Old 07-13-2008, 04:33 AM   #1336
slow coach's Avatar
Originally Posted by Turbine_au View Post
Used some 2mm washers to take out the bump steer today. Was a bit faster when I stopped overdriving it. The only problem is, the threads on the steering balls don't hit the nylon in the locknut now. Anyone make a steering ball with a longer thread? I know about using loctite but if I can use the locknut like they're supposed to, that'd be better.
try turning the nut over and go through the nylon first ??
Kyosho MP9TKI2 soon to be TKI3, Novarossi, SMD, GM Racing, www.grccc.org
a great wife and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
Old 07-13-2008, 04:53 AM   #1337
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
i just used a 1mm spacer and works good bout half a mm sticks out the nylon section and has stoped the bump steer maby give that a try or what slow coach said
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 07-13-2008, 06:23 AM   #1338
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Usually with a 2mm spacer, the ballend still threads into nylon. It just sits flush, or a hair below flush.
As for me. I had installed RC8 tierod ends and ballends. They sit taller just using them instead. No spacer needed
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 07-13-2008, 07:52 AM   #1339
Turbine_au's Avatar
Never thought of flipping the nut over, might give that a go. I've got the stock steering balls and nuts and the screws get nowhere near flush.
Using the 2mm spacers made a lot of difference, the car felt a lot better as long as you didn't over drive it.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 07-13-2008, 09:04 AM   #1340
Reckward Tuning #rmvtu8706 has a set of steering balls with a long screw
going straight through the ball; Amain carries them but they are out of stock
now.
Has anybody had problems with the front or rear aluminum chassis brace
loosing up during a race? Mine seem to loosen up during every five minute
heat race. I'm thinking it's not only the screw and the locknut,but the
aluminum braces vibrating, rubbing and wearing down the aluminum chassis.
I tried to use the 5t modified plastic braces but it prevents use of the battery
box lid. I'll try putting a thin piece of plastic or paper between the brace and
the chassis to absorb some of the vibration.
topcat-lll is offline   Reply With Quote
Old 07-13-2008, 01:54 PM   #1341
what is the cheapest place to buy an MBX-5R?
revracer222 is offline   Reply With Quote
Old 07-13-2008, 02:13 PM   #1342
my front chasis brace used to always loosen up during the heats rear was always fine using the kfactory braces i simply got a bottle of high grade loctite from my friend who works in engineering place. nver had any more problems until i had to get it off which i ended up using a lighter.
adz06 is offline   Reply With Quote
Old 07-13-2008, 02:58 PM   #1343
ezveedub's Avatar
There was a NIB R in the for sale threads
Old 07-13-2008, 06:36 PM   #1344
TonysScrews's Avatar
Just use a slightly longer screw and put a locknut on top of it....problem solved
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 07-15-2008, 05:49 PM   #1345
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Asking this question for a buddy of mine. He just picked up a MBX5R. What is a good setup for large outdoor, rough, loamy track. All I could find is the kit setup on their site and the 06' worlds Hughes setup. Which would work better.
Thanx``
Dasupacat1 is offline   Reply With Quote
Old 07-16-2008, 01:38 AM   #1346
Turbine_au's Avatar
now.
Yeah, I wanted to order those, but they've been out of stock since I've been looking at them which has been about a month now.
Old 07-16-2008, 03:10 AM   #1347
slow coach's Avatar
Thanx``
go with the hughes 06 worlds
Old 07-16-2008, 03:28 AM   #1348
Check out the Mugen forum here for setup help:
http://www.mugenracing.com/phpBB2/
Scott Hughes and the Tillman's are on the forum. Try to get a setup for Silver State as it is a rough blown out track. The World's setup may not work well as that track was in Indonesia.
Best regards,
Tony P.
Tonys Screws LLC
Old 07-22-2008, 05:42 AM   #1349
vti-chris's Avatar
I'm looking into purchasing the 3.2 rear and 2.7 front sway bars.
I found the 2.7 front on amain but can't seem to find the 3.2mm.
Anyone knows if the sway bars from the truggy fit directly on the buggy?
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 07-22-2008, 05:52 AM   #1350
paulj2's Avatar
The sway bars do interchange.
paulj2 is offline   Reply With Quote
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
