Old 06-06-2007, 03:05 PM   #1
Default Shock Oil Comparison Chart
Hey everyone,
I have created a pdf for anyone that wants it, it is a chart of different shock oils being compared. This is based on as much data as I could find on the different ratings of shock oils on the net. If I have made any mistakes or if anyone has anymore information for me I will be happy to add it to the chart.
I made this for the simple reason of being able to compare set-ups and thought it might be useful for others, I am open to any suggestions or changes...
You can download the file at the link below:
Download Shock_Oil.pdf
** I must give a thanks to Team TWF8, as allot of my data came from them
6g72tt is offline   Reply With Quote
Old 06-06-2007, 03:24 PM   #2
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
heres a link that might be helpful
http://www.twf8.ws/php/tip/shock.html
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 06-06-2007, 03:30 PM   #3
Yeah i used that site quite a bit on my research. I just found it easier to have a chart, simpler to compare...
Old 06-06-2007, 04:28 PM   #4
teabag's Avatar
thanks,
putting a copy in my toolbox
teabag is offline   Reply With Quote
Old 09-14-2007, 03:23 PM   #5
rltanner's Avatar
Thanks that was very helpful
rltanner is offline   Reply With Quote
Old 09-15-2007, 10:31 PM   #6
can you please explain the chart a little more? are we suppose to want a lower or higher cps at any given wt?,or should we use it for those extra-fine adjustments?
i am going to do a little research on cps and wt readings,but any help is appreciated.
tsanc10 is offline   Reply With Quote
Old 09-17-2007, 08:53 AM   #7
the chart is more for comparisons between different oil manufacturers. So if you ask a guy at the track what shock oil he is running, and he says losi 40 WT, and you only have xray oils, then you know what Losi 40 WT s equivalent to in Xray oil. So your setup will be much closer.
Shock oil comparison Jmnay_83 Nitro Off-Road 4 01-01-2017 05:21 PM
comparison....... kyosho 444 Electric On-Road 5 05-25-2007 06:24 AM
Mini T/B Comparison trainable Micro and Mini Scales 13 10-26-2006 03:11 AM
Shock oil comparison chart DJG24 Electric On-Road 2 04-24-2006 06:39 AM
comparison between a few .12 engines ribena86 Singapore R/C Racers 6 01-23-2006 08:07 AM
