have tried it at home and works 300%!!
Thanx!
Adjusting a Slipper Clutch? TheBigEasy Micro and Mini Scales 4 06-04-2008 11:12 PM
WTB rs4 slipper clutch assy lewlew R/C Items: Wanted to Buy 0 05-21-2008 10:38 AM
slipper clutch new2this Electric Off-Road 3 05-30-2007 05:00 PM
New AE GT2 RS Slipper Clutch? Mjk87 Rookie Zone 2 03-07-2007 02:46 PM
Slipper Clutch Question. SmokinPhred Rookie Zone 1 06-03-2006 08:56 PM
