Old 05-09-2008, 10:57 AM   #1111
buckeye34's Avatar
Originally Posted by mugenlife View Post
i have light weight pivot balls, some titanium screws (upper), machined a few parts, carbon hinge pins, carbon fiber rear shock mount, and the kings heads steering posts. the machining of the chassis, pivot retaining screws, side mud guards and some of the steel lower screws netted me a weight loss of some where close to 12 grams. i just would like to get it really light (still strong) and then have to add some weight to it to balance it out.
if you take weight away in one or several spots, then have to ADD weight somewhere else to balance it, aren't you defeating the purpose of lightening the buggy?
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
Old 05-09-2008, 10:57 PM   #1112
TonysScrews's Avatar
Some guys run the center diff out drives on the front & rear since they are lighter. They need to be slightly modded though. The steel ball ends add up in weight, chassis braces, ceramic bearings, Rx battery, motor (with head) and pipe, and the biggest item are tires/rims/foams.
oh, and don't forget the body & paint job. I've seen painted bodies that weight 80 grams and ones that weigh 160 grams.
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 05-10-2008, 09:36 AM   #1113
im not going to add as much as i take away. it is to keep the car balanced is all. you would be suprised how many guys run some lead weights in thier buggy's.
Mugen MBX5R - retireded Passion
22 3.0 SR Hobbywing 3.1 Stock Spec Trinity 17.5 24k Reilley Motorsports
B6 Hobbywing 3.1 Stock Spec Fantom
22 SCT 2.0 Exotek Hobbywing 3.1 Stock Spec Fantom
Tekno 410SCT Hobbywing ProSC
mugenlife is offline   Reply With Quote
Old 05-10-2008, 05:05 PM   #1114
buckeye34's Avatar
just curious about it. i've never tried to lighten the buggy.
mbx5r
v-spec
jp-3 pipe
m-11
Old 05-10-2008, 07:38 PM   #1115
just depends where most of the weight comes off at to where i will the weights. (probably only 2-4 1/4 oz weights) as off right now though the front lost more than the rear. i figure i can atleast center the weight. tony you were not kidding about the tire weight differences with regular foams vs molded. i have 1 body that weighs 74 grams the other 83.
Old 05-11-2008, 12:24 AM   #1116
Vsfriedmugan's Avatar
Send a message via MSN to Vsfriedmugan
Originally Posted by TonysScrews View Post
Most guys I know like the 48T even on good low-end motors like the V-Spec.
hey thanks I through the 48t spur on 2nite @ the track and was very pleased
thought id return the thanks and bought some of your products from carolinasrc
v
MBX6>>FUTABA>BYRON FUEL>O.S>ProTek>HITEC
and a mask to inhale nitro fumes
Vsfriedmugan is offline   Reply With Quote
Old 05-11-2008, 05:33 AM   #1117
buckeye34's Avatar
just wanted to let everyone know i put the washers under my steering ball ends to get rid of the bumpsteer and i must say, i never really understood what bumpsteer was, but after i added the washers, i FULLY understand it now! it is amazing how much better it handles and turns. thanks for the info and pics on it guys.
mbx5r
v-spec
jp-3 pipe
m-11
Old 05-11-2008, 06:55 AM   #1118
thewholeyearinn's Avatar
Tony or anyone.
I bought the mbx5t prospec front center and rear diffs as well as front and rear pinions for my mbx5r. I'm currently running the 48t spur with 14 tooth CB. how do you think the truggy gears in the buggy will compare to that. I mostly like the spiral cut, my truggy is so much smoother than my buggy.
thanks,
I don't know who I am I don't know where I've been human junk just words and so much skin stick my hands through the cage of this endless routine just some flesh caught in this big broken machine.
thewholeyearinn is offline   Reply With Quote
Old 05-11-2008, 07:06 AM   #1119
Turbine_au's Avatar
Is there a standard kit part for the washers to eliminate bump steer? If not, anyone know the washer size?
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 05-11-2008, 07:42 AM   #1120
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
With stock ballends, you need a 2mm thick washer with M3mm hole. I believe the rear hub spacers could work if you have some extras.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 05-11-2008, 10:08 AM   #1121
buckeye34's Avatar
Originally Posted by ezveedub View Post
With stock ballends, you need a 2mm thick washer with M3mm hole. I believe the rear hub spacers could work if have some extras.
that's what i used..
mbx5r
v-spec
jp-3 pipe
m-11
Old 05-11-2008, 04:44 PM   #1122
Ezveedub
Thats an simple easy fix. I havn't tried it yet, but I will next weekend, and if
it works great! Thanks!
p/s I wonder why mugen hadn't thought of this?
topcat-lll is offline   Reply With Quote
Old 05-11-2008, 05:36 PM   #1123
Antbody know of some other good Forums for MBX5r. Ive been to nitroaddicts rc universe and few others.
just curious
thanks
V
Old 05-11-2008, 06:29 PM   #1124
Has anyone tried mugen's new mbx-5r black chassis#(e0401-b)yet? Carolins-
rc has them.
Old 05-11-2008, 06:55 PM   #1125
Please disreguard my last post.
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
