Old 08-13-2007, 09:10 AM   #31
Trader Rating: 66 (99%+)
Hello guys,
I just bought a sweet sp2 thats dialed out, so I figured I would check this thread out and learn some things on the car, I got a ton of spares with it as well at a KILLER price...............is it worth it to upgrade to big bore shocks??? Thats my big question. thanks guys Trevor
heres everything I got with it
J-concepts body painted by Mike Czech @ czech-it-out-graphics (body in decent shape. has normal wear marks)
King headz extended motor mount (5th mount hole not drilled)
King headz frt knuckles
King Headz rear carriers
King headz frt and rear chassis braces
King Headz rear toe blocks full set
King Headz upper and lower suspension holders (full set)
Racer's Edge bulkhead to wingstay brace
Tony's screw kit installed
Kyosho Hard upper tie rod IFW123 NIP
Kyosho Fuel tank NIP
Kyosho sterring pin NIP IF35
Kyosho Shock shaft 53mm NIP IFW140-02
Kyosho Shock shaft 61mm NIP IFW141-02
Kyosho Rear arms NIP IF331
Kyosho Wheel nuts NIP IFW106B
Kyosho alum clutch shoes IFW136 NIP
Kyosho Frt lower arms NIP IF330
Kyosho bulkheads IF112C NIP
Kyosho Shock parts IFW140-07 NIP
Kyosho CLutch springs NIP 1.00mm IFW53
Kyosho Servo saver NIP IF308B
Kyosho ballends 6.8mm 1296 NIP
Kyosho clutch bell 14T 92614 NIP
Kyosho clutch bell 15T 92615 NIP
Kyosho Shimset BS53 NIP
Kyosho Springs green IF336GR IF335GR NIP
Kyosho Springs blue IF335BL
Kyosho Springs White IF335W
SOme other misc items (c-hubs, etc)
my sp2 I just bought from Chicago local - I will get better pics when it arrives
pwnzor is offline   Reply With Quote
Old 08-13-2007, 04:53 PM   #32
khoo's Avatar
pwnzor, since so much has been done to the car, might as well pop in the big bore shocks. the car is going to be even sweeter.....
The car with the current shocks already handles very well. Why don't you give it a shot and let us know how's the big bore?
khoo is offline   Reply With Quote
Old 08-13-2007, 05:25 PM   #33
I think im going to, which means I have to get the f/r lightweight universals as well, correct? I will keep you guys posted, Im looking @ prices on the net for big bore kit....who's the cheapest?? thanks Trevor
Old 08-13-2007, 06:18 PM   #34
You will only need the front Lightened universals, shock standoffs, and green front and rear springs. Build with the stock pistons they come with and try your old oil combination.
Car is better IMO with the new shocks. Feels alot more stable in the choppy stuff and lands big jumps better..
As far as shops that have them. I would go with A - Main Hobbies or www.carolinasrc.com
Its well worth the upgrade...
ultragraffics is offline   Reply With Quote
Old 08-13-2007, 07:31 PM   #35
they are like $250 to get f/r....and the rear big bore kit, and the universals are on backorder @ Amain
$170 without uni's
do you really need the unis? I hear you dont
Old 08-14-2007, 03:49 AM   #36
Crocket's Avatar
$170 without uni's
Hi Guys,
I have the Big Bores on order - they should turn up tomorrow so will let you know if the Unis are required. I haven't ordered the unis as I have been advised that you can simply space out the shock to allow clearance.
Will be in touch........
Crocket is offline   Reply With Quote
Old 08-14-2007, 04:31 AM   #37
khoo's Avatar
Dude, I just can't seem to locate the big bore shocks in A-main hobbies. Could you share the link?
thanks
Old 08-14-2007, 02:03 PM   #38
Originally Posted by Crocket View Post
Hi Guys,
sounds great man..........who did you order them from?
thanks,
Trevor
Old 08-14-2007, 02:13 PM   #39
Crocket's Avatar
Hiya,
I bought mine from the LHS here in New Zealand however you guys can buy these from Amain.
