Old 05-17-2008, 10:43 PM   #1141
cbaranski's Avatar
Trader Rating: 43 (100%+)
GREGORY!
The washers on the steering tie rods is the perfect fix. I never really realized how much bump steer affects the handling so much. Tonite I was on fire. Tore up all the rc8's and losi's on the track. I love this forum for info.
Chuck
Chuck Baranski www,pikemotorsportsrc.com
Xfactory SCX60CF w/ 12mm BB, Tekin RSX, Tekin RPM 17.5, Savox 1258
AE B5M FT, Tekin RS, Tekin RPM 17.5, Savox 1258tg
cbaranski is offline   Reply With Quote
Old 05-17-2008, 11:55 PM   #1142
how are the bce chassis?
Mugen MBX5R - retireded Passion
22 3.0 SR Hobbywing 3.1 Stock Spec Trinity 17.5 24k Reilley Motorsports
B6 Hobbywing 3.1 Stock Spec Fantom
22 SCT 2.0 Exotek Hobbywing 3.1 Stock Spec Fantom
Tekno 410SCT Hobbywing ProSC
mugenlife is offline   Reply With Quote
Old 05-18-2008, 12:03 AM   #1143
cbaranski's Avatar
mugenlife,
I have the R model, there is a extended chassis that is out now to. I like it. Made the car a little more rigid for less flex. Fit is perfect. It handles alot better on rough track and is more predicable.
Chuck
Old 05-18-2008, 01:39 AM   #1144
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Originally Posted by cbaranski View Post
GREGORY!
Chuck
Glad it hear it worked out for you.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 05-19-2008, 06:08 PM   #1145
Default Starter Box Pad
Hey guys whats the name of that company or can somebody give me a link to where I can buy that starter box pad for the 5R? I thought it was TKO but it doesnt come up when i do search for it. Help a brotha out
Bubonic-X is offline   Reply With Quote
Old 05-19-2008, 08:25 PM   #1146
Crim3Wav3's Avatar
well...it doesnt "look" pretty from the picture, but I've recently seen this on ebay....
http://cgi.ebay.com/Mugen-Prospec-MB...2em118Q2el1247
...but you didnt hear it from me
Crim3Wav3 is offline   Reply With Quote
Old 05-19-2008, 08:32 PM   #1147
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
ran my 5r for the second time. i felt more comfortable wheeling it but not as comfortable as i was with my jammin. i think 1 or 2 more weekend and ill be better then i was with my jammin. i love the way i can throw this buggy into a corner and peg the throttle and it turns or i can lay into it and hit the brakes and it still turns. im liking this buggy more and more... next hop up for it is the bce extended chassis
cheesecake is offline   Reply With Quote
Old 05-20-2008, 01:48 AM   #1148
slow coach's Avatar
the plates are available from carolinasrc well at least they were not sure if they still are but my m8 got one from there a while ago, they work ok but he was a little unimpressed with the slop between the chassis and the plate there was some sideways movement which kinda defeats the object of it really.
anyone got a link for bce chassis ? sorted found it eventually
just in case http://www.rcracingparts.com/index.htm
Kyosho MP9TKI2 soon to be TKI3, Novarossi, SMD, GM Racing, www.grccc.org
a great wife and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
Old 05-20-2008, 02:05 AM   #1149
hi all,
can someone more experienced with setup of the MBX5R then myself please answer a couple questions please as i am trying to set my buggy to the stock settings..
the first question..
In the MBX5R instructions it says to use one 2mm spacer on the front of the pin on the Front suspension upper arm and two 1mm spacers at the back end of the pin. Though the setup sheet says to use 1mm spacer for the Upper arm spacer only.
If I just use 1mm spacer it leaves 2mm of un-used or un-spaced pin which will allow the upper arm to slide back and forth.
What is the correct position and number of spacers to be used here?
pracy is offline   Reply With Quote
Old 05-20-2008, 02:36 AM   #1150
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
adjusting the spacer in front and behind the upper arm are adjust your caster but dont leve any gap to allower the arm to slop back and forth having the arm more forward gives more positive caster which is good for slow speed corners and less space is better on high speed corners there is no set recommended amout just play around to find what best suits your driving style and track layout just dont let the arm slap back and forth
Nitro$junkie is offline   Reply With Quote
Old 05-20-2008, 02:52 AM   #1151
thankyou for the explanation cheers. though i am still confused by what they want in the setup sheet.
Do they want 1mm spacer at the back of the pin and 2mm at the front which is opposite to what the book shows...?
also the rear arm spacer on the setup sheet says 0mm. does that mean no spacers in the rear?
i will exeriment this weekend but for now i want it exactly like the setup sheet as this buggy is new and it will be a good starting point..
here is the settings sheet
http://www.mugenseiki.com/mbx5r-setu...0601kitstd.pdf
referring to upper arm spacer= 1mm (front)
and
Lower arm spacer= 0mm (rear)
Old 05-20-2008, 03:05 AM   #1152
If u want the bone stock set uphave 1mm spacer infront and fill the gap behind with left over spacers should be a 2/3mm gap dont worry bout the book is just for show refer to the setup sheet (one provided with link)
now for the rear arm i had the same issue when i first built my buggy but all i did is do the hidge pin up reel tight so there is min slop as u can, the plastic arm infront of the diff kinda bends a little i still run no spacer back there now but have slight play it didnt worry me to much the play in nothing just be able to wiggle it a little bit like half a mm back and forth just dont do it up to tight the arm will bind
Old 05-20-2008, 05:23 AM   #1153
thanks again for your reply.
i followed the setup sheet. i guess it just confused me because they stated one side of the pin 1mm without telling me about the other side.
I now have 1mm on the back side of the upper arm and 2mm at the front as shown on the sheet... (you said the other way around so i just went off the sheet. just a different way of say front/back?) I said back side meaning the side closer to the rear of the buggy where the nut it screwed on the pin.
I also have 0mm on the front side of the rear lower arm and tried using no spacer at the back which would have been fine but there is no difference in putting the 1mm spacer at the back side of the pin so i did. saves stressing the plastic i guess...
I also had the wheel hub uprights using the wrong pin hole (i was using the top hole now using the bottom so no hub is left hanging low)
also again i had all the spacers at the hub upright pin on the front side. I now have 1.5mm each side which centers the hub which i think has been shown on the setup sheet.
I completed the buggy at about 2am so i can forgive myself for stuffing these things up
Old 05-20-2008, 06:10 AM   #1154
Trader Rating: 52 (100%+)
Hey Guys
what are some tricks you guys are doing to lighten the car up??
any hop ups??? option parts??? I do fairly well with the car as it is but
think it could be a little lighter.
thanks
MO
Mo Denton is offline   Reply With Quote
Old 05-20-2008, 07:34 AM   #1155
buckeye34's Avatar
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
