Old 09-03-2008, 06:57 PM   #1441
FrankBlack's Avatar
New engines are very tight, you wanna heat the engine before you start it up with a heat gun or hair dryer, and/or loosen the plug before starting, and/or put in another head shim. Heating the engine before you start it is the best way, less strain on the conrod.
FrankBlack is offline   Reply With Quote
Old 09-04-2008, 03:41 AM   #1442
slow coach's Avatar
sounds like its stuck at TDC no amount of cranking will unstick it, you will have to manually force it back by levering the flywheel with a screwdriver brutal i know but thats the way, once its free make sure the piston is near the BDC then heat up the engine with a hairdrier so its nice and hot then try again, never leave the motor stuck at TDC always bring it back down the liner
Kyosho MP9TKI2 soon to be TKI3, Novarossi, SMD, GM Racing, www.grccc.org
a great wife and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
Old 09-04-2008, 06:56 PM   #1443
Eccentric's Avatar
Originally Posted by krimsonkid View Post
brand new. now it seems like the starter wheel is losing power??
Most new engines these days have a crazy amount of 'pinch' when new. Heat that engine up with a heat gun or a hair dryer before starting. That'll make the 'pinch' much easier for your starter box to spin through. It'll be a lot easier on the connecting rod too. When you preheat the engine the sleeve expands to near running dimentions.
Heat the head and the upper portion of the crankcase until you get a 200 degree reading at the glow plug. You can also rotate the flywheel backwards by hand until it stops. This will give your starter box a 'running start' when spinning the new engine over for the first time.
When heating the engine with a heat gun be carefull not to melt plastic parts on the car---epecialy the body!!!
Edit:
D'Oh!!! Why didn't I see that two other guys had already said the same thing????
-Aaron
Dangit, when did all my favorite cars, trucks, airplanes, and engines become "vintage"???
Eccentric is offline   Reply With Quote
Old 09-04-2008, 08:01 PM   #1444
Registered User
Use a hair dryer dont have to worry about melting parts, the ole dryer will get it hot enough!!!
Loop&Roll is offline   Reply With Quote
Old 09-08-2008, 05:56 AM   #1445
vti-chris's Avatar
Will the 38T crown gear work with the 13T bevel gear for the front diff?
I've read somewhre on this thread that someone preffered it than the 11T bevel because it meshed better.
Also will it work, performance wise?
I know that some use the 38/11 on the rear but the ratio is closer to 43/13 than the 38/13.
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 09-08-2008, 07:45 AM   #1446
Cannondale1974's Avatar
Trader Rating: 29 (100%+)
Sorry, I'm being a little lazy and don't want to read through 50 pages
Can I get some information on the BCE chassis, does it really help the 5R that much, if so how? I'm only club racing and just bought a 5R, does anyone have a chassis for sale by chance?
Thank you!
Cannondale1974 is offline   Reply With Quote
Old 09-09-2008, 09:28 AM   #1447
krimsonkid's Avatar
Thanks guys got her up and running. What is everyone doing with the exposed ball joints around the wheels, are boots available?
krimsonkid is offline   Reply With Quote
Old 09-21-2008, 10:00 PM   #1448
slow coach's Avatar
Smile
Life in the old dog yet 3rd place at the worlds running with the new MBX6 shocks and towers
Old 09-21-2008, 10:22 PM   #1449
OBMIT's Avatar
Im pretty sure he was running a 6 i just looked at the pics and the tank is diffirent as well as the radio tray
www.timnicolphotography.com.au
811 Cobra - Ninja - Ace - Spektrum
Plaig RC Bearings
OBMIT is offline   Reply With Quote
Old 09-22-2008, 01:00 AM   #1450
slow coach's Avatar
where did you see the pics
Old 09-22-2008, 02:38 PM   #1451
ilmugenracer's Avatar
Send a message via MSN to ilmugenracer Send a message via Yahoo to ilmugenracer
Thank you!
the bce chassis is about 5mm longer and moves everything forward from the rear gearbox. due to this addition in length you must use these cvd parts: Losi A3528 & losi A3514 http://www.amainhobbies.com/product_...ducts_id/12306 http://www.amainhobbies.com/product_...oducts_id/7711
I personally felt the BCE chassis gave the car more steering and i have heard that it does not wear as quickly in the rear like the stock 5R chassis.
Ryan Bauer
http://myworld.ebay.com/staind_rock <-- ebay feedback
Mugen Seiki, Advantage Racing Bearings, Kiefer Designs
ilmugenracer is offline   Reply With Quote
Old 09-25-2008, 06:07 AM   #1452
OBMIT's Avatar
Hi there here it is its a bit muddy though.
Plaig RC Bearings
Old 09-28-2008, 08:03 PM   #1453
Lebatek's Avatar
Send a message via AIM to Lebatek
Default MBX5/5R Prospec Parts
Hey guys,
Cleaning out the race room, and I have a batch of MBX5/5R Propsec parts listed on Ebay. Do a search under Mugen.
Cheers,
John Lebak
Sponsored by: Team Associated, Reedy, Airtronics, LRP, and Mugen
Lebatek is offline   Reply With Quote
Old 09-28-2008, 10:00 PM   #1454
hairymuffin's Avatar
Trader Rating: 93 (100%+)
That car is without a doubt a X6!!! My frien was driving his today and he said the best difference is the acceleration. There will be a Pro spec kit with ti screws and rear alluminum hubs. Box says US version with carbon towers. I was curious as to why I seen some kits with cnc towers. Not to many options to buy here for this car. For $850 car I guarantee the makers of Kyosho will come out with option parts. It never fails!!! Dont know what parts because it also looks pretty complete. Next year will make for some good racing for sure with all the cars out. Funny after all these years Mugen had changed their air filter to a 2 stage. They have been using the same filter since '93(Athlete). Always worked though. Only part I can see carried over from the X5 is the steering slider.
hairymuffin is offline   Reply With Quote
Old 10-12-2008, 06:08 PM   #1455
zfmrchnt's Avatar
Trader Rating: 34 (97%+)
Default clutch assembly
looking for just the clutch nut but im interested in a whole new assembly. if any has any suggestions or comments please advise.
zfmrchnt is offline   Reply With Quote
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