There is no single part number for the front or rear as the springs etc are bought seperately.
here are links to each of the parts
KYOIF346 Kyosho Rear Big Bore Shock Set (MP777/ST-R)
http://www.amainhobbies.com/product_...ducts_id/14936
KYOIF349 Kyosho Front Big Bore Shock Set (MP777)
http://www.amainhobbies.com/product_...ducts_id/14946
KYOIF346-04 Kyosho Big Bore Shock Steel Shock Bushing (4)
http://www.amainhobbies.com/product_...ducts_id/14937
KYOIF348-1116 Kyosho Big Bore Rear Shock Set Springs (Light Green - Hard)
http://www.amainhobbies.com/product_...ducts_id/14944
KYOIF348-1216 Kyosho Big Bore Rear Shock Set Springs (Purple - Soft)
http://www.amainhobbies.com/product_...ducts_id/14945
KYOIF350-816 Kyosho Big Bore Front Shock Set Springs (MP777 Light Green - Hard)
http://www.amainhobbies.com/product_...ducts_id/14947
KYOIF350-916 Kyosho Big Bore Front Shock Set Springs (MP777 Purple - Soft)
http://www.amainhobbies.com/product_...ducts_id/14948
and the Unis if desired (optional)
KYOIFW333 Kyosho Light Weight Front Universal Swing Shaft (90.7mm)
http://www.amainhobbies.com/product_...ducts_id/14933
KYOIFW334 Kyosho Light Weight Rear Universal Swing Shaft (89.5mm)
http://www.amainhobbies.com/product_...ducts_id/14934
All these parts are linked from the following page
http://www.amainhobbies.com/index.ph..._25_133/page/4
Cheers...........Dave
Old 08-14-2007, 04:36 PM   #40
khoo's Avatar
Hiya,
Dave,
thanks. I'm sure you're enjoying the ride now.
Old 08-14-2007, 06:19 PM   #41
Crocket's Avatar
Exclamation
I haven't recieved them yet..hopefully today
Here is a link to my local supplier which is KW Racing
http://www.rcracing.co.nz/kwracing/index.htm
I would recommend contacting Kelvin (owner) to compare prices as he is very competitive. Not sure what his freight charges are.
His email address is Kelvinwnz@hotmail.com
Cheers............Dave
Old 08-15-2007, 03:32 AM   #42
Crocket's Avatar
Talking
Woohoo.....Big Bores have arrived
I have just finished building and installing them and I can honestly say that they are huge.
I can also confirm that the light weight universals aren't required in the rear as there seems to be plenty of room, see below
Rear Shock clearance from Universals
The front ones are a little tighter, they dont touch, however I felt some extra room was a good thing so I've simply spaced the top of the front shocks out about 2mm which allows some extra clearance. - You will need to use longer mounting bolts if you are planning to do this.
Top of front shocks - Note the silver spacer
Room now between shock and front universals.
Now I cant wait for the weekend so I can go and test out this bad boy
Old 08-15-2007, 07:14 AM   #43
khoo's Avatar
Dude,
Sweet. Very sweet! is there any clearance between the springs and the universals when the shocks are depressed? what shock oil settings did you use?
Old 08-15-2007, 07:52 AM   #44
that looks dialed Crocket, let us know how they work for you, and any issues you may come across with them
Old 08-15-2007, 09:48 PM   #45
Jason's Avatar
Crocket - Can you post more pictures of your fuel line layout?
Just got a Kyosho MP777WC and finished putting it together tonight.
Can't wait to drive it this weekend. Looking for a starting setup for a hard
packed track with a dusty surface. Anyone? What kind of surface is the setup at the top of this thread good for?
Thanks,
Jason
| Team Orion | KO Propo | SPEEDLine Designs | RMS Graphix | HobbyTown USA, Rockford Il |
Jason is offline   Reply With Quote
Kyosho V-One S III Cup Edition 2 or EVO vazzo Australia Wanted to Buy 3 09-02-2008 02:23 PM
WTB-KYOSHO RRR WC EDITION corney_01 Australia Wanted to Buy 0 07-23-2007 10:59 PM
KYOSHO V-ONE III CUP EDITION 2 corney_01 Hong Kong Racing 0 07-08-2007 01:08 AM
Kyosho V-One RRR WC Team Edition Roller(laydown servos edition) - $245 Shipped! AZrcDude R/C Items: For Sale/Trade 40 07-03-2007 11:15 PM
Kyosho V-One RRR WC Team Edition Roller(laydown servos edition) - $300 Shipped AZrcDude R/C Items: For Sale/Trade 39 06-20-2007 03:55 PM
