Old 05-05-2008, 02:59 PM   #1081
buckeye34's Avatar
Originally Posted by ezveedub View Post
Drop a 2mm spacer under the steering ballend on the upright. Or install the RC8 ballend and outer tierod. This will take the crazy bumpsteer out. Also, the car will steer more consistent and react quicker.
Pic of it? maybe i'm just igornant(misspelled on purpose) but i can't visualize where the 2mm spacer should go.
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
Old 05-05-2008, 09:30 PM   #1082
Turbine_au's Avatar
Look at your steering uprights. Disconnect the steering linkage from the upright. The little metal ball still attached to the upright is the ball end. Remove it, place a 2mm spacer under the ball end so the ball end sits up 2mm from the upright then reinstall.
I should really see if I've got some spacers to try it.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 05-05-2008, 11:28 PM   #1083
DogboneS's Avatar
Trader Rating: 20 (100%+)
I tried this tip on mine today, and it helped a little, yet I only added about 1.5mm(used a cone washer for a 2mm screw). I think the the amount of toe out and castor also affect the amount of bumpsteer. Basically the two pillow balls and the steering link on the hub want to travel up and down in the same parallel plane. This topic was brought up in the MBX-6 thread, I don't recall if anything was done to the link at the ackerman as well.
DogboneS is offline   Reply With Quote
Old 05-06-2008, 01:58 AM   #1084
1 washer under the upright ballstud and 2 washers under the ackerman ballstuds......
Mugen MBX5R - retireded Passion
22 3.0 SR Hobbywing 3.1 Stock Spec Trinity 17.5 24k Reilley Motorsports
B6 Hobbywing 3.1 Stock Spec Fantom
22 SCT 2.0 Exotek Hobbywing 3.1 Stock Spec Fantom
Tekno 410SCT Hobbywing ProSC
mugenlife is offline   Reply With Quote
Old 05-06-2008, 07:27 AM   #1085
GREGORY!'s Avatar
mugenlife,any fhotos please?
GREGORY! is offline   Reply With Quote
Old 05-06-2008, 08:51 AM   #1086
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Go here, third post down:
Mugen MBX6
Thats a bit extreme, and you cannot use that large of a spacer with stock ball end, but you get the idea of what were talking about. The stock ballend can only take a 2mm spacer under it, or you will have to use a different ballend. I used the RC8 ballend with tierod since its longer than the Mugen stock ballend. Actually, the AE ballends come long and short, so you could go taller with the AE long ball end than a 2mm spacer under stock if needed. You need to adjust the height to your ride height and droop so you can keep the steering consistent from top to bottom of travel, as stock tends to toe out only when the suspension lowers, and toes in only when it travels up. This setup will toe out only slightly when the suspension is at the top and the bottom of travel, not just the bottom.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 05-06-2008, 09:33 AM   #1087
DogboneS's Avatar
Here's a pic of the spacer at the hub... The ball stud is one piece, so you'll run out of threads if you add any more spacers. I have some extra linkage balls(from the rear, I believe) that I may try to stack like the 777.
Old 05-06-2008, 04:21 PM   #1088
Vsfriedmugan's Avatar
Send a message via MSN to Vsfriedmugan
Iam tired of hearing about the RC8. I understand that its the new hot buggy to some. Lord knows half of the local club guys hear switched over to RC8 from there mugens but c'mon please enough already!! Ive been faithfull to Mugen Seiki for some time know and i treat my buggy like its gold and it pays me back in spades @ the track. Like last weekend i came in 123 all day and had great lap times smok'n the RC8 but everytime i go to neo or open a mag. BAM! there it is even my LH guy stated doggin the Mugen . Well enough ranting. I will always stay with Mugen and when the MBX6 kit is on my table its off to the tack to SMOKE some RC8
thanks
MBX6>>FUTABA>BYRON FUEL>O.S>ProTek>HITEC
and a mask to inhale nitro fumes
Vsfriedmugan is offline   Reply With Quote
Old 05-06-2008, 04:57 PM   #1089
Seisick's Avatar
Originally Posted by insaneracin2003 View Post
Since Mugen is re-doing the MBX5R, Do you guys think the T will be next?
mbx6 coming to the worlds, truggy wil also be revised but most likely a mbx5tR, not mbx6T
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 05-06-2008, 07:10 PM   #1090
imaxx21's Avatar
Send a message via AIM to imaxx21
we got some more buggies in..
these are prolly the last ones till the new buggy.
http://www.rccompound.com/ProductDet...tCode=MUGE0040
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 05-06-2008, 08:35 PM   #1091
Just ordered a mbx5r I want to go with the fiber brake pads which ones are the best?
What else would you change outta the box on an already awesome buggy? Im not going for broke but just need some opinions.
Your 2 cents please.........
Jake
Bubonic-X is offline   Reply With Quote
Old 05-06-2008, 08:56 PM   #1092
imaxx21's Avatar
get the RC8 ones...
be sure to run the bare metal pads with those discs
-Crash
Old 05-06-2008, 08:56 PM   #1093
cbaranski's Avatar
Trader Rating: 43 (100%+)
The only thing I changed on mine was the brake rorors to the Avid rorors and dont install the blue brake pads. And just like the previous posts about bump steer I used a couple of washers under the front upright pivot ball on the steering tie rods. I also use the truggy MBX5T ring and pinions front and rear with a 44t center gear and a 17t or 18t clutch bell. This really helps the car accelorate much faster with higher top speed.
Chuck
Chuck Baranski www,pikemotorsportsrc.com
Xfactory SCX60CF w/ 12mm BB, Tekin RSX, Tekin RPM 17.5, Savox 1258
AE B5M FT, Tekin RS, Tekin RPM 17.5, Savox 1258tg
cbaranski is offline   Reply With Quote
Old 05-07-2008, 04:03 AM   #1094
there are only 2 places on each side to do this one by the tire the other on the ackerman arm. you know the parts on the cars steering that controls the steering of the front tires? there are 2 ball studs on each side one goes on the upright the other the ackerman arm (the aluminum arm connecting the steering cranks together? the two ball studs on the aluminum arm get 1 washer the ball studs by each tire get 2 . it lessens the angle of the steering links between the ackerman arm and the front tires.
http://www.amainhobbies.com/product_...oducts_id/8986 -that is an r ackerman
this is the front upright
http://www.amainhobbies.com/product_...oducts_id/8980
i would take a picture but the way the washers sit in the ackerman YOU CANT SEE THEM and i am not taking the front end apart to show you something obvious LOL im too lazy!
try it it works! especially if you arent as lazy as me at 7 am
Old 05-07-2008, 09:50 AM   #1095
GREGORY!'s Avatar
I don't know english very well.so i asked you a fhoto [kind enough]to be sure.i am not so big noob like you think...
never mind..thank you!
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
MUGEN MBX5R F/S tshaec5r R/C Items: For Sale/Trade 25 01-14-2008 07:17 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen MBX5R Brand New Mugen Hops Ups and More bretzkej R/C Items: For Sale/Trade 8 05-27-2007 05:57 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
