Old 01-28-2008, 06:02 AM   #271
tex1's Avatar
Send a message via Yahoo to tex1
On Buggy I run BLS9451 in steering because it is 147 oz/in of torque and they are fast as well. I run the standard 9451 on throttle. If the servo looses power my throttle band closes it with no problems.
I run the BLS9351 for steering in my truck and am loving that servo.
No complaints on the Futaba stuff here.
TEX
tex1 is offline   Reply With Quote
Old 01-28-2008, 06:59 AM   #272
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Same here, no issues with the Futaba servos, but some seem to be destoying the gears in 5 minutes it seems in truggies.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 01-28-2008, 07:20 AM   #273
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
I've heard that too. I have some spare gears in my box but haven't needed them yet.
I've been testing a Hobbico Digital servo that has 300+ oz of torque and it's been working very well in my ST-RR. I was worried about the speed but I don't find myself waitng for it ever. Battery life seems to be good using it too.
Jon Carlson is offline   Reply With Quote
Old 01-28-2008, 09:24 AM   #274
Registered User
Kendall Welch's Avatar
Originally Posted by Swen View Post
There is no way anyone can feel the speed difference between the 9351 and the 9451. It's always nice to have the torque though. Just out of curiousity, Kendall, have you ever ran the 9351?
Yes, I have one in my truggy. It sucks when you are bycicling on two wheel and you can't counter the steering fast enough because the servo is slower. Or when you have a tight chicane and it won't turn fast enough for the second one. Other people have told me you can't tell the difference between the two also, but after running the JR .06 servos in mod buggy you can tell a difference between a 9451 and a 9351 in gas. I have ran a 9451 in truggy before as well and had no problems with not having enough torque.
Kendall
Kendall Welch is offline   Reply With Quote
Old 01-29-2008, 05:06 PM   #275
jeff1's Avatar
Questions??
Hello guys
my friend have a Inferno US Sports and want to get race shocks
I was thinking on the bigbore, but have no idea if they will fit
anyone has changed the shocks can tell his experience
jeff1 is offline   Reply With Quote
Old 01-30-2008, 07:21 PM   #276
jeff1's Avatar
7.4kg torque servo will be good for throttle? This specs is of a Sanwa Digital ERG-WZ... Can brake good?
Old 02-04-2008, 04:55 AM   #277
BigRed's Avatar
Trader Rating: 20 (100%+)
Ok boys and girls I have my big bore shocks on the way. I dont have any kyosho shock oil on hand. I do have Associated and losi oils. Any suggestions F/R? Thanks.
Lake Superior R/C Car Club
lsrcc.com
BigRed is offline   Reply With Quote
Old 02-05-2008, 04:17 PM   #278
Jason's Avatar
Think I'm running 30-35 front and 30 rear with blue springs up front and Lt Green on rear.
| Team Orion | KO Propo | SPEEDLine Designs | RMS Graphix | HobbyTown USA, Rockford Il |
Jason is offline   Reply With Quote
Old 02-17-2008, 05:32 PM   #279
t hatcher's Avatar
i hear alot of people say that the k car works better when it is as light as posible does anyone know what mods are done to make it lighter. thanks for any help
t hatcher is offline   Reply With Quote
Old 02-17-2008, 05:39 PM   #280
Trader Rating: 15 (100%+)
I'm posting on this thread in hope that a buggy guy can help me.
I run an Inferno GT rally car in an on-road series that we run in the summer. After using the two-speed that the IGT comes with for a season, I'm ready to swap it out for a center diff for various reasons.
I acquired a center diff assembly and towers from an MP7.5 and they mount to the chassis just fine. The problem is that the dog bone I had is now 3mm to 4mm too short. I tried using an MP7.5 universal in place of the stock IGT dog bone which helps because at least one side (the side that attaches to the front gear box) can be fixed in place which eliminates the dog bone from falling out altogether. However, the problem is still that where the universal shaft connects to the center diff, it's just barely reaching and I fear problems.
Can anyone recommend a solution that will get me another 3-4mm? Here's what I hope will be a picture:
Arboleda is offline   Reply With Quote
Old 02-18-2008, 05:23 AM   #281
ezveedub's Avatar
The new axle shafts are lightened. Also, taking off some aluminum, like the radio tray posts and the wing stay posts. I have the F, R & C lightened axles, K Factory laydown servo tray, and carbon front bulkhead brace. I am going to change the shock towers soon to carbon fiber. I would like to change out the pinions for Fioroni. Mine have some wear and the Fioroni's are a bit lighter and stronger.
Old 02-18-2008, 06:23 AM   #282
BigRed's Avatar
I would start taking some measurements of what you're going to need. The SP2/WC usses a longer chasis and maybe one of those universals would work. I know also that the Hot Bodies Lightning ST center universals will work on the Kyosho buggy. I cant remember how those compare in length with Kyosho buggy.
lsrcc.com
Old 02-18-2008, 09:50 AM   #283
t hatcher's Avatar
thanks for the info
Old 02-23-2008, 12:51 AM   #284
Just got done ready this entire thread thanks for all the info guys and please keep it coming.
Bfly is offline   Reply With Quote
Old 03-15-2008, 06:15 PM   #285
xlgraphicspro's Avatar
i don't know why I haven't seen this thread, it's more helpful setup wise compared to the regular sp2 thread
anyway, on to my question. I just got a SP2 WC and I'm trying tochange the oil in my Big bore shocks.It calls for Kyosho 600 Wt. oil in fornt and 450 Wt. in rear.
The problem is that I have a ton of Losi and assocated oil on hand and I don't know what the Kyosho weights are as compared to Losi or associated shock Oil, some one help please.
My only guess wa 600= 60 Wt. 450 =45 Wt? That sounds wrong because 60 Wt, that's super thick!
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Kyosho V-One S III Cup Edition 2 or EVO vazzo Australia Wanted to Buy 3 09-02-2008 02:23 PM
WTB-KYOSHO RRR WC EDITION corney_01 Australia Wanted to Buy 0 07-23-2007 10:59 PM
KYOSHO V-ONE III CUP EDITION 2 corney_01 Hong Kong Racing 0 07-08-2007 01:08 AM
Kyosho V-One RRR WC Team Edition Roller(laydown servos edition) - $245 Shipped! AZrcDude R/C Items: For Sale/Trade 40 07-03-2007 11:15 PM
Kyosho V-One RRR WC Team Edition Roller(laydown servos edition) - $300 Shipped AZrcDude R/C Items: For Sale/Trade 39 06-20-2007 03:55 PM
