Old 06-04-2008, 08:17 PM   #1216
TonysScrews's Avatar
Sorry pracy, I haven't been on the forums the last two days to reply but it looks like your questions were answered.
If you sand the diff cups, you can still use one gasket as you're only taking off maybe 0.0004" (yes that is right 4/10,000ths). When you build the diffs, there are 4 thin washers/shims that go behind the four small spyder gears. You have to use these. But do NOT use the small S3 o-rings in the manual. On the S5 o-rings, I sent you some of my MBX5 o-rings that I sell on my website. They are slightly thicker than stock and work very well. Don't be afraid to use the grease on the o-rings, the out drives (make sure you get grease in that grrove on the out drive shaft) and the large washer/shims that go behind the two larger spyder gears. There will feel like there is a lot of play in the diff when you assemble it and push the out drives in and out. But when you spin teh out drive it'll feel tighter. Only fill with diff fluid to the cross pins. I fill mine and then slowly turn the outdrive in the cup to settle the oil.
Best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 06-05-2008, 09:36 PM   #1217
thankyou very much for your replies fellas!!
do you guys use grease on your ring and pinion gears? (the gear that connects the drive shafts to the diffs if thats what its called)
I have some metal shavings after using them without grease and i am helping a mate put a xray 808 kit together and they show using grease in that area.
should i be using some?
thankyou heaps!
pracy is offline   Reply With Quote
Old 06-05-2008, 09:43 PM   #1218
Turbine_au's Avatar
If you're talking about inside the diff housing, then yes, grease that. I use a fair bit of grease in there.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 06-05-2008, 10:05 PM   #1219
Integra's Avatar
thankyou heaps!
coat the Ring gear all the way around while spinning the gear and it'll get all over the pinion....but using EXcessive amounts is not needed...coat the gear's and ur good....anything extra will be Slung off the gears anyways.
Old 06-05-2008, 10:30 PM   #1220
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
I will coat the gear and pinion with automotive axle grease. I dab some in the groove of the chassis also. Eventually it slings off, but with bumping around the grease will always be there for the ring gear.
Also, I smear Mugen super grease around the bottom of the bulkhead case where it seals against the chassis. This leaves a barrier to catch dirt and keep out moisture from creeping in when cleaning the car.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 06-06-2008, 02:15 AM   #1221
slow coach's Avatar
run a bead of grease around ring gear you dont need loads as most of it flings off anyway but you do get some left behind, if you can get it try the eureka lube this stuff is supposed to be the stuff for this kind of application it also works with spur clutch bell contact also, the lube has had some very good comments from seasoned racers so looks good, havent tried it myself yet but its on my list
http://www.twf8.ws/new/tech/options/.../eurekapro.htm
http://tkocompetitiondev.com/shop/index.php?cPath=38_97
Kyosho MP9TKI2 soon to be TKI3, Novarossi, SMD, GM Racing, www.grccc.org
a great wife and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
Old 06-06-2008, 07:55 AM   #1222
I just use black moly grease on my ring and pinion gears. Just a light coating as like everyone here has said it'll just fling off ifyuo put on a lot.
Best regards,
Tony P.
Tonys Screws LLC
Old 06-06-2008, 08:52 AM   #1223
fasteddie2's Avatar
Trader Rating: 30 (100%+)
I'm looking for a 48t spur gear,anyone have one to sell?
fasteddie2 is offline   Reply With Quote
Old 06-06-2008, 08:53 AM   #1224
Trader Rating: 16 (100%+)
Default New Mugen
I am sure I have missed this thread, but does anyone have news on a new Mugen buggy
tshaec5r is offline   Reply With Quote
Old 06-06-2008, 09:03 AM   #1225
Turbine_au's Avatar
My clutch seems to be overheating, discolouring the clutch bell and killing clutch bearings. Anyone know where I should be looking for a problem? Aluminium shoes, 1mm springs, 14t cb, standard spur, novarossi Plus 21-5. Shoe wear to be expected, springs still sit within shoe easy.
Old 06-06-2008, 09:21 AM   #1226
Integra's Avatar
what shoes ?..and how old are they ?
Old 06-06-2008, 09:37 AM   #1227
Turbine_au's Avatar
Mugen aluminium ones, not very old.
Incorrect shimming maybe? How much play do you guys have in your clutchbell?
Old 06-06-2008, 09:46 AM   #1228
Integra's Avatar
nah the stock mugen alum are JUNK in yo Trunk....compared to other 7075 allum shoes they arent the best....i would look into a set of Dynamite Max life shoes...or Ofna Silver's...both are the good 7075 and should take WAY more abuse then the mugens do.....u should have .4 end play in the bell...Kyosho 5X7 shim kit is what u reallly need to get 100% bang on end play.
and keep the 1.0 spring set-up...1.1's KILL shoes alot Faster then 1.0's.
Old 06-07-2008, 01:08 AM   #1229
vti-chris's Avatar
Can anyone measure these on their MBX5r front shock tower?
I would also like your input on the carbon shock towers sold on ebay...if someone has tried them out!
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 06-09-2008, 11:30 AM   #1230
slidejob26's Avatar
Congrats to Mr. Hughes and Mugen - Top 5 at the nats!! with the buggy every one says is too heavy and slow!
Scott
PERFORMANCE RC, Burlington WA 360-755-7084/360-755-9464
slidejob26 is offline   Reply With Quote
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
