Old 06-21-2008, 07:56 PM   #1276
imaxx21's Avatar
Send a message via AIM to imaxx21
a few guys run that way
you'll need to run a 44t spur with a 16t bell to make it even out tho
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 06-21-2008, 09:47 PM   #1277
Vsfriedmugan's Avatar
Send a message via MSN to Vsfriedmugan
Originally Posted by quietstorm76 View Post
Hey guys can someone tell me the ratio of the ring and pinion gears. I'm wondering if changing to the X5T gears will help me out of the corners. My car just seems sluggish compared to my Kyosho. The kyosho had less power and it would kill my X5R off the line. Any advice?
try 35t conical in the rear diff 48t spur 13t racers edge ni-tri cb dyn. max life shoes w/ 1.0 mugen sp this combo works extreamly well also iam bias but a powerhouse modded v-spec w/ ttr 2035!
MBX6>>FUTABA>BYRON FUEL>O.S>ProTek>HITEC
and a mask to inhale nitro fumes
Vsfriedmugan is offline   Reply With Quote
Old 06-22-2008, 12:26 AM   #1278
Registered User
ummm, wtf does that all mean
Loop&Roll is offline   Reply With Quote
Old 06-22-2008, 03:17 AM   #1279
Winner's Circle's Avatar
Default ratio
I had the same problem with my MBX5T. I tried 2 things that helped a lot = 48T spur and 12T clutch bell. These things really helped get the car to move coming off of a turn so that it would generate the speed needed to make the jump. I have the 12t in stock but sold the 48.
Lee
Lee Muse
leemuse3445@comcast.net
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 06-22-2008, 07:42 AM   #1280
Turbine_au's Avatar
35 tooth conical gear in the rear diff. 48 tooth spur gear with a 13 tooth clutch bell, made by racers edge. Dynamite max life shoes with 1.0mm mugen clutch springs.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 06-22-2008, 08:04 AM   #1281
slow coach's Avatar
do you run the recommended pinion gear with the 35t crown gear or just run the crown gear on its own?
Kyosho MP9TKI2 soon to be TKI3, Novarossi, SMD, GM Racing, www.grccc.org
a great wife and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
Old 06-22-2008, 04:34 PM   #1282
quietstorm76's Avatar
Lee
Hey Lee I'll call you tomorrow evening.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 06-22-2008, 05:16 PM   #1283
turbine traslated it for you bro!!
Old 06-22-2008, 10:25 PM   #1284
maximugen's Avatar
Send a message via MSN to maximugen
u have to run the matching pinion, otherwise it wont mesh
Mugen MBX5r - N/R 367 / Sirio bx STi
Mugen MST1 - JP RS12
Losi JRXSR- LRP SPX and Speed Passion 17.5R
HPI Savage - N/R 528
Trex 250
maximugen is offline   Reply With Quote
Old 06-22-2008, 10:36 PM   #1285
maximugen's Avatar
double post :@ plz delete
Trex 250
Old 06-23-2008, 05:27 AM   #1286
Why use a 35 tooth crown gear. It has a 40t now, or am I thinking of the wrong gear?
Primary Weapon: ?
Secondary Weapon: ?
Old 06-23-2008, 07:54 AM   #1287
I have been racing mugen mbx5 prospec for while and recently got the mbx5r and was racing sunday last. I used the same setup as my old car on my new car or very similar anyway. BUT i am having a problem with the car rolling at a particular part on the track as its a long rough and corner. I was using 40 front 37.5 rear as the track has a load of jumps i lowered the car 3mm and it handled better but on landing one of the jumps in the final flywheel musta hit ground or somthing as car just stalled on landing.
so looking for any advice to help stop the car rolling shock positions are on the lower arms (holes closest to the wheel) and on the shock towers middle mounting holes. pistons etc are stock.
i am wondering should i try running shockoil 35 30 or 30 30.
thanks
adz06 is offline   Reply With Quote
Old 06-23-2008, 08:02 AM   #1288
slow coach's Avatar
Queitstorm76
no you are on the right gear thinking there it just works different to how you think it would work if that makes sense, i always thought the bigger gear would aid acceleration as a bigger spur does but it doesnt the smaller crown gear will turn faster than a bigger gear does and increases acceleration in the process.
Maximugen
thats what i thought just wanted to make sure as people do read what is on these forums and do whats posted
Old 06-23-2008, 11:08 AM   #1289
no i made a mistake... what i meant to say was a 38t conical for increased rpms out of the corners. sorry bout that
Old 06-23-2008, 11:14 AM   #1290
I run the 38t in the rear with the stock bevel believe it or not.. it works well and the mesh is good. I purchased the recommended 11t bevel but the mesh wasnt to my likeing so the stock was put back in and i havent had any problems. the rpm increaseed giving me a lil jump on the hairpins
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
